发表于 2014-4-24 15:53:11
显示全部楼层
Hi Apenper:
If the output cap has a ESR, the LDO is 2 pole and 1 zero system.
At the heavy load, one pole is higher than the zero and other is
closed to low frequency the result is like your picture.
If your compensation is based on an external element (Cout + ESR),
I suggest the zero is in the LDO.
mpig |
