查看: 376|回复: 0
[其它] Materialise Mimics Core (Medical) 2026 v28.0 +3-matic v20.0
发表于 2025-11-11 10:26:17 | 显示全部楼层 |阅读模式
Materialise Mimics Core with 3-matics move from 3D medical image data to 3D modeling efficiently and accurately. Mimics Core’s unmatched virtual procedure planning capabilities allow you to manage even the most uncommon patient cases and challenging image data.
Features in v28.0
Effective anatomy segmentation
Combine AI-enabled automated tools with smart editing tools to obtain accurate 3D models.
Accurate anatomy analysis
Identify landmarks and analyze the anatomy with an extensive set of 3D measurement tools.
Virtual procedure planning
Visualize different procedure scenarios for improved understanding. Virtually position devices to fully grasp the anatomical fit.
Workflow automation
Use Python scripting to automate repetitive steps, making you more efficient and reducing the learning curve for colleagues.
Seamless connection with Materialise Mimics
Experience seamless cloud-desktop integration throughout the full Mimics platform, allowing you to save, share, access AI-enabled segmentations, or view your model in XR from anywhere.
Smooth design software integration
Seamlessly transfer accurate patient anatomy and planning to the 3-matic Medical design environment, or move your patient-specific design into Mimics to compare it to your original patient images.
Design personalized devices and desktop models
Design anatomical models, guides, and implants directly on the anatomy using an extensive range of STL design tools.
Prepare for FEA, FEM, or CFD simulations
Create highly detailed surface and volume meshes and smoothly export to a wide range of FEA, FEM, and CFD solvers.
Verify device design and fit
Perform virtual implantations, anatomical studies, complex 3D measurements, and entire population analyses.
Prepare your 3D model for printing
Add labels, connectors, and more to your design, then ensure printability with easy and robust fixing tools.
Seamless connection with Mimics Flow
Experience seamless cloud-desktop integration throughout the full Mimics platform, allowing you to save, share, or view your model in XR from anywhere.
Smooth Mimics Core integration
Seamlessly transfer detailed patient anatomy and planning to the design environment, or move your patient-specific design into Mimics to compare it to your original patient images.
28最新版更新 可以直接联系1739083603@qq.com
GMT+8, 2025-12-28 06:11 , Processed in 0.013546 second(s), 4 queries , Gzip On, Redis On.
