使用的是Cyclone III,EP3C25F324C6
 在分配完引脚后,发生错误,说D1,E2,H3三个脚不能分配
 如下:
 Error: Can't place pins assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
 Info: Pin flash_data[1] is assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
 Info: Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
 Error: Can't place pins assigned to pin location Pin_E2 (IOPAD_X0_Y25_N0)
 Info: Pin flash_nce is assigned to pin location Pin_E2 (IOPAD_X0_Y25_N0)
 Info: Pin ~ALTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_E2 (IOPAD_X0_Y25_N0)
 Error: Can't place pins assigned to pin location Pin_H3 (IOPAD_X0_Y22_N7)
 Info: Pin flash_data[0] is assigned to pin location Pin_H3 (IOPAD_X0_Y22_N7)
 Info: Pin ~ALTERA_DATA0~ is assigned to pin location Pin_H3 (IOPAD_X0_Y22_N7)
 Error: Can't fit design in device
 Error: Quartus II Fitter was unsuccessful. 4 errors, 3 warnings
 Info: Allocated 185 megabytes of memory during processing
 Error: Processing ended: Mon Mar 10 15:42:55 2008
 Error: Elapsed time: 00:00:04
            error   |
