查看: 490|回复: 1
[其它] SuperPro Designer 14 Build 2025 Fixed
发表于 2025-10-7 12:26:31 | 显示全部楼层 |阅读模式
SuperPro Designer是工程师和科学家在过程开发,过程工程和生产中的宝贵工具。SuperPro Designer软件可以促进各行各业(药房,生物技术,专业化学,食品,消费品,矿物加工,微电子,水处理,废水处理,空气污染控制等)的集成过程的建模,评估和优化。 )是。它也是环境专业人员的宝贵而有用的工具(例如,废水处理,空气污染控制,废物最小化,污染预防)。
SuperPro Designer软件的特点和功能:
  • 设备尺寸和成本
  • 包含精密反应器模块
  • 物质平衡和能量平衡
  • 环境影响评估
  • 批量操作计划
  • 流量和故障分析
  • 广泛的设备和资源数据库
  • 广泛的化学成分和混合数据库
  • 撤消/重做选项并恢复到以前的状态
  • 包括超过140个单元/操作方法的模型
  • 通过添加图形和文本进行PFD自定义
  • 跟踪资源(公用事业,原材料和劳动力)作为时间的函数
  • 兼容各种图形,电子表格和文字处理软件包
  • 具有一组用于快速共享任务的键盘快捷键
  • 选择以DXF格式(加入AutoCAD)和WMF格式导出PFD
  • 更灵活的选项,用于描述如何计算构图和数量的初始内容
  • 能够为具有自定义访问级别的模拟文件创建受密码保护的版本
SuperPro Designer facilitates modeling, evaluation and optimization of integrated processes in a wide range of industries (Pharmaceutical, Biotech, Specialty Chemical, Food, Consumer Goods, Mineral Processing, Microelectronics, Water Purification, Wastewater Treatment, Air Pollution Control, etc.). The combination of manufacturing and environmental operation models in the same package enables the user to concurrently design and evaluate manufacturing and end-of-pipe treatment processes and practice waste minimization via pollution prevention as well as pollution control.
SuperPro Designer is a valuable tool for engineers and scientists in process development, process engineering, and manufacturing. It is also a valuable tool for professionals dealing with environmental issues (e.g., wastewater treatment, air pollution control, waste minimization, pollution prevention). SuperPro provides under a single umbrella modeling of manufacturing and end-of-pipe treatment processes, project economic evaluation, and environmental impact assessment
Key Features of SuperPro Designer:
  • Models for over 140 unit procedures / operations.
  • Rigorous reactor modules.
  • Material and energy balances.
  • Extensive chemical component and mixture database.
  • Extensive equipment and resource databases.
  • Equipment sizing and costing.
  • Thorough process economics.
  • Scheduling of batch operations.
  • Throughput Analysis and Debottlenecking.
  • Resource (utilities, raw materials, and labor) tracking as a function of time.
  • Waste stream characterization.
  • Environmental impact assessment
  • OLE-2 support.
  • PFD customization through addition of your own graphics and text.
  • Compatibility with a variety of graphics, spreadsheet, and word processing packages.
  • Option to export PFDs in DXF format (for incorporation into Autodesk AutoCAD) and in WMF format.
  • 需要SuperPro Designer v14 Build 2025联系3766906032@qq.com
发表于 2025-10-7 14:43:01 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-10-18 10:24 , Processed in 0.994368 second(s), 6 queries , Gzip On, Redis On.
