查看: 310|回复: 1
[求助] 对于data input的timing value 在k库的时候,有没有什么方法覆盖table里value这些数值的关系
发表于 2025-8-18 14:58:18 | 显示全部楼层 |阅读模式
timing() {
                                                        related_pin :   "CE2" ;
                                                        timing_type : hold_rising ;
                                                        rise_constraint ("vio_7_7_1") {
        index_1("0.0160000, 0.0320000, 0.0640000, 0.1280000, 0.2560000, 0.5120000, 1.0240000");
        index_2("0.0160000, 0.0320000, 0.0640000, 0.1280000, 0.2560000, 0.5120000, 1.0240000");
        values("0.2520141, 0.2482756, 0.2380105, 0.2170922, 0.1956920, 0.1645749, 0.1261529", \
        "0.2555891, 0.2518057, 0.2445799, 0.2238562, 0.2002855, 0.1687571, 0.1296817", \
        "0.2630017, 0.2591888, 0.2519638, 0.2338413, 0.2073209, 0.1788179, 0.1374900", \
        "0.2779553, 0.2740430, 0.2673261, 0.2491905, 0.2255872, 0.1942150, 0.1518390", \
        "0.2963432, 0.2919543, 0.2871788, 0.2666807, 0.2449978, 0.2087459, 0.1727115", \
        "0.3260859, 0.3194851, 0.3121788, 0.2987110, 0.2731418, 0.2432291, 0.2056704", \
        "0.3775021, 0.3755781, 0.3447398, 0.3278961, 0.2963093, 0.2742061, 0.2342027");
                                                        fall_constraint ("vio_7_7_1") {
        values("0.2696844, 0.2658401, 0.2583355, 0.2406600, 0.2131670, 0.1709800, 0.1055141", \
        "0.2760529, 0.2723896, 0.2618369, 0.2442408, 0.2206950, 0.1772781, 0.1119739", \
        "0.2834954, 0.2798614, 0.2723489, 0.2549268, 0.2281913, 0.1846821, 0.1195795", \
        "0.2984466, 0.2950371, 0.2874408, 0.2695178, 0.2422088, 0.1997601, 0.1344417", \
        "0.3161500, 0.3125073, 0.3047939, 0.2861663, 0.2595814, 0.2170820, 0.1503297", \
        "0.3435299, 0.3400524, 0.3332431, 0.3221172, 0.2906871, 0.2493294, 0.1705775", \
        "0.4015371, 0.3727228, 0.3777759, 0.3478880, 0.3175033, 0.2846746, 0.2140401");
对于data input的timing value 在k库的时候,有没有什么方法覆盖table里value这些数值的关系,这些数据是一个点一个点仿出来的,很耗时,如果有一个大概方法可以覆盖这些数值的关系 是不是就可以节省很多时间了?
 楼主| 发表于 2025-8-18 17:22:15 | 显示全部楼层
请有想法的佬们在悬赏贴那边回复,我不知道这个咋删除
GMT+8, 2025-10-22 17:34 , Processed in 0.014082 second(s), 4 queries , Gzip On, Redis On.
