查看: 8952|回复: 34
[资料] TCAS Ⅰ&Ⅱ 6月份合集
发表于 2025-6-2 15:34:03 | 显示全部楼层 |阅读模式
2025年6月份合集
IEEE Transactions on Circuits and Systems I: Regular Papers
IEEE Transactions on Circuits and Systems II: Express Briefs
(txt文件为百度网盘链接,请勿重复下载)
仅供学习交流,请勿商用
压缩包为整个期刊的pdf合集
或选取下方百度网盘链接
TCAS 1
REGULAR PAPERS
Analog and Mixed Mode Circuits and Systems
Systematic Design of a 3.5 GS/s 11-bit Time-Interleaved SAR ADC in 28 nm CMOS Achieving 54 dB SNDR at Nyquist
Frequency .............................................................................. S. Liu, Y. Tian, C. Sun, G. Li, H. Xu, and N. Yan 2483
Kolmogorov–Arnold Networks-Based Calibration for Single-Channel ADCs: High-Precision Nonlinear Code Synthesis With Low
Power Consumption ..............................................................................................................................
........................ Y. Peng, X. Peng, H. Wang, D. Fu, Y. Ni, C. Zhu, B. Zhang, L. Chen, Z. Hu, Z. Lu, H. Tang, and M. Guo 2497
Topkima-Former: Low-Energy, Low-Latency Inference for Transformers Using Top-k In-Memory ADC ..............................
.............................................................. S. Dong, J. Yang, X. Peng, H. Shang, Y. Ke, X. Yang, H. Liu, and A. Basu 2509
A Dual Slope Boosted Relaxation Oscillator With 2.93 μJ/Cycle Energy Efficiency and 0.068% Period Jitter in 180 nm
CMOS ......................................................................................... Y. Shi, X. Liu, C. Hu, X. Tang, and J. Jiang 2520
Low-Power Subthreshold Voltage References for High-Temperature Applications .............................. Y. Ji, Y. Li, and I. Lee 2529
Design of Oscillator-Based Reconfigurable Modulator With High-Q FBAR Resonators Supporting Fast OOK/BFSK/ BPSK
Modulation .................................. D. Liang, H. Zhang, Y. Wang, L. Ma, S. Ma, Z. Zhou, F. Meng, K. Ma, and K. Wang 2543
A 16-Channel Neurostimulation IC With Self-Biased Monopolar Stimulus Drivers and a Multiple-Output Charge-Pump Converter
Achieving 25.44-mW/mm2 Power Density in Low-Voltage CMOS ........ P. Han, Y. Ding, D. He, X. Guo, S. Wu, and H. Lyu 2556
Design and Application of Brain-Inspired Circuit With Context-Dependent and State-Dependent Memory ............................
...................................................................................................... G. Dou, D. Li, M. Guo, and H. H.-C. Iu 2566
Super-Regenerative Reception Technique Based on an Improved General Theory in Linear Mode ......................................
.............................................................................................. J. Liu, G. Feng, Y. Wu, F. Meng, and X. Zhang 2578
A High-Efficiency RFEH System With Feedback-Free Fast (F3) MPPT Over a Wide Input Range ....................................
................................................................................. X. Liao, Y. Zhang, Y. Zhang, S. Zhang, Z. Zhu, and L. Liu 2592
A Compact 321–343-GHz Integrated CMOS Radiator by Co-Designing Ring Oscillator and Multifunctional Antenna ..............
............................................................................................................ J. Yang, Y. Shen, Z. Wei, and S. Hu 2603
A 24–32 GHz Bidirectional Variable-Gain Phase Shifter Using a Novel Quadrature Generator and Dual-Function Bidirectional
Amplifier With Phase Compensation ............................... K. Long, T. Xu, H. Zhu, S. Deng, P. Qin, W. Che, and Q. Xue 2614
Input Phase Controlled Doherty Power Amplifier With Out-Phased Current Load Modulation for Arbitrary Output Back-Off .....
