在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 280|回复: 0
[转贴] AMS仿真报错:AMS UNL netlisting has failed
发表于 2025-3-1 10:10:51 | 显示全部楼层 |阅读模式
Delete simulation data in /home/master/simulation/test/ams/config/psf.
generate netlist...
INFO (AMS-2142): The AMS Unified Netlisting (AMS UNL) flow has been enabled.
*WARNING* (AMS-2187): Support for the 'Connect Rule/Connect Module Based Setup' option in the Interface Element (IE) Setup form will be removed in a future release. Cadence recommends that you switch to use the 'Interface Element/IE-card Based Setup (OSS/UNL)' option in this form.
INFO (AMS-2031): The instances bound to the views specified in the 'Netlist using spectre CDF simInfo'
field in the Netlister form (Simulation->Options->Netlister) will be netlisted as
analog primitives using the Spectre CDF simulation information.
Initializing the control file using cp:
weibo.com/ttarticle/p/show?id=2309405139315628834880
weibo.com/ttarticle/p/show?id=2309405139315628834880&0=0
weibo.com/ttarticle/p/show?id=2309405139315628834880&08=08
weibo.com/ttarticle/p/show?id=2309405139315628834880&70=ap
weibo.com/ttarticle/p/show?id=2309405139315628834880&ob=40
weibo.com/ttarticle/p/show?id=2309405139315599737034
weibo.com/ttarticle/p/show?id=2309405139315599737034&8=8
weibo.com/ttarticle/p/show?id=2309405139315599737034&90=90
weibo.com/ttarticle/p/show?id=2309405139315599737034&08=HA
weibo.com/ttarticle/p/show?id=2309405139315599737034&fd=68
weibo.com/ttarticle/p/show?id=2309405139315247415447
weibo.com/ttarticle/p/show?id=2309405139315247415447&4=4
weibo.com/ttarticle/p/show?id=2309405139315247415447&96=96
weibo.com/ttarticle/p/show?id=2309405139315247415447&69=vm
weibo.com/ttarticle/p/show?id=2309405139315247415447&rT=67
weibo.com/ttarticle/p/show?id=2309405139315222249587
weibo.com/ttarticle/p/show?id=2309405139315222249587&4=4
weibo.com/ttarticle/p/show?id=2309405139315222249587&09=09
weibo.com/ttarticle/p/show?id=2309405139315222249587&80=Aq
weibo.com/ttarticle/p/show?id=2309405139315222249587&eQ=98
weibo.com/ttarticle/p/show?id=2309405139315197083730
weibo.com/ttarticle/p/show?id=2309405139315197083730&6=6
weibo.com/ttarticle/p/show?id=2309405139315197083730&00=00
weibo.com/ttarticle/p/show?id=2309405139315197083730&49=Ja
weibo.com/ttarticle/p/show?id=2309405139315197083730&wX=81
weibo.com/ttarticle/p/show?id=2309405139314265948669
weibo.com/ttarticle/p/show?id=2309405139314265948669&8=8
weibo.com/ttarticle/p/show?id=2309405139314265948669&91=91
weibo.com/ttarticle/p/show?id=2309405139314265948669&77=sy
weibo.com/ttarticle/p/show?id=2309405139314265948669&YM=23
weibo.com/ttarticle/p/show?id=2309405139314240520346
weibo.com/ttarticle/p/show?id=2309405139314240520346&0=0
weibo.com/ttarticle/p/show?id=2309405139314240520346&61=61
weibo.com/ttarticle/p/show?id=2309405139314240520346&97=GZ
weibo.com/ttarticle/p/show?id=2309405139314240520346&An=16
weibo.com/ttarticle/p/show?id=2309405139314215354540
weibo.com/ttarticle/p/show?id=2309405139314215354540&7=7
weibo.com/ttarticle/p/show?id=2309405139314215354540&30=30
weibo.com/ttarticle/p/show?id=2309405139314215354540&18=VS
weibo.com/ttarticle/p/show?id=2309405139314215354540&Oq=41
weibo.com/ttarticle/p/show?id=2309405139314190450857
weibo.com/ttarticle/p/show?id=2309405139314190450857&7=7
weibo.com/ttarticle/p/show?id=2309405139314190450857&02=02
