查看: 74208|回复: 346
各种运算放大器的设计paper(很多的IEEE上的文章)
发表于 2008-3-3 18:29:50 | 显示全部楼层 |阅读模式
下面列出的是paper的名称,每一个包都可以独自解开,想下哪个下哪个。
放大器的Common Mode Feedback检测电路:
A Continuous-Time CMFB for High-Impedance Current Mode App
A Linear MOS Transconductor using Source Degeneration and Adaptive Biaing
Fully Differential OpAmp with Accurate Output Balance
放大器的相位裕度补偿电路
A high performance low power CMOS channel filter
A low dropout CMOS regulator with high PSR over wideband frequencies
An NMOS OpAmp with internal compensation
Efficient pole zero sensitivity analysis using asymptotic waveform evaluation
Indirect feedback compensation of CMOS OpAmps
Miller OTA design using a design methodology based on the gm-id and early-voltage characteristics
Phase compensation for feedforward CMOS OTA
Phase compensation scheme for feedforward linearized CMOS OTA
3-Stage Op-Amp电路
Multistage Amp technique with embedded frequency compensation
Single miller capacitor compensated multistage Amp for large capacitive load
Three Stage Amplifier Frequency Compensation
Three-stage large capacitive load amplifier with DFCFC
Class-AB放大器
A 3V CMOS low-distortion class AB line driver suitable for HDSL applications
A capacitance-compensation Tech for improved linearity in CMOS class-AB power amp
A class AB output buffer for driving high capacitive loads
A classAB floating buffer BiCMOS Op-Amp
A class-AB floating buffer BiCMOS power OpAmp
High-voltage OpAmp based on dual floating-gate transistors
A novel class AB transconductor suitable for high speed CMOS OpAmp
Low voltage class AB output stages for CMOS op-amps using floating capacitors
Common Mode Feedback电路.rar
1.17 MB, 下载次数: 1795 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-3 18:32:37 | 显示全部楼层
放大器的相位裕度补偿电路
放大器的相位裕度补偿电路
相位裕度补偿电路.rar
4.09 MB, 下载次数: 1577 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-3-3 18:34:08 | 显示全部楼层
3-Stage Op-Amp电路
3-Stage Op-Amp电路
3-Stage Op-Amp电路.rar
1010.19 KB, 下载次数: 1342 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-3 18:36:20 | 显示全部楼层
Class-AB放大器
Class-AB放大器
Class-AB放大器.rar
2.98 MB, 下载次数: 1533 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-3 22:35:24 | 显示全部楼层
Thanks!!
发表于 2008-3-4 03:19:20 | 显示全部楼层
:lol :lol
发表于 2008-3-4 08:56:21 | 显示全部楼层
xiexie
发表于 2008-3-4 17:07:58 | 显示全部楼层
hoaohaohaohao
发表于 2008-3-5 00:27:54 | 显示全部楼层
我不能不顶lz,恩!
发表于 2008-3-14 15:10:24 | 显示全部楼层
hao 东西
GMT+8, 2025-12-21 12:20 , Processed in 0.022091 second(s), 4 queries , Gzip On, Redis On.