........................................................................... B. H. Zeng, Y. F. Pan, F. C. Yuan, W. S. Chan, and S. Y. Zheng 2626
Design and Analysis of Passive-Integrated Absorptive Flat-Group-Delay RF Bandpass Filters in GaAs Technology for Digital
Communications ................................................................... N. Iranpour, L. Yang, R. Gómez-García, and X. Zhu 2639
A VM-Terminated PAM-3 Transmitter Using Floating Middle Level With Enhanced Signal Integrity and Energy Efficiency for
Low-Power Memory Interfaces .......................................................... C. Han, K.-S. Lee, J.-C. Lee, and J.-H. Chae 2653
A 0.92-pJ/b 112-Gb/s PAM-4 Transmitter With Bandwidth and Linearity Enhanced Quasi-Voltage-Mode Driver and Reconfigurable
Three-Tap T/2–T Variable Fractional-Spaced FFE in 28-nm CMOS .... K. Wang, R. Tang, S. Xiang, Y. He, Y. He, and X. Gui 2664
Digital Circuits and Systems and VLSI
A Neuromorphic Transformer Architecture Enabling Hardware-Friendly Edge Computing ...............................................
.................... P. J. Zhou, R. C. Ma, Y. C. Chen, Z. T. Liu, C. Y. Liu, L. W. Meng, G. C. Qiao, Y. Liu, Q. Yu, and S. G. Hu 2676
An Investigation on the Three-Dimensional Memristive Morris–Lecar Model With Magnetic Induction Effects: Simulation of
Biological Behaviors and Cost-Effective Digital Circuit Implementation .................................................................
.................................................................................. J. Sun, H. Chen, X. Ji, G. Zhang, C. Wang, and X. Miao 2690
Adaptive Neural Control of Superheated Steam System in Ultra-Supercritical Units With Output Constraints Based on Disturbance
Observer ................................................................................ Z. Zhou, J. Zhang, Y. Wang, D. Yang, and Z. Liu 2701
SHMT: An SRAM and HBM Hybrid Computing-in-Memory Architecture With Optimized KV Cache for Multimodal
Transformer ...................................................................... X. Fu, J. Yue, M. Faizan, Z. Li, Q. Huo, and F. Zhang 2712
A Novel Transform Accelerator With Fast Kernel Selection and Efficient Transform Circuit ............................................
....................................................................... Z. Hao, C. He, J. Liu, Q. Zheng, J. Xu, P. Ma, X. Ma, and Y. Hao 2726
MINA: A Hardware-Efficient and Flexible Mini-InceptionNet Accelerator for ECG Classification in Wearable Devices ............
.................................................................................... H. L. Pham, T. D. Tran, V. T. D. Le, and Y. Nakashima 2740
Ultra-High Efficiency TRNG IP Based on Mesh Topology of Coupled-XOR ...............................................................
............................................................................ Y. Lu, E. Xu, Y. Liu, J. Chen, H. Liang, Z. Huang, and L. Yao 2754
Nonlinear Circuits and Systems
Bursting Oscillations Induced by the Variable Discontinuous Boundary in Chua’s Circuit ...............................................
............................................................................................ W. Zuo, Y. Zhang, J. Song, Y. Zhu, and Z. Zhang 2768
Modeling and Nonlinear Dynamic Behavior Analysis of Photovoltaic-Energy Storage DC Microgrid ..................................
................................................................................. R. Wang, F. Xie, B. Zhang, D. Qiu, W. Xiao, and Y. Chen 2778
Dynamic Nonlinear Resistance Model for a Power MOSFET in an Oscillatory RLC Circuit ............................................