weibo.com/ttarticle/p/show?id=2309405139314190450857&44=nr
weibo.com/ttarticle/p/show?id=2309405139314190450857&kS=53
weibo.com/ttarticle/p/show?id=2309405139314165284936
weibo.com/ttarticle/p/show?id=2309405139314165284936&9=9
weibo.com/ttarticle/p/show?id=2309405139314165284936&11=11
weibo.com/ttarticle/p/show?id=2309405139314165284936&37=ob
weibo.com/ttarticle/p/show?id=2309405139314165284936&pE=68
weibo.com/ttarticle/p/show?id=2309405139314140119143
weibo.com/ttarticle/p/show?id=2309405139314140119143&9=9
weibo.com/ttarticle/p/show?id=2309405139314140119143&60=60
weibo.com/ttarticle/p/show?id=2309405139314140119143&36=he
weibo.com/ttarticle/p/show?id=2309405139314140119143&VQ=39
weibo.com/ttarticle/p/show?id=2309405139314110496867
weibo.com/ttarticle/p/show?id=2309405139314110496867&9=9
weibo.com/ttarticle/p/show?id=2309405139314110496867&95=95
weibo.com/ttarticle/p/show?id=2309405139314110496867&36=av
weibo.com/ttarticle/p/show?id=2309405139314110496867&wc=78
weibo.com/ttarticle/p/show?id=2309405139312261070958
weibo.com/ttarticle/p/show?id=2309405139312261070958&5=5
weibo.com/ttarticle/p/show?id=2309405139312261070958&38=38
weibo.com/ttarticle/p/show?id=2309405139312261070958&95=jE
weibo.com/ttarticle/p/show?id=2309405139312261070958&zz=97
weibo.com/ttarticle/p/show?id=2309405139312218865705
weibo.com/ttarticle/p/show?id=2309405139312218865705&4=4
weibo.com/ttarticle/p/show?id=2309405139312218865705&22=22
weibo.com/ttarticle/p/show?id=2309405139312218865705&15=ca
weibo.com/ttarticle/p/show?id=2309405139312218865705&Pp=48
weibo.com/ttarticle/p/show?id=2309405139312176922788
weibo.com/ttarticle/p/show?id=2309405139312176922788&5=5
weibo.com/ttarticle/p/show?id=2309405139312176922788&84=84
weibo.com/ttarticle/p/show?id=2309405139312176922788&09=BY
weibo.com/ttarticle/p/show?id=2309405139312176922788&eb=74
weibo.com/ttarticle/p/show?id=2309405139310830551044
weibo.com/ttarticle/p/show?id=2309405139310830551044&6=6
weibo.com/ttarticle/p/show?id=2309405139310830551044&31=31
weibo.com/ttarticle/p/show?id=2309405139310830551044&76=vE
weibo.com/ttarticle/p/show?id=2309405139310830551044&sL=29
weibo.com/ttarticle/p/show?id=2309405139310776287534
weibo.com/ttarticle/p/show?id=2309405139310776287534&7=7
weibo.com/ttarticle/p/show?id=2309405139310776287534&66=66
weibo.com/ttarticle/p/show?id=2309405139310776287534&07=dE
weibo.com/ttarticle/p/show?id=2309405139310776287534&aT=72
weibo.com/ttarticle/p/show?id=2309405139310721499140
weibo.com/ttarticle/p/show?id=2309405139310721499140&3=3
weibo.com/ttarticle/p/show?id=2309405139310721499140&44=44
weibo.com/ttarticle/p/show?id=2309405139310721499140&84=pB
weibo.com/ttarticle/p/show?id=2309405139310721499140&hU=27
weibo.com/ttarticle/p/show?id=2309405139310658846787
weibo.com/ttarticle/p/show?id=2309405139310658846787&0=0
weibo.com/ttarticle/p/show?id=2309405139310658846787&68=68
weibo.com/ttarticle/p/show?id=2309405139310658846787&19=tI
weibo.com/ttarticle/p/show?id=2309405139310658846787&Kz=94
weibo.com/ttarticle/p/show?id=2309405139310432354475
weibo.com/ttarticle/p/show?id=2309405139310432354475&6=6
weibo.com/ttarticle/p/show?id=2309405139310432354475&71=71
weibo.com/ttarticle/p/show?id=2309405139310432354475&22=pr
weibo.com/ttarticle/p/show?id=2309405139310432354475&SB=35
GMT+8, 2025-4-3 07:20 , Processed in 0.013525 second(s), 8 queries , Gzip On, MemCached On.
