查看: 1579|回复: 4
[求助] 从Schematic打开Layout XL崩溃
发表于 2024-9-20 20:23:09 | 显示全部楼层 |阅读模式
崩溃求助!麻烦各位帮忙看看是什么原因导致的。
使用环境:IC618, Spectre2023, Calibre2023, XCELIUMMAIN2023
崩溃原因:从Schematic打开Layout XL,窗口出来没有任何操作,virtuoso所有窗口全部闪退,弹出崩溃报告
崩溃报告:
startdate:Fri Sep 20 16:17:48 2024
crashdate:Fri Sep 20 16:18:34 2024
appname:virtuoso
version(#)$CDS: virtuoso version 6.1.8-64b 10/11/2023 09:56 (cpgbld01) $
subversion:IC6.1.8-64b.500.34
mem:743227392 (total 20864126976)
memavail:31904176k (total 37153360k)
signal:Aborted(6)
user:meow
host:chiara (x86_64)
osinux
osversion: 3.10.0-1160.108.1.el7.x86_64 #1 SMP Thu Jan 25 16:17:31 UTC 2024 x86_64
xserver:The X.Org Foundation
xversion:11.0 (vendor release 12004000)
display::0
qtversion:5.9.1
cdslog:/tmp/crashReport_092024_161834_IC6.1.8-64b.500.34_meow_chiara.log.CDS.log
cmd:240:schZoomFit(1.0 0.9)
cmd:242:schHiCheck("run")
cmd:250:hiDBoxOK(_schCheckDBox)
cmd:254:_deUpdateMenu('schematicTools 2)
cmd:256:lxLaunchLayoutXL()
cmd:260:hiiSetCurrentForm('lxCVPairActionForm)
cmd:262:hiFormDone(lxCVPairActionForm)
cmd:265:hiFormDone(deNewForm)
cmd:281:_treeWidgetTreeWidgetItemClicked(_iaConfForm->_iaCfgTree "Generate Trunks" "0" "Unchecked")
cmd:283:_treeWidgetTreeWidgetItemClicked(_iaConfForm->_iaCfgTree "Generate Trunks" "0" "Unchecked")
warning:173:but was defined in libFile '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/cds.lib' for Lib 'avTech'.
warning:185:*WARNING* The directory: '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/$ASSURAHOME/tools/assura/etc/avtech/avTech' does not exist
warning:186:but was defined in libFile '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/cds.lib' for Lib 'avTech'.
warning:199:*WARNING* The directory: '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/$ASSURAHOME/tools/assura/etc/avtech/avTech' does not exist
warning:200:but was defined in libFile '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/cds.lib' for Lib 'avTech'.
warning:209:*WARNING* The directory: '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/$ASSURAHOME/tools/assura/etc/avtech/avTech' does not exist
warning:210:but was defined in libFile '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/cds.lib' for Lib 'avTech'.
warning:257:*WARNING* The directory: '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/$ASSURAHOME/tools/assura/etc/avtech/avTech' does not exist
warning:258:but was defined in libFile '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/cds.lib' for Lib 'avTech'.
warning:303:*WARNING* Process was terminated with SIGABRT signal
signal_by:system
skill:<<< Stack Trace >>>
skill... in _cphDataInitFromXL ...)
skill:        cph = nil
skill:        openTheGui = nil
skill:        launchMode = "Automatic"
skill:        templateFile = ""
skill:        template = ""
skill:        cfgAccessMode = "a"
skill:        cfgView = "physConfig"
skill:        cfgCell = "nmos"
skill:        cfgLib = "test"
skill:        dstCVId = db:0x26ecb99a
skill:        srcCVId = db:0x26ecc51a
skill:        configSpec = (nil fileSpec (nil accessMode "a" viewType "physConfig" ... ) dstCVId db:0x26ecb99a ... )
skill... in _cphInitCVPairConfig ...)
skill:        libN = "test"
skill:        cellN = "nmos"
skill:        viewN = "physConfig"
skill:        fileSpec = (nil accessMode "a" viewType "physConfig" ... )
skill:        status = t
skill:        notCanceled = nil
skill:        tmpM = nil
skill... in _lxInitCPH ...)
