楼主: netshell
[资料] soc encounter8.1安装文件(15MB压缩包版本,节约大家信元!)
发表于 2013-3-9 09:32:02 | 显示全部楼层
LZ,你好:
      安装encounter8.1出现问题,希望lz赐教.
encounter: WARNING: The OA features of encounter are disabled in this
encounter:          session.
encounter:    INFO: Use -debug3264 to get more information about how
encounter:          to activate OA features.
Checking out Encounter license ...
SOC_Encounter_GXL 8.1 license checkout succeeded.
**ERROR: (SOCOAX-148):  Could not open shared library liboax22.so : liboaDesign.so: cannot open shared object file: No such file or directory
**ERROR: (SOCOAX-148):  OA features will be disabled in this session.
启动时候出现的问题,这个如何解决?
 楼主| 发表于 2013-3-9 09:54:23 | 显示全部楼层
回复 261# 歪枣树
   操作系统的问题!
发表于 2013-3-9 11:09:15 | 显示全部楼层
回复 262# wkjatzju
    谢谢了,问题解决了,是我把OA_HOME这个变量设置错了。倒是还有个问题,希望赐教:
**WARN: (SOCLF-102):    Two layers 'M1' and 'V1' specified in
SAMENET spacing rule have different type. To specify a SAMENET
spacing rule between a cut layer and routing layer, the first
one must be a cut layer. The rule is ignored.
**WARN: (SOCLF-102):    Two layers 'M2' and 'V1' specified in
**WARN: (SOCLF-102):    Two layers 'M2' and 'V2' specified in
这是加载std_cell.lef和antenna.lef后出现的问题
 楼主| 发表于 2013-3-26 11:05:20 | 显示全部楼层
回复 263# 歪枣树
    这是你库的原因吧!~
 楼主| 发表于 2013-3-26 19:00:39 | 显示全部楼层
回复 31# chengyh
    你下完了吗?
 楼主| 发表于 2013-5-16 07:59:38 | 显示全部楼层
回复 259# xiaobenyi
    现在解决了吗?
 楼主| 发表于 2013-9-11 14:47:34 | 显示全部楼层
回复 259# xiaobenyi
    后来搞定了吗?
 楼主| 发表于 2013-9-12 15:36:06 | 显示全部楼层
回复 259# xiaobenyi
    are u ok ?
发表于 2013-10-20 23:32:29 | 显示全部楼层
mark先
 楼主| 发表于 2013-10-21 12:48:00 | 显示全部楼层
回复 269# xueyou9469
    完全可用  放心!
GMT+8, 2025-10-28 07:48 , Processed in 0.017309 second(s), 3 queries , Gzip On, Redis On.
