查看: 913|回复: 1
[求助] 请问这是电源接的不对吗?具体是哪方面的问题呀
发表于 2025-7-7 21:51:19 | 显示全部楼层 |阅读模式
Warning: #1 in OSC
WARNING:  Short circuit - Different names on one net:
          Net Id:  4
          (1)  name  "VDD"  at location  (-82.245,24.22)  on layer  144
          (2)  name  "VDD"  at location  (-82.245,43.045)  on layer  144
          (3)  name  "VSS"  at location  (-82.09,43.065)  on layer  144
          The name "VDD" was assigned to the net.
Warning: #2 in OSC
WARNING:  Open circuit - Same name on different nets:
          (1)  at location  (-89.16,14.815)  on layer  144  on net id  2
          (2)  at location  (-89.16,33.64)  on layer  144  on net id  2
          (3)  at location  (-82.245,24.22)  on layer  144  on net id  4
          (4)  at location  (-82.245,43.045)  on layer  144  on net id  4
          The name was assigned to net 2 .
Warning: #3 in OSC
WARNING: Top level port name "VDD" on net 4 at location (-82.245,24.22) already used on net 2; ignored.
Warning: #4 in OSC
WARNING: Top level port name "VDD" on net 4 at location (-82.245,43.045) already used on net 2; ignored.
Warning: #5 in OSC
WARNING: Invalid PATHCHK request "GROUND && ! POWER": no GROUND nets present, operation aborted.
Warning: #6 in OSC
WARNING: Invalid PATHCHK request "POWER && ! GROUND": no GROUND nets present, operation aborted.
Warning: #7 in OSC
WARNING: Invalid PATHCHK request "! POWER && ! GROUND": no GROUND nets present, operation aborted.
发表于 2025-7-8 09:21:43 | 显示全部楼层
lvs options 里面有个short ,打开这个可以看你的short发生在哪里。
GMT+8, 2025-12-21 06:21 , Processed in 0.044401 second(s), 5 queries , Gzip On, Redis On.