skill:        cfgSpec = nil
skill:        config = nil
skill:        cvPairAction = (nil invokedFrom "Schematic" config (nil fileSpec (nil accessMode "a" viewType "physConfig" ... ) dstCVId db:0x26ecb99a ... ) ... )
skill:        configViewName = "physConfig"
skill:(... in _lxPerformInit ...)
skill:        start_both_wins = nil
skill:        new_data = (db:0x26ecc51a window:2 db:0x26ecb99a window:3)
skill:        noSchWin = nil
skill:        srcWinId = window:2
skill:        dstWinId = window:3
skill:        topSrcWinId = window:2
skill:        start_src_win = nil
skill:        mustOpenOtherWin = t
skill:        apName = "Virtuoso XL (Schematics)"
skill:        noDeskTop = nil
skill:        schDefAppNone = nil
skill:        transparent = nil
skill:        startFromLay = nil
skill:(... in _lxiHiSetup ...)
skill:        _tSch = nil
skill:        _transRef = nil
skill:        _wasPushed = nil
skill:        ret = nil
skill:        refCV = nil
skill:        booleanSavedEnv = nil
skill:        lcv = nil
skill:        conn_ref_type = "CELLVIEW"
skill:        conn_ref = nil
skill:        cvs_need_close = nil
skill:        start_libname = "test"
skill:        start_lib = dd:0x353ba200
skill:        src_open_info = (window:3 nil)
skill:        start_viewtype = "schematic"
skill:        view_type = "maskLayout"
skill:        cvPairInfo = nil
skill:        otherWinId = window:3
skill:        otherCVId = db:0x26ecb99a
skill:        oldFormValues = (nil windowStyle "new tab" doneAction "deNewFormCB()" ... )
skill:        topSrcCVId = nil
skill:        open_mode = "edit"
skill:        sviewName = "layout"
skill:        initWinId = window:2
skill:        initCVId = db:0x26ecc51a
skill:        accessMode = nil
skill:        _transparent = nil
skill:        descendOrigWin = nil
skill:(... in unknown ...)
skill:funobj@0x2f21a638()
skill:(... in lxiMCVSchEnableTrigger ...)
skill:        winId = window:2
skill:        in_lxiMCVSchEnableTrigger = t
skill:        cvId = db:0x26ecc51a
skill:        isOK = nil
skill:        result = t
skill:        args = (nil appName "Virtuoso XL (Schematics)" action install ... )
skill:(... in _launchXLid ...)
skill:        returnValue = nil
skill:        rootType = "schematic"
skill:        idWin = window:2
skill:        ar = (nil appName "Virtuoso XL (Schematics)" action install ... )
skill:        winId = nil
skill:        appName = "Virtuoso XL (Schematics)"
skill:_launchXLid(winId "Virtuoso XL (Schematics)")
skill:        winId = nil
skill:lxLaunchLayoutXL()
skill:        _insideilparser = t
skill:<<< End Stack >>>
userenv:ABVIP_ISNT_DIR=/opt/cadence/VIPCAT113/tools/abvip
userenv:AMBIT_BDF_PATH=/opt/cadence/IC618/etc/syntechEtc/bdfc
userenv:AMBIT_MSG_PATH=/opt/cadence/IC618/etc/syntechEtc/msgc
userenv:AMS_DIR=/home/meow/Design/AMS/
userenv:A__z="*SHLVL
userenv:CADENCE_DIR=/opt/cadence/IC618
userenv:CADENCE_VIP_LIC_ORDER=newrev:soc:portfolio:alacarte
userenv:CADHOME=/opt/cadence
userenv:CALIBRE_HOME=/opt/mentor/Calibre2023/aoj_cal_2023.2_16.9
userenv:CALIBRE_OS_MSG_LEVEL=1
userenv:CDK_DIR=/opt/PDKs/ncsu-cdk-1.6.0.beta
userenv:CDN_VIP_ROOT=/opt/cadence/VIPCAT113
userenv:CDS=/opt/cadence/IC618
userenv:CDSDIR=/opt/cadence/IC618
userenv:CDSHOME=/opt/cadence/IC618
userenv:CDSROOT=/opt/cadence/IC618
userenv:CDS_ARCH=lnx86
userenv:CDS_AUTO_64BIT=ALL
userenv:CDS_ENABLE_VMS=1
userenv:CDS_INST_DIR=/opt/cadence/IC618
userenv:CDS_INST_ROOT=/opt/cadence/IC618
userenv:CDS_LANG=C
