查看: 2919|回复: 4
[讨论] LDO负载电流为3A时,交流仿真为什么是这样?如何改进
发表于 2014-4-24 15:00:48 | 显示全部楼层 |阅读模式
QQ图片20140424145749.jpg 增益怎么变成这样,怎么从负的开始,如何分析,电路改怎么改进
发表于 2014-4-24 15:53:11 | 显示全部楼层
Hi Apenper:
If the output cap has a ESR, the LDO is 2 pole and 1 zero system.
At the heavy load, one pole is higher than the zero and other is
closed to low frequency the result is like your picture.
If your compensation is based on an external element (Cout + ESR),
I suggest the zero is in the LDO.
mpig
发表于 2014-4-24 17:22:28 | 显示全部楼层
是负载电流过大,LDO已经进入by-pass状态了么~~
 楼主| 发表于 2014-4-25 11:08:51 | 显示全部楼层
谢谢   正如上面所说负载电流过大   问题已经解决
 楼主| 发表于 2014-4-25 11:10:01 | 显示全部楼层
回复 3# edgar_a
    请问什么是bypass状态呢,是指管子进入线性区么?
GMT+8, 2025-9-12 15:50 , Processed in 2.174160 second(s), 6 queries , Gzip On, Redis On.
