查看: 861|回复: 5
[求助] 求助,ccopt遇到的问题
发表于 2025-4-23 15:22:17 | 显示全部楼层 |阅读模式
这错误怎么解决啊,求求大佬
 楼主| 发表于 2025-4-24 14:51:28 | 显示全部楼层
好像找到问题所在了,CKBUF_X2_R在现在的STD里面没有,我网表改一下重新试试
发表于 2025-4-24 14:59:34 | 显示全部楼层
按照提示的话,是这个变量要在 init_design 之前设才会生效
 楼主| 发表于 2025-4-24 15:56:34 | 显示全部楼层
大佬,那个错误改掉后又有一个网表唯一的错误,有什么办法解决吗
 楼主| 发表于 2025-4-24 15:59:28 | 显示全部楼层
No ideal or dont_touch nets found in the clock tree
Validating CTS configuration done. (took cpu=0:00:00.3 real=0:00:00.3)
CCOpt configuration status: all checks passed.
External - Set all clocks to propagated mode...
Innovus will update I/O latencies
External - Set all clocks to propagated mode done. (took cpu=0:00:00.0 real=0:00:00.0)
Check Prerequisites done. (took cpu=0:00:00.4 real=0:00:00.4)
CCOpt:hase::Initialization done. (took cpu=0:00:00.4 real=0:00:00.4)
Executing ccopt post-processing.
Synthesizing clock trees with CCOpt...
**WARN: (IMPECO-560):        The netlist is not unique, because the module 'SYN_WIDTH1' is instantiated multiple times. Make the netlist unique by running 'set init_design_uniquify 1' before loading the design to avoid the problem.
**ERROR: (IMPCCOPT-4255):        Netlist must be uniquified before running 'ccopt_legacy_synth_clock_trees'.
**ERROR: (IMPCCOPT-2196):        Cannot run ccopt_design because the command prerequisites were not met. Review the previous error messages for more details about the failure.
*** Summary of all messages that are not suppressed in this session:
Severity  ID               Count  Summary
WARNING   IMPECO-560           1  The netlist is not unique, because the m...
WARNING   IMPCCOPT-1361        3  Routing configuration for %s nets in clo...
ERROR     IMPCCOPT-2196        1  Cannot run ccopt_design because the comm...
ERROR     IMPCCOPT-4255        1  Netlist must be uniquified before runnin...
*** Message Summary: 4 warning(s), 2 error(s)
大佬,现在的错误变成了网表没有唯一化,这个SYN_WIDTH1怎么让他唯一哇
 楼主| 发表于 2025-4-25 09:56:23 | 显示全部楼层
神奇,重启重新来一遍过了
GMT+8, 2025-12-20 06:24 , Processed in 0.034971 second(s), 4 queries , Gzip On, Redis On.
