查看: 1292|回复: 1
[求助] BUMP net spef 反标不上
发表于 2025-1-26 01:38:19 | 显示全部楼层 |阅读模式
Hi all,
请问有没有人遇到过出bump的net 读spef 反标不上?
Information: Derived library resistance unit is 1.000000 Kohm (Time unit is 1 ns, and Capacitance unit is 1.000000 pF). (DES-028)
Information: Attempting to read the parasitic file to auto-determine location transformation factors. (PARA-067)
Error: Cannot find port/pin 'ddr3_ba[2]_1' in design 'umctl2_phy_top' (PARA-124)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/io_a_3__pad_a/OE ddr3_ba[2]_1 1.70529e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/FE_RN_91: node 'ddr3_ba[2]_1' could not be found (PARA-043)
Error: Cannot find port/pin 'ddr3_ba[2]_191' in design 'umctl2_phy_top' (PARA-124)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/io_a_3__pad_a/OE ddr3_ba[2]_191 1.18993e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/FE_RN_91: node 'ddr3_ba[2]_191' could not be found (PARA-043)
Error: Cannot find port/pin 'ddr3_ba[2]_192' in design 'umctl2_phy_top' (PARA-124)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/io_a_3__pad_a/OE ddr3_ba[2]_192 9.58034e-06) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/FE_RN_91: node 'ddr3_ba[2]_192' could not be found (PARA-043)
Error: Cannot find port/pin 'ddr3_addr[10]_1' in design 'umctl2_phy_top' (PARA-124)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_83_NET:5 ddr3_addr[10]_1 3.73191e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_83_NET: node 'ddr3_addr[10]_1' could not be found (PARA-043)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_84_NET:5 ddr3_addr[10]_1 3.72059e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_84_NET: node 'ddr3_addr[10]_1' could not be found (PARA-043)
Error: Cannot find port/pin 'dto[0]_1' in design 'umctl2_phy_top' (PARA-124)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/io_a_14__pad_a/SJ dto[0]_1 4.12347e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_106_NET: node 'dto[0]_1' could not be found (PARA-043)
Warning: Invalid coupling capacitor (u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/io_a_14__pad_a/ET dto[0]_1 4.25658e-05) on net u_DWC_DDRPHY_top/u_DWC_DDR3PHY/u_DWC_DDR3PHYAC_top/u_DWC_DDR3PHYAC_io/LTIELO_108_NET: node 'dto[0]_1' could not be found (PARA-043)
Error: Cannot find port/pin 'ddr3_dm[0]_209' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_210' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_211' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_212' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_213' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_214' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_215' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_216' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_217' in design 'umctl2_phy_top' (PARA-124)
Error: Cannot find port/pin 'ddr3_dm[0]_218' in design 'umctl2_phy_top' (PARA-124)
明明port 名字是ddr3_dm[0] 为何变成了那么多下划线的_不同名字?
 楼主| 发表于 2025-1-26 21:34:18 | 显示全部楼层
是因为bump的原因,把bump删掉,不会有这些
GMT+8, 2025-12-25 16:32 , Processed in 0.012682 second(s), 5 queries , Gzip On, Redis On.