userenv:CDS_LIC_FILE=/opt/cadence/IC618/share/license/license.dat
userenv:CDS_LIC_ONLY=1
userenv:CDS_LOAD_ENV=CWD
userenv:CDS_MPS_SESSION=virtuoso6571
userenv:CDS_Netlisting_Mode=Analog
userenv:CDS_PERFDEBUG_DATA=/opt/cadence/IC618/tools.lnx86/dfII/samples/perfUtil/data/DebugData
userenv:CDS_PERFDEBUG_LIBDIR=/opt/cadence/IC618/tools.lnx86/dfII/samples/perfUtil/lib
userenv:CDS_PERFDEBUG_TOOLLIBDIR=/opt/cadence/IC618/tools/lib/64bit
userenv:CDS_ROOT=/opt/cadence/IC618
userenv:CDS_SET_LOCALE=C
userenv:CDS_USE_XVFB=1
userenv:CDS_VISA_DEV_RPC_ENABLE=1
userenv:CDS_W3264_LIBPATH=/opt/cadence/IC618/share/oa/lib/lnx86/opt::/opt/cadence/IC618/tools/dfII/lib/64bit:/opt/cadence/IC618/tools/sev/lib/64bit:/opt/cadence/IC618/tools/lib/64bit:/opt/cadence/IC618/tools/lib:/opt/cadence/IC618/tools/hdf5/lib/64bit::/opt/cadence/IC618/tools/lz4/lib/64bit:/opt/cadence/IC618/tools/python/64bit/lib:/opt/cadence/XCELIUM2309/tools.lnx86/lib/64bit:/opt/cadence/IC618/tools/TPtools/grpc/lib64:/opt/cadence/IC618/tools/TPtools/grpc/lib:/opt/cadence/IC618/tools/Qt/v5/64bit/lib:/opt/cadence/IC618/tools/lib/64bit/RHEL/RHEL8:/lib64
userenv:CNI_LOG_DEFAULT=/dev/null
userenv:CNI_PLAT_ROOT=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64
userenv:CNI_ROOT=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262
userenv:COLORTERM=truecolor
userenv:CONDA_DEFAULT_ENV=base
userenv:CONDA_EXE=/home/meow/anaconda3/bin/conda
userenv:CONDA_PREFIX=/home/meow/anaconda3
userenv:CONDA_PROMPT_MODIFIER=(base)
userenv:CONDA_PYTHON_EXE=/home/meow/anaconda3/bin/python
userenv:CONDA_SHLVL=1
userenv:CORNERS_INST_DIR=/opt/cadence/IC618/share/java/COM/cadence/seaStars/corners
userenv:CTU_CDSENV_SETTINGS=1
userenv:CTU_COMMON_SETTINGS_VIRTUOSO=1
userenvBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-ek2xwONC8g,guid=023a6966bfd315922254d41c66edd4dd
userenvD_USE_LIBDEFS=no
userenvENALI=/opt/cadence/VIPCAT113/tools/denali_64bit
userenv:DESKTOP_SESSION=gnome-classic
userenv:DISPLAY=:0
userenv:GDMSESSION=gnome-classic
userenv:GDM_LANG=en_US.UTF-8
userenv:GNOME_DESKTOP_SESSION_ID=this-is-deprecated
userenv:GNOME_SHELL_SESSION_MODE=classic
userenv:GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/31177289_26a9_4522_a848_0a2f5dcdd086
userenv:GNOME_TERMINAL_SERVICE=:1.107
userenv:GSETTINGS_SCHEMA_DIR=/home/meow/anaconda3/share/glib-2.0/schemas
userenv:GSETTINGS_SCHEMA_DIR_CONDA_BACKUP=
userenv:HISTCONTROL=ignoreboth
userenv:HISTSIZE=1000
userenv:HOME=/home/meow
userenv:HOSTNAME=chiara
userenv:IMSETTINGS_INTEGRATE_DESKTOP=yes
userenv:IMSETTINGS_MODULE=none
userenv:K2_HOME=/opt/cadence/PVS151/tools/K2
userenv:K2_MASKCOMPOSE_HOME=/opt/cadence/PVS151/tools/K2/MaskCompose
userenv:K2_MC_DATA=/home/meow/Projects
userenv:K2_VIEWER_HOME=/opt/cadence/PVS151/tools/K2/Viewer
userenv:KDEDIRS=/usr
userenvANG=C
userenvC_ALL=C
userenv:LD_LIBRARY_PATH=/opt/cadence/IC618/share/oa/lib/lnx86/opt:/opt/cadence/IC618/tools/dfII/lib/64bit:/opt/cadence/IC618/tools/sev/lib/64bit:/opt/cadence/IC618/tools/lib/64bit:/opt/cadence/IC618/tools/lib:/opt/cadence/IC618/tools/hdf5/lib/64bit:/opt/cadence/IC618/tools/lz4/lib/64bit:/opt/cadence/IC618/tools/python/64bit/lib:/opt/cadence/XCELIUM2309/tools.lnx86/lib/64bit:/opt/cadence/IC618/tools/TPtools/grpc/lib64:/opt/cadence/IC618/tools/TPtools/grpc/lib:/opt/cadence/IC618/tools/Qt/v5/64bit/lib:/opt/cadence/IC618/tools/lib/64bit/RHEL/RHEL8:/lib64:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/3rd/lib:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/lib:/opt/cadence/XCELIUM2309/tools/lib/64bit:/opt/cadence/XCELIUM2309/tools/lib