................................................................................... S. Raju, D. A. Steyn-Ross, M. Wilson, and N. Kularatna 2792
Computer Aided Design and Electronic Design Automation
Circuit Transfer Matrix: A Novel Approach to Enhancing Circuit Analysis Efficiency by Extending the Transfer Matrix Method
for Multibody System ..................................................................................... Z. Jin, X.-T. Rui, and F.-F. Yang 2804
Inductive GNN-Based Methodology for Accurate and Fast Average Power Estimation of Synthesized ASIC Designs From RTL
Simulation Bypassing Gate-Level Simulation ............................ M. B. Rakesh, P. Das, K. R. S. Pranav, and A. Acharyya 2818
Control Theory and Systems
Adaptive Switching Control for Nonlinear Uncertain Systems With Sensor Faults and Quantization .... X. Jia, S. Xu, and G. Cui 2832
A Novel Approach to Prescribed-Time Cooperative Output Regulation in Linear Heterogeneous Multi-Agent Systems Using Cascade
System Criteria .......................................................................... G. Zuo, L. Zhu, Y. Wang, Z. Chen, and Y. Song 2842
A Novel Feasibility Condition-Free Approach for Achieving Desired Precision and Unified Performance Within Prescribed
Time ................................................................... M. Golestani, Y. Song, T. Liu, X. Xu, G.-R. Duan, and H. Kong 2856
Generalized Discrete-Time Variable Gain ADRC for Nonlinear Systems and Its Application to Parallel Teleoperated
Manipulators ........................................................................................ S. Gu, J. Zhang, L. Cheng, and Y. Wu 2868
Stabilization of Markov Jump Systems With Delay by Discrete-Time Aperiodically Intermittent Stochastic Control Based on Lévy
Noise ................................................................................................. X. Liu, P. Cheng, F. Deng, and T. Cai 2878
Data-Driven Attack Detection and Identification for Cyber-Physical Systems Under Sparse Sensor Attacks: Iterative Reweighted
l2/l1 Recovery Approach ........................................................................................... J.-L. Wang and X.-J. Li 2890
Data-Based Output Containment of Completely Heterogeneous Multi-Agent Systems With Unknown Dynamics and Its
Application ........................................................................... S. Huo, Z. Wang, H. Shen, Y. Zhang, and C. Deng 2903
Fixed-Time Generalized VGESO-Based Trajectory Tracking Control for WMRs on Uneven Road: A Fully Actuated System
Approach ..................................................................................... J. Qiang, L. Li, C. Hua, X. Ren, and C. Liu 2915
Power Systems and Electronic Circuits
A Consistency Enhancement Technique for MIMO Power Amplifier Modules .............................................................
.................................................................................... Z. Li, Z. Dai, Z. Liu, W. Shi, J. Pang, S. Hu, and M. Li 2928
A Unified Sampled-Data Small-Signal Model for a Ripple-Based COT Buck Converter With Arbitrary Ripple Injection
Network ................................ F. Gabriele, A. Carlucci, D. Lena, F. Pareschi, R. Rovatti, S. Grivet-Talocia, and G. Setti 2942
A Single-Input Multi-Output Resonant Regulating Rectifier Generating Three Outputs in a Half Cycle for Wirelessly Powered
Biomedical Devices .................................................................................... H.-S. Lee, K. Eom, and H.-M. Lee 2956
Impedance Circuit Model of Voltage Source Converter With DC-Link Voltage Control Dynamics ......................................
........................................................................................................ Z. Wang, P. Cheng, H. Pan, and L. Jia 2970
TCAS 2
REGULAR PAPERS
A Dual-Core Dual-Mode DCO for S/C-Band Radar . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . C. Wan, X. Luo, S. Deng, B. Dong, Z. Lu, Y. Wang, S. Wang, Q. Xue, and Y. Zheng 808
A 22.5∼28.5-GHz Low-Amplitude-Variation Low-Phase-Error Hybrid Phase Shifter Using Flatness Enhancement Techniques
