查看: 663|回复: 3
[求助] dc综合时使用28nm的台积电工艺出现以下错误
发表于 2025-7-11 19:04:24 | 显示全部楼层 |阅读模式
最近写了个乘法器,想用dc进行综合一下,
但总是出现这样的错误
Error: The target library does not contain all required gates.
Either a NOR, or an AND and an OR gate (two-input) is required for mapping. (OPT-102)
Error: Compile has abnormally terminated.  (OPT-100)
有没有大佬指点一下啊,感谢
这是我的指令
set folder_path "/home/cy/product/test"
set verilog_files [glob -nocomplain "${folder_path}/*.v"]
foreach file $verilog_files {
    puts "正在读取 Verilog 文件: $file"
    read_verilog $file
current_design Top_booth_1
set_app_var target_library ../library/tcbn28hpcplusbwp40p140cgcwffg0p99v0c.db
set_app_var link_library ../library/tcbn28hpcplusbwp40p140cgcwffg0p99v0c.db
link
create_clock "clk" -period 14
set_clock_uncertainty -setup 0.15 [get_ports clk]
set_clock_transition 0.12 [get_clocks clk]
write_sdc test.sdc
write_sdf test.sdf
write_file -format verilog -output netlist.v
发表于 2025-7-11 23:01:44 | 显示全部楼层
用这个:tcbn28hpcplusbwp7t40p140 试一下
你挂的那个 *cg*,应该是一套低功耗Cell库的。
 楼主| 发表于 2025-7-12 14:04:30 | 显示全部楼层
谢谢您的指点,我去试一下
 楼主| 发表于 2025-7-12 14:15:09 | 显示全部楼层
我换了个库,还真解决了,谢谢大哥,下次应该提前看看库文件里有没有标准单元库
GMT+8, 2025-11-18 08:59 , Processed in 0.237582 second(s), 4 queries , Gzip On, Redis On.