userenv:LESSOPEN=||/usr/bin/lesspipe.sh %s
userenv:LF11IS_DISPLAY=true
userenv:LF11IS_HOME=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2
userenv:LF11IS_OPTION=4metal
userenv:LM_LICENSE_FILE=/opt/cadence/IC618/share/license/license.dat
userenv:LOGNAME=meow
userenv:MAIL=/var/spool/mail/meow
userenv:MGC_CALIBRE_DRC_RUNSET_FILE=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/lf11is_calibre.runset
userenv:MGC_CALIBRE_LAYOUT_SERVER=meowu:9189
userenv:MGC_CALIBRE_LAYOUT_SERVER_NAME=Cadence:Virtuoso
userenv:MGC_CALIBRE_LVS_RUNSET_FILE=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/setup/lf11is_calibre.runset
userenv:MGC_CALIBRE_REALTIME_VIRTUOSO_ENABLED=1
userenv:MGC_CALIBRE_REALTIME_VIRTUOSO_RELEASE_DATE=20231011
userenv:MGC_CALIBRE_REALTIME_VIRTUOSO_RESET_SOCKET=1
userenv:MGC_CALIBRE_SAVE_ALL_RUNSET_VALUES=1
userenv:MGC_CALIBRE_SCHEMATIC_SERVER=meowu:9199S
userenv:MGC_FDI_OA_VERSION=22.50
userenv:MGC_HOME=/opt/mentor/Calibre2023/aoj_cal_2023.2_16.9
userenv:MGC_LIB_PATH=/opt/mentor/Calibre2023/aoj_cal_2023.2_16.9/lib
userenv:MGC_PDF_READER=evince
userenv:MGC_RVE_HILIGHT_SHORT_TEXT_CMDS=1
userenv:MGLS_LICENSE_FILE=/opt/mentor/license/license.dat
userenv:MMSIMHOME=/opt/cadence/SPECTRE231
userenv:MOZILLA_HOME=/usr/bin/firefox
userenv:OA_COMPILER=gcc483
userenv:OA_PLUGIN_PATH=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/quickstart:
userenv:OA_UNSUPPORTED_PLAT=linux_rhel50_gcc48x
userenv:OLDPWD=/home/meow
userenvATH=/opt/cadence/IC618/bin:/opt/cadence/IC618/tools/bin/64bit:/opt/cadence/IC618/tools/bin:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/3rd/bin:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/bin:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/bin:/home/meow/anaconda3/bin:/home/meow/anaconda3/condabin:/home/meow/Design/AMS/cds/bin:/home/meow/Design/Xfab_all/x_all/cadence/xenv:/usr/lib64/qt-3.3/bin:/home/meow/Design/Xfab_all/x_all/cadence/xenv:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/meow/.local/bin:/home/meow/bin:/opt/cadence/IC618/tools/dfII/bin:/opt/cadence/IC618/tools/plot/bin:/opt/cadence/SPECTRE231/bin:/opt/cadence/SPECTRE231/tools/relxpert/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/XCELIUM2309/bin:/opt/cadence/XCELIUM2309/tools/bin:.:/opt/cadence/XCELIUM2309/tools/vtools/vfault/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/tools/denali_64bit/bin:/opt/cadence/MVS152/tools/bin:/opt/mentor/Calibre2023/aoj_cal_2023.2_16.9/bin
userenvWD=/home/meow/Design/LF110_Workarea
userenvYTHONHOME=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/3rd
userenv:PYTHONPATH=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/pylib:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/lib:
userenvRC_HOME=/opt/cadence/EXT151
userenvRC_MOS_LW_PRECISION=Y
userenvTDIR=/usr/lib64/qt-3.3
userenv:QTINC=/usr/lib64/qt-3.3/include
userenv:QTLIB=/usr/lib64/qt-3.3/lib
userenv:QT_GRAPHICSSYSTEM_CHECKED=1
userenv:QT_IM_MODULE=ibus
userenv:QT_PLUGIN_PATH=/usr/lib64/kde4/plugins:/usr/lib/kde4/plugins
userenv:QT_XCB_NO_XI2_MOUSE=1
userenv:SHELL=/bin/bash
userenv:SHLVL=5
userenv:SOCV_KIT_HOME=/opt/cadence/XCELIUM2309/kits/VerificationKit
