查看: 860|回复: 1
[求助] LVS时综合出不存在的器件
发表于 2025-5-12 19:15:29 来自手机 | 显示全部楼层 |阅读模式
想知道为什么会出现这种情况,还有应该怎么解决,谢谢各位大佬
报告如下:
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Connectivity errors.
  Error:    Instances of different types or subtypes were matched.
LAYOUT CELL NAME:         C2MosDT
SOURCE CELL NAME:         C2MosDT
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              8         8
Nets:              14        14
Instances:          7         7         MN (4 pins)
                     7         7         MP (4 pins)
Total Inst:        14        14
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              8         8
Nets:              10        10
Instances:          3         3         MN (4 pins)
                     3         3         MP (4 pins)
                     2         2         _sdw2v (4 pins)
                     2         2         _sup2v (4 pins)
Total Inst:        10        10
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               8          8            0            0
   Nets:               10         10            0            0
   Instances:           3          3            0            0    MN(N)
                        3          3            0            0    MP(P)
                        2          2            0            0    _sdw2v
                        2          2            0            0    _sup2v
   Total Inst:         10         10            0            0
o Initial Correspondence Points:
   Ports:        VDD GND X Q Y CLK~ CLK D
发表于 2025-5-13 09:24:24 | 显示全部楼层
管子类型不对,看一下规则文件对应器件的图层
GMT+8, 2025-12-21 04:29 , Processed in 0.013525 second(s), 4 queries , Gzip On, Redis On.
