查看: 1131|回复: 2
[讨论] Calibre Pex Compilation Error PXR12 on line 270
发表于 2024-12-4 12:10:55 | 显示全部楼层 |阅读模式
The layout is designed using SMIC18mmrf library file, and Caliber DRC and Caliber LVS are passed. While run CalibrePEX, The compilation error is occured.
"Compilaion Error
Error while compiling rules file
/hom/disk/CMOSedu/SMIC_018_MMRF_oa/Calibre/pex/SmicSPM10RR12R_cal018_mixRF_sali_p1mtx_1833.lvs_XRC:Error PXR12 on line 270 of /hom/disk/CMOSedu/SMIC_018_MMRF_oa/Calibre/pex/SmicSP10R_018_mix_p1mt6_tran_typ_1833.rc- this was found where an expression representing a numeric value was expected: lenpoly "
Previously I resolved this error, remove the library file from in the virtuoso library manager and vmware, the copied again to the vmware and virtuoso library manager. Then this error is resolved and could not know the reason. Then calibre pex is tried in different machine , compilation error is occurred.
Could you please any one suggest to resolve this error?
compilation error
compilation error
发表于 2024-12-4 13:04:59 | 显示全部楼层
你xrc文件这里怎么写的
 楼主| 发表于 2024-12-4 14:21:51 | 显示全部楼层
In-lucky 发表于 2024-12-4 13:04
你xrc文件这里怎么写的
Below xrc file is mentioned. the 270 line of xrc file is marked.
GMT+8, 2025-12-27 03:39 , Processed in 0.014309 second(s), 5 queries , Gzip On, Redis On.