userenv:SPECMAN_PATH=/usr/lib64/qt-3.3/bin:/home/meow/Design/Xfab_all/x_all/cadence/xenv:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/meow/.local/bin:/home/meow/bin:/opt/cadence/IC618/tools/dfII/bin:/opt/cadence/IC618/tools/plot/bin:/opt/cadence/SPECTRE231/bin:/opt/cadence/SPECTRE231/tools/relxpert/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/XCELIUM2309/bin:/opt/cadence/XCELIUM2309/tools/bin::/opt/cadence/XCELIUM2309/tools/vtools/vfault/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/utils:/opt/cadence/VIPCAT113/packages:/opt/cadence/VIPCAT113/vips/enet/vr_enet
userenv:SSH_AGENT_PID=2087
userenv:SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
userenv:SYSTEM_CDS_LIB_DIR=/opt/cadence/IC618/share/cdssetup
userenv:TCL_LIBRARY=/opt/cadence/IC618/tools/TPtools/tcltk/tcl8.6/library
userenv:TERM=xterm-256color
userenv:TSMC_ASU_DFM_PATH=/opt/PDKs/tsmc/CRNxxG/Assura/lvs_rcx/DFM
userenv:USER=meow
userenv:USERNAME=meow
userenv:VCA_ENABLE_CSM=15
userenv:VTE_VERSION=5204
userenv:W3264_ENV=/home/meow/.kshrc
userenv:W3264_NO_HOST_CHECK=1
userenv:W3264_PS_COMPAT_LIBDIR=/opt/cadence/IC618/tools/lib/64bit/RHEL/RHEL8
userenv:W3264_STORED_HOSTNAME=chiara
userenv:W3264_USER_LIBPATH=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/3rd/lib:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/lib:/opt/cadence/XCELIUM2309/tools/lib/64bit:/opt/cadence/XCELIUM2309/tools/lib
userenv:W3264_USER_PATH=/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/3rd/bin:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/plat_linux_gcc483_64/bin:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/bin:/home/meow/anaconda3/bin:/home/meow/anaconda3/condabin:/home/meow/Design/AMS/cds/bin:/home/meow/Design/Xfab_all/x_all/cadence/xenv:/usr/lib64/qt-3.3/bin:/home/meow/Design/Xfab_all/x_all/cadence/xenv:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/meow/.local/bin:/home/meow/bin:/opt/cadence/IC618/tools/dfII/bin:/opt/cadence/IC618/tools/plot/bin:/opt/cadence/SPECTRE231/bin:/opt/cadence/SPECTRE231/tools/relxpert/bin:/opt/cadence/EXT151/bin:/opt/cadence/PVS151/bin:/opt/cadence/PVS151/tools/bin:/opt/cadence/PVS151/tools/K2/MaskCompose/bin:/opt/cadence/GENUS152/tools/bin:/opt/cadence/JLS151/bin:/opt/cadence/INNOVUS152/bin:/opt/cadence/CTOS142/bin:/opt/cadence/CONFRML152/bin:/opt/cadence/SSV152/tools/bin:/opt/cadence/XCELIUM2309/bin:/opt/cadence/XCELIUM2309/tools/bin:.:/opt/cadence/XCELIUM2309/tools/vtools/vfault/bin:/opt/cadence/ET151/bin:/opt/cadence/VIPCAT113/tools/denali_64bit/bin:/opt/cadence/MVS152/tools/bin:/opt/mentor/Calibre2023/aoj_cal_2023.2_16.9/bin
userenv:WINDOWPATH=1
userenv:XAUTHORITY=/run/gdm/auth-for-meow-RjIu4o/database
userenv:XDG_CURRENT_DESKTOP=GNOME-Classic:GNOME
userenv:XDG_DATA_DIRS=/home/meow/.local/share/flatpak/exports/share/:/var/lib/flatpak/exports/share/:/usr/local/share/:/usr/share/
userenv:XDG_MENU_PREFIX=gnome-
userenv:XDG_RUNTIME_DIR=/run/user/1000
userenv:XDG_SEAT=seat0
userenv:XDG_SESSION_DESKTOP=gnome-classic
userenv:XDG_SESSION_ID=1
userenv:XDG_SESSION_TYPE=x11
userenv:XDG_VTNR=1
userenv:XKEYSYMDB=/opt/cadence/IC618/tools/plot/etc/XKeysymDB
userenv:XMODIFIERS=@im=ibus
userenv:X_DIR=/home/meow/Design/Xfab_all/
userenv:_=*6570*/opt/cadence/IC618/tools/dfII/bin/64bit/virtuoso
userenv:_CE_CONDA=
userenv:_CE_M=
userenv:__DFII_INTEG_NC_PATH__=/opt/cadence/XCELIUM2309/tools/bin/64bit
userenv:_dfII_bin_bit=/64bit
userenv:df2BaseVhdlin=/opt/cadence/XCELIUM2309
userenv:ml_seq_dir=/opt/cadence/XCELIUM2309/specman/src
userenv:ml_uvm=/opt/cadence/XCELIUM2309/tools/uvm/uvm_lib/uvm_ml/sc/ml_uvm
userenv:ps3264_osid=RedHatEnterprise
