查看: 89|回复: 0
[求助] 哪位大佬帮忙下载一篇论文,谢谢!
发表于 2025-12-1 15:21:32 | 显示全部楼层 |阅读模式
An RC snubber design method to achieve optimized switching noise-loss trade-off of cascode GaN HEMTs
作者:
X Peng、
E Hoene、
P Davari
摘要:
The cascode gallium nitride high electron mobility transistors (GaN HEMTs) are very vulnerable to self-sustained turn-off oscillation due to their cascode configuration. This paper presents a design approach for the RC snubber of cascode GaN HEMTs to achieve the optimized noise-loss trade-off. At first, an analytical model is proposed to describe the instability of cascode GaN HEMTs-based test circuits utilizing RC snubber. Based on the model, an analytical approach is proposed to achieve two optimum RC snubber designs S1 and S2. The design S1 can satisfactorily dampen the oscillation with minimum switching losses. The design S2 achieves maximum effective damping on the oscillation at a minimized cost of additional power losses. In the end, the accuracy of the proposed model is validated by the double-pulse test and good agreement is obtained.
展开
electromagnetic interference; power semiconductor devices; semiconductor device reliability; wide band gap semiconductors
DOI:
10.1049/pel2.12741
年份:
2024
GMT+8, 2025-12-27 09:30 , Processed in 1.167647 second(s), 4 queries , Gzip On, Redis On.
