查看: 967|回复: 9
[资料] FPGA-Based Embedded System Developer's Guide 2018
发表于 2025-5-15 08:34:02 | 显示全部楼层 |阅读模式
Description:
The book covers various aspects of VHDL programming and FPGA interfacing with examples and sample codes giving an overview of VLSI technology, digital circuits design with VHDL, programming, components, functions and procedures, and arithmetic designs followed by coverage of the core of external I/O programming, algorithmic state machine based system design, and real-world interfacing examples.
Unique Features of the Book:
This book is a digital system design and hardware interfacing text. VHDL synthesis and simulation software are used as tools to realize the intended designs.
• Focus on real-world applications and peripherals interfacing for different applications like data acquisition, control, communication, display, computing, instrumentation, digital signal processing and top module design
• Aims to be a quick reference guide to design digital architecture in the FPGA and develop system with RTC, data transmission protocols
•A new approach is used to explain the very-large-scale integration (VLSI) technology, VHDL-based real-world applications and system generator–assisted top-level designs.
•The suggested coding style shows a clear relationship between VHDL constructs and hardware components.
•Easy-to-understand conceptual diagrams, rather than cell-level netlists, explain the realization of VHDL codes.
•The book emphasizes the re-use aspect of code throughout.
•More than 300 design examples (VHDL and MATLAB® code) with computation flow tables, explanations about the code design, function procedures, simulation (timing) results, data analysis, peripheral interfacing, hardware implementation and so on make the design “technology neutral” so that the developed VHDL code can be synthesized using demo-version synthesis software provided by FPGA vendors.
•The book contains a large number of nontrivial, practical examples to illustrate and reinforce the design concepts, procedures and techniques.
•Chapters consist of (i) illustrations corresponding to the digital architectures built inside the FPGA for various applications, (ii) explanations of the architectural design and external component wiring and (iii) scientific specifications of all the peripherals/devices required for the applications covered in the book.
•Many advanced real-time applications such as specialized sensor interfacing,bidirectional signal conditioner designs, audio codec interfacing, VGA interfacing, data communication protocol design and so on are detailed with the necessarycircuits, RTL schematics and color photographs (for the fast and reliable diagnosisof component assembly) of the experimental test beds.
FPGA-Based Embedded System Developer's Guide.part1.rar (5 MB , 下载次数: 34 )
FPGA-Based Embedded System Developer's Guide.part2.rar (4.92 MB , 下载次数: 34 )
发表于 2025-5-15 09:31:18 | 显示全部楼层
谢谢分享!
发表于 2025-5-15 09:35:31 | 显示全部楼层
学习到了
发表于 2025-5-15 10:00:52 | 显示全部楼层
感谢楼主分享
发表于 2025-5-15 10:35:27 | 显示全部楼层
谢谢
发表于 2025-5-15 11:39:03 | 显示全部楼层
Thanks for sharing
发表于 2025-5-16 07:13:59 | 显示全部楼层
Thanks for the share
发表于 2025-5-16 21:45:30 | 显示全部楼层
Thanks
发表于 2025-5-17 03:18:58 | 显示全部楼层
thanks
发表于 2025-5-19 08:12:12 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-7 00:07 , Processed in 0.021644 second(s), 5 queries , Gzip On, Redis On.