userenv:uvm_home=/opt/cadence/XCELIUM2309/tools/uvm
userenv:w3264_osver=8
cdsinit:;; PDK specific entries do not touch --
cdsinit:
cdsinit:LF11IS_HOME = getShellEnvVar( "LF11IS_HOME" )
cdsinit:
cdsinit:defun( LFinitDisplayError ( t_banner t_errorMsg )
cdsinit:;; display a dialog box message about LF11IS_HOME failure.
cdsinit:    when( t_errorMsg
cdsinit:        warn( t_errorMsg )
cdsinit:        hiDisplayAppDBox(
cdsinit:            ?name           'LF11IS_HOME_error
cdsinit:            ?dboxBanner     t_banner
cdsinit:            ?dboxText       t_errorMsg
cdsinit:            ?dialogType     hicErrorDialog
cdsinit:            ?dialogStyle    'modal
cdsinit:            ?buttonLayout   'Close
cdsinit:        )
cdsinit:    )
cdsinit ;; close defun
cdsinit:
cdsinit:;; getting LF11IS_HOME directory
cdsinit:if( !LF11IS_HOME || LF11IS_HOME == "" then
cdsinit:  LFinitDisplayError(
cdsinit:    "LF11IS_HOME Error"
cdsinit:    strcat(
cdsinit:      "Environment variable LF11IS_HOME not set.\n"
cdsinit:      "This will result in an incomplete customization for LF11ISC.\n"
cdsinit:    )
cdsinit:  )
cdsinit:else
cdsinit:  if( !isDir( LF11IS_HOME ) then
cdsinit:      strcat(
cdsinit:        "Environment variable LF11IS_HOME is not a directory.\n"
cdsinit:      )
cdsinit:    )
cdsinit:  else
cdsinit:    if( !isReadable( LF11IS_HOME ) then
cdsinit:        strcat(
cdsinit:          "Directory LF11IS_HOME is not readable.\n"
cdsinit:        )
cdsinit:      )
cdsinit:    else
cdsinit:      loadi( strcat( LF11IS_HOME "/tools/setup/.cdsinit" ) )
cdsinit:    ) ;; close unless isReadable
cdsinit:  ) ;; close if isDir
cdsinit ;; close if getShellEnvVar
cdsinit:
cdsinit:;;) ;; close let
cdsinit:
cdsinit:;; END PDK specific entries do not touch --
cdsinit:
cdsinit:;; PDK ADDONs specific entries do not touch --
cdsinit:let(
cdsinit:        (
cdsinit:                (addon_list getShellEnvVar("LF11IS_ADDON"))
cdsinit:                addon_path
cdsinit:        )
cdsinit:        addon_list=getShellEnvVar("LF11IS_ADDON")
cdsinit:        when(addon_list
cdsinit:                foreach(addon parseString(addon_list ":")
cdsinit:                        addon_path=strcat(addon "/tools/setup/.cdsinit")
cdsinit:                        if(isFile(addon_path) then
cdsinit:                                printf("*LF-INFO* %s loading \n" addon_path)
cdsinit:                                loadi(addon_path)
cdsinit:                        else
cdsinit:                                printf("*LF-WARN* %s is not avaliable \n" addon_path)
cdsinit:                        );if
cdsinit:                );foreach
cdsinit:        );when
cdsinit
cdsinit:;; END PDK ADDONs specific entries do not touch --
cdsinit:
cdsinit:
cdsinit:;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
cdsinit:;;  opening the library manager
cdsinit:
cdsinit:let((b_openLibManger)
cdsinit:b_openLibManger=t
cdsinit:if( b_openLibManger then
cdsinit:         ddsOpenLibManager( )
cdsinit:         printf( "*LF-INFO* .cdsinit: Opening library manager                                   done\n" )
cdsinit:else
cdsinit:         printf( "*LF-INFO* .cdsinit: Opening library manager                           skipped\n" )
cdsinit:) ;; close if b_openLibManger
cdsinit:)
cdsinit:
cdsinit:let(
cdsinit:        (
cdsinit:                addon_path
cdsinit:        )
cdsinit:                        else
cdsinit:                        );if
cdsinit:                );foreach