for 5G NR in 40-nm CMOS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . S. Zheng, Y. Wang, Z. Deng, C. Jiang, and H. Xu 813
Circuits and Systems for Communications
A 0.62-pJ/Bit 60-GHz OOK Receiver With Supply Interference Tolerance for Short-Range Interconnects . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . J. Liu, Y. Wu, G. Feng, R. Liu, S. Li, C. Hu, and X. Zhang 818
Preassigned-Time Sliding-Mode Control of Chaotic Memristive Neural Networks With Time-Varying Delays . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . G. Gao, H. Ge, G. Wang, and L. Wang 823
Neural-Learning-Based Adaptive Sliding Mode Impedance Force Control of Robotic Microinjection Systems Interacting With
Viscoelastic Cells . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . S. Kang, T. Li, X. Yang, Y. Li, and M. Xie 828
Clock Edge Triggering Control in Topology-Based Logic Dynamic Systems Using Matrix Approaches . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Jia, J. Hu, Y. Li, P. Guo, Q. Xu, A. Luo, and A. Tayebi 833
Design and Application of Mean and Square Root Circuits for Stochastic Computing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . S. Wang, K. Shi, Y. Xu, Y. Wang, and Y. Zhang 838
Low-Area-Cost VLSI Architecture of Fault-Aware High-Reliability Triple-Mode Polar Decoder Chip Reconfiguring SC and SCL
Decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X.-Y. Shih, D.-L. Wu, and W.-L. Chang 843
A 40 TOPS Single-Chip Accelerator Enabling Low-Latency Inference for Deep Neural Networks . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X. He, T. Cao, Y. Liu, L. Zhong, G. Xiao, and C. Yu 848
Virtual-Synchronizer-Based Current Sharing Scheme in m-Phase Resonant DC-DC Converters System . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . K. Liu, T. Xiao, P. Chen, W. Chen, and J. Zhao 853
A New Variant of Turns-Ratio Independent Shoot-Through Current-Based Magnetically-Coupled Z-Source InverterWith Smooth
DC-Link Voltage and Enhanced High-Gain . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . S. Konar, P. K. Gayen, and S. S. Saha 858
An Optimized PWMPattern for Three-Phase Current Source RectifierWith Fault-Tolerant of Short-Circuit in Bridge Legs . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Q. Chen, R. Ma, R. Yin, X. Zhang, and M. Ma 863
Signal Processing
SSPP Transmission System With Negative Group Delay and Power Compensation . . . . . . . . . . . . . . . . . G. Lu, Q. Kang, and W. Li 868
1
1
2
2
Circuits_and_Systems_I_Regular_Papers_IEEE_Transactions_on_-_Volume_72_-_Issue_6.part1.rar
30 MB, 下载次数: 174 , 下载积分: 资产 -9 信元, 下载支出 9 信元
Circuits_and_Systems_I_Regular_Papers_IEEE_Transactions_on_-_Volume_72_-_Issue_6.part2.rar
30 MB, 下载次数: 189 , 下载积分: 资产 -9 信元, 下载支出 9 信元
Circuits_and_Systems_I_Regular_Papers_IEEE_Transactions_on_-_Volume_72_-_Issue_6.part3.rar
30 MB, 下载次数: 175 , 下载积分: 资产 -9 信元, 下载支出 9 信元
Circuits_and_Systems_I_Regular_Papers_IEEE_Transactions_on_-_Volume_72_-_Issue_6.part4.rar
30 MB, 下载次数: 181 , 下载积分: 资产 -9 信元, 下载支出 9 信元
Circuits_and_Systems_I_Regular_Papers_IEEE_Transactions_on_-_Volume_72_-_Issue_6.part5.rar
13.84 MB, 下载次数: 167 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Circuits_and_Systems_II_Express_Briefs_IEEE_Transactions_on_-_Volume_72_-_Issue_.rar
30 MB, 下载次数: 163 , 下载积分: 资产 -9 信元, 下载支出 9 信元
2.22 MB, 下载次数: 137 , 下载积分: 资产 -2 信元, 下载支出 2 信元
TCAS2506.txt
121 Bytes, 下载次数: 59 , 下载积分: 资产 -2 信元, 下载支出 2 信元
售价: 30 信元资产  [记录]
百度网盘链接
Table_of_Contents Ⅰ.pdf
86.13 KB, 下载次数: 52 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Table_of_Contents Ⅱ.pdf
346.11 KB, 下载次数: 37 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2025-6-3 04:40:40 | 显示全部楼层
Thanks for the share
发表于 2025-6-3 10:02:18 | 显示全部楼层
花费巨资。。。
发表于 2025-6-3 10:47:01 | 显示全部楼层
thanks
发表于 2025-6-3 17:49:32 | 显示全部楼层
感谢分享
发表于 2025-6-3 20:06:12 | 显示全部楼层
多谢分享
发表于 2025-6-3 20:23:39 | 显示全部楼层
thanks!
发表于 2025-6-4 01:31:38 | 显示全部楼层
thank
发表于 2025-6-4 10:44:33 | 显示全部楼层
谢谢分享
发表于 2025-6-4 17:34:02 | 显示全部楼层
感谢分享
GMT+8, 2025-12-27 11:25 , Processed in 0.022298 second(s), 7 queries , Gzip On, Redis On.
