楼主: henry_wangjj
[求助] CTS 优化不下去.
发表于 2011-9-7 00:01:40 | 显示全部楼层
面积不够吧
发表于 2011-9-7 13:12:43 | 显示全部楼层
尝试着做一下网表优化,再看看你的FP 是否合理啊?
发表于 2011-9-7 13:31:42 | 显示全部楼层
2种可能。
1. SDC有问题。
2. Clock Tree是否有问题。
建议先在Opt之前,先报下Timing, Setup 和HOLD。
个人建议是好好关注下HOLD。
发表于 2011-9-7 13:54:48 | 显示全部楼层
icc里能修到100%啊
 楼主| 发表于 2011-9-7 20:58:14 | 显示全部楼层
回复 13# jiancongwoo
    thanks all.
and I check the hold violations, and found one strange things:
the clock network delay is always much bigger in Required path than in Arrival path.  to put it simply:
(1), I set the network delay(network + source = 2ns) in SDC before CTS, but the value of the clock network delay(ideal) is ranged from 5 to 10(before CTS), and the value in RT is much bigger than AT, why?
(2), after CTS the propagated network delay(propagated): values in RT is also much bigger than AT, why ?
thanks in advance.
发表于 2012-10-31 23:29:49 | 显示全部楼层
很有可能是你的uncertainty clock 加在了hold 上面了,而且加的很大吧。
发表于 2016-1-21 14:21:52 | 显示全部楼层
回复 8# icfbicfb
    版主,我做CTS时也遇到类似的问题,placement做完后利用率才65%,但fix hold time后就100%了,我建时钟树和修hold time是分开做的。
查看报告发现,建时钟树时遇到了error:
initializing parameters for clock ate_clk:
root pin: pin/clk_buf_scan/clk_buf/Z
Error: skipping pin pin/clk_buf_scan/clk_buf/Z because it's not on clock network.(CTS-555)
CTS-555的意思是该pin不在clock network上,或者在该pin的fanout路径中的某点被定义了set_case_analysis或者set_disable_timing,
请问这个问题怎么解啊,和前端designer一起debug 1周多了,没找出根源,求版主赐教。
发表于 2016-1-21 14:37:28 | 显示全部楼层
回复 8# icfbicfb
版主,我在cts时也遇到了类似的问题,placement做完后利用率只有65%,但fix hold time后利用率100%了,我建时钟树和fix hold time是分开两步做的。
查看报告,发现在建时钟树时报了一个error:
CTS-555的意思是该pin不在clock network上,或者在该pin的fanout上的某点被set_case_analysis或set_disable_timing了。
请问这个问题怎么解啊,和前端designer一起debug 1周多了,没找出根源,求版主指教!!
GMT+8, 2025-10-30 07:32 , Processed in 0.017331 second(s), 3 queries , Gzip On, Redis On.
