查看: 2770|回复: 14
[求助] innovus跑布局布线时遇到问题
发表于 2025-3-14 17:08:02 | 显示全部楼层 |阅读模式
新手上路烦请各位大佬指教!错误信息如下:
Start to collect the design information.
Build netlist information for Cell counter_4bit.
Finished collecting the design information.
Generating standard cells used in the design report.
Analyze library ...
Analyze netlist ...
Analyze timing ...
Analyze floorplan/placement ...
Analysis Routing ...
Report saved in file rpt//route_design.rpt.
# Design Stage: PostRoute
# Design Name: counter_4bit
# Design Mode: 5nm
# Analysis Mode: MMMC OCV
# Parasitics Mode: No SPEF/RCDB
# Signoff Settings: SI Off
Extraction called for design 'counter_4bit' of instances=40 and nets=46 using extraction engine 'preRoute' .
PreRoute RC Extraction called for design counter_4bit.
RC Extraction called in multi-corner(2) mode.
RCMode: PreRoute
      RC Corner Indexes            0       1
Capacitance Scaling Factor   : 1.00000 1.00000
Resistance Scaling Factor    : 1.00000 1.00000
Clock Cap. Scaling Factor    : 1.00000 1.00000
Clock Res. Scaling Factor    : 1.00000 1.00000
Shrink Factor                : 1.00000
PreRoute extraction is honoring NDR/Shielding/ExtraSpace for clock nets.
Using Quantus QRC technology file ...
Updating RC grid for preRoute extraction ...
Initializing multi-corner resistance tables ...
PreRoute RC Extraction DONE (CPU Time: 0:00:00.0  Real Time: 0:00:00.0  MEM: 1562.836M)
AAE_INFO: 1 threads acquired from CTE.
Calculate early delays in OCV mode...
Calculate late delays in OCV mode...
Start delay calculation (fullDC) (1 T). (MEM=1565.85)
Total number of fetched objects 44
AAE_INFO: Total number of nets for which stage creation was skipped for all views 0
End delay calculation. (MEM=1619.49 CPU=0:00:00.0 REAL=0:00:00.0)
End delay calculation (fullDC). (MEM=1601.95 CPU=0:00:00.6 REAL=0:00:00.0)
Writing Netlist "counter_4bit.v" ...
**ERROR: (IMPSYT-6692):        Invalid return code while executing 'run_invs.tcl' was returned and script processing was stopped. Review the following error in 'run_invs.tcl' then restart.
**ERROR: (IMPSYT-6693):        Error message: run_invs.tcl: missing operand at _@_
in expression "(0x0 + _@_)/2".
innovus 1>
error
error
这是我的脚本
这是我的脚本
发表于 2025-3-17 10:01:17 | 显示全部楼层
应该是语法有问题,仔细看一下脚本吧
 楼主| 发表于 2025-3-17 16:07:02 | 显示全部楼层
Cribug2022 发表于 2025-3-17 10:01
应该是语法有问题,仔细看一下脚本吧
好的,我试试看,谢谢
 楼主| 发表于 2025-3-17 17:09:38 | 显示全部楼层
应该是语法有问题,仔细看一下脚本吧
大佬!我好像找到错误 了,但是我不知道咋去改,能帮忙看一下吗
发表于 2025-3-18 09:38:40 | 显示全部楼层
你这个里头是叫vdd vss吗?
 楼主| 发表于 2025-3-18 10:07:25 | 显示全部楼层
Cribug2022 发表于 2025-3-18 09:38
你这个里头是叫vdd vss吗?
我看PDN.tcl里面创建的是VDD和VSS
发表于 2025-3-18 13:09:45 | 显示全部楼层
你把这么一大段命令分开执行,就是先看什么vdd vss,再get他的net,看看问题出在那一步
发表于 2025-3-18 15:55:32 | 显示全部楼层
12行,你先把这一行的dbGet扒明白了,就能知道问题出现在哪儿了,从最里面的dbGet开始试
 楼主| 发表于 2025-3-18 20:30:28 | 显示全部楼层
Cribug2022 发表于 2025-3-18 13:09
你把这么一大段命令分开执行,就是先看什么vdd vss,再get他的net,看看问题出在那一步 ...
大佬,这是我分步跑出来的结果,感觉第一步是提取到了,第二步开始就没有提取到了,这是为啥呀
分布测试dbget
分布测试dbget
这是我测试的dbget命令,命令应该没有问题
感觉问题只能出现在标红地方
感觉问题只能出现在标红地方
发表于 2025-3-19 14:40:53 | 显示全部楼层
到sWires 能正常返回吗
GMT+8, 2025-12-25 11:50 , Processed in 0.025066 second(s), 5 queries , Gzip On, Redis On.
