查看: 909|回复: 2
[求助] IC Compiler II Workshop遇到的问题
发表于 2025-5-18 23:08:53 | 显示全部楼层 |阅读模式
本人后端小白,在做IC Compiler II: Block-level Implementation Workshop的lab1中的Task 7. Timing Analysis时候,
给出了很多警告信息,然后时序分析全红。请问如何解决?
用的2022年版本的ICC2.
ICC-II-BLI-201903-LG.pdf (2.84 MB , 下载次数: 27 )
我运行的结果
Warning: Technology layer 'M1' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M2' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M3' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M4' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M5' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M6' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M7' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M8' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'M9' setting 'routing-direction' is not valid (NEX-001)
Warning: Technology layer 'MRDL' setting 'routing-direction' is not valid (NEX-001)
Warning: no valid parasitic for ss_125c corner(LATE) (NEX-018)
Warning: no valid parasitic for ss_125c corner(EARLY) (NEX-018)
Warning: no valid parasitic for ff_125c corner(LATE) (NEX-018)
Warning: no valid parasitic for ff_125c corner(EARLY) (NEX-018)
Warning: no valid parasitic for ff_m40c corner(LATE) (NEX-018)
Warning: no valid parasitic for ff_m40c corner(EARLY) (NEX-018)
发表于 2025-5-19 09:38:22 | 显示全部楼层
好的,学习到了
发表于 2025-10-15 10:19:48 | 显示全部楼层
好的,学习到了
GMT+8, 2025-12-3 17:07 , Processed in 0.015279 second(s), 6 queries , Gzip On, Redis On.
