clock source delay 是到你定义的时钟的那个端口之前的时钟延迟,或者说源时钟本身的延迟
确切地英文解释为“Clock source latency is the time it takes for a clock signal to propagate from its actual ideal waveform origin point to the clock definition point in the design. ”
如果不涉及几个源时钟之间的关系,一般不用定义source delay
回复 6#陈涛
涛哥
我在手册上看到Source latency, also known as insertion delay, is the time it
takes for a clock to be propagated from its ideal waveform origin point to the clock definition
那clock insertion delay也就是insertion delay的一部分啦?
