查看: 507|回复: 0
[转贴] CALPUFF View 10.0 完美最新
发表于 2025-8-3 11:45:30 | 显示全部楼层 |阅读模式
CALPUFF View provides a complete graphical solution for the CALPUFF modeling system: CALPUFF, CALMET, CALPOST, and their related pre- and post-processors. CALPUFF View includes powerful and independent QA tools, stunning report-ready results, and a wide range of visualization optionsCALPUFF is a multi-layer, multi-species non-steady-state puff dispersion model which simulates the effects of time-and space-varying meteorological conditions on pollution transport, transformation, and removal.CALPUFF can be applied to a wide variety of scenarios including far-field impacts (those beyond 50km from releases) which cannot be modeled with traditional plume models (e.g., AERMOD). Its three-dimensionally varying meteorological field makes it useful for regions with very complex terrain or non-steady-state conditions. CALPUFF View’s wide range of features make it easy to execute the entire suite of pre- and post-processors for a modeling analysis
Features of CALPUFF View :
  • Increase your processing capability! CALPUFF View can utilize multiple cores when running the CALMET model to generate model data faster than ever before.
  • Fully integrated GIS-based interface combining easy-to-use graphical tools for drawing sources, buildings, and receptors; seamless model run execution; and automated contouring and posting of results.
  • This software allows you to play and record plume animations along with your wind field.
  • This software allows you to export your buildings, sources, receptors, and contours into Google Earth giving you a more realistic image of where your pollutants will impact surrounding areas.
  • Using the export to Google Earth feature, you can quickly and easily see where your puff will impact. The play feature shows how your puff disperses over time.
System Requirements
Operating system
Windows 10 / 11
CPU
1 GHz or faster processor
RAM
2 GB of RAM (4 GB recommended)
Hard Disk
At least 20 GB of available hard disk space
联系3766906032@qq.com
GMT+8, 2025-12-21 15:25 , Processed in 0.013862 second(s), 4 queries , Gzip On, Redis On.
