查看: 1239|回复: 14
[原创] Emre Salman_2012_High Performance Integrated Circuit Design
发表于 2025-9-21 14:31:35 | 显示全部楼层 |阅读模式
The latest techniques for designing robust, high performance integrated circuits in nanoscale technologies Focusing on a new technological paradigm, this practical guide describes the interconnect-centric design methodologies that are now the major focus of nanoscale integrated circuits (ICs). High Performance Integrated Circuit Design begins by discussing the dominant role of on-chip interconnects and provides an overview of technology scaling. The book goes on to cover data signaling, power management, synchronization, and substrate-aware design.
Specific design constraints and methodologies unique to each type of interconnect are addressed. This comprehensive volume also explains the design of specialized circuits such as tapered buffers and repeaters for data signaling, voltage regulators for power management, and phase-locked loops for synchronization. This is an invaluable resource for students, researchers, and engineers working in the area of high performance ICs.
Coverage includes:
  • Technology scaling
  • Interconnect modeling and extraction
  • Signal propagation and delay analysis
  • Interconnect coupling noise
  • Power generation
  • Power distribution networks
  • CAD of power networks
  • Techniques to reduce power supply noise
  • Power dissipation
  • Synchronization theory and tradeoffs
  • Synchronous system characteristics
  • On-chip clock generation
  • Clock distribution networks
  • Substrate noise in mixed-signal ICs
  • Techniques to reduce substrate noise
          From the Publisher   Eby G. Friedman, Ph.D., is Distinguished Professor of Electrical and Computer Engineering at University of Rochester.
Emre Salman, Ph.D., is a research assistant at High Performance VLSI/IC Design and Analysis at the University of Rochester.
         About the Author   Emre Salman Received the B.S. degree in microelectronics engineering from Sabancı University, Istanbul, Turkey, in 2004, and the M.S. and Ph.D. degrees in electrical engineering from the University of Rochester, New York, in, respectively, 2006 and 2009. Between May 2009 and September 2010, he worked as a postdoctoral research associate at the University of Rochester. He also worked and conducted research at STMicroelectronics, Synopsys, and Freescale Semiconductor. Since September 2010, he has been an Assistant Professor with the Department of Electrical and Computer Engineering, Stony Brook University, New York, where he is the director of the Nanoscale Circuits and Systems (NanoCAS) Laboratory. His broad research interests include analysis, modeling, and design methodologies for nanoscale integrated circuits in both 2-D and 3-D technologies.
Eby G. Friedman: Received the B.S. degree from Lafayette College in 1979, and the M.S. and Ph.D. degrees in electrical engineering from the University of California, Irvine, in, respectively, 1981 and 1989. From 1979 to 1991, he was with Hughes Aircraft Company, rising to the position of manager of the Signal Processing Design and Test Department. He has been with the Department of Electrical and Computer Engineering at the University of Rochester since 1991, where he is a Distinguished Professor. He is also a Visiting Professor at the Technion - Israel Institute of Technology. He is the author of about 400 papers and book chapters, 11 patents, and the author or editor of 15 books in the fields of  high speed and low power CMOS design techniques, 3-D design methodologies, high speed interconnect, and the theory and application of synchronous clock and power distribution networks.
Emre Salman_2012_High Performance Integrated Circuit Design.pdf
33.07 MB, 下载次数: 428 , 下载积分: 资产 -10 信元, 下载支出 10 信元
发表于 2025-9-21 14:54:16 | 显示全部楼层
感謝囉!!!
发表于 2025-9-21 16:11:39 | 显示全部楼层
发表于 2025-9-21 16:48:52 | 显示全部楼层
多谢分享。。
 楼主| 发表于 2025-9-21 22:31:25 | 显示全部楼层
solaris 发表于 2025-9-21 16:11
高性能集成电路设计
之前找了好久才找到,没想到论坛就有,还有中文版的,感谢分享
发表于 2025-9-22 02:55:09 | 显示全部楼层
Thanks!!!
发表于 2025-9-22 08:34:22 | 显示全部楼层
Thanks for sharing.
发表于 2025-9-22 09:10:14 | 显示全部楼层
感谢楼主分享
发表于 2025-9-22 09:27:33 | 显示全部楼层
GOOOOOOOOOOOOOOOOOOD
发表于 2025-9-22 10:52:16 | 显示全部楼层
谢谢分享
GMT+8, 2025-11-7 03:18 , Processed in 0.023638 second(s), 5 queries , Gzip On, Redis On.