cdsinit:        );when
cdsinit:)
cdsinit:
cdsinit:
cdsinit:
cdsinit:else
cdsinit:)
cdsinit:
cdsinit:;; load( strcat( getShellEnvVar("CALIBRE_HOME") "/lib/calibre.skl" ))
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib':
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:    defines 'DMTYPE none'.
cdslibinfo:Info (cdsinfo): Library checking is off, CDSLIBRARY entries will not be used.
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/etc/cdsDefTechLib/cdsinfo.tag
cdslibinfo:has a CDSLIBRARY entry defined.
cdslibinfo:    defines 'NAMESPACE libraryUnix'.
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic':
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/basic/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths':
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/sheets/US_8ths/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib':
cdslibinfo:Info (cdsinfo): could not locate an entry for 'DMTYPE' in any cdsinfo.tag file.
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfExamples/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/ahdlLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib/cdsinfo.tag
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/samples/artist/rfTlineLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib':
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/analogLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional':
cdslibinfo:The cdsinfo.tag file at: /opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:/opt/cadence/IC618/tools.lnx86/dfII/etc/cdslib/artist/functional/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/db/cnVPcellLib':
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/db/cnVPcellLib/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/tools/plugins/PyCellStudio_linux_gcc483_64_L-2019.06-SP1_Py262/db/cnVPcellLib/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/common/lf11isdhvt7s':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/common/lf11isdhvt7s/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/common/lf11isdhvt7s/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11is':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11is/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11is/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isChipFn':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isChipFn/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isChipFn/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isPixel':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isPixel/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11isPixel/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO1v2hvt':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO1v2hvt/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO1v2hvt/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO3v3hvt':
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO3v3hvt/cdsinfo.tag
cdslibinfo:/home/meow/Design/LF110/PDK_LF11ISi_V1_3_2/analog/libraries/4metal/lf11ispIO3v3hvt/cdsinfo.tag
cdslibinfo:cdsinfo searching relative to '/home/meow/Design/LF110_Workarea/test':
cdslibinfo:/home/meow/Design/LF110_Workarea/test/cdsinfo.tag
cdslibinfo:The cdsinfo.tag file at: /home/meow/Design/LF110_Workarea/test/cdsinfo.tag
xdpyinfo:name of display:    :0
xdpyinfo:version number:    11.0
xdpyinfo:vendor string:    The X.Org Foundation
xdpyinfo:vendor release number:    12004000
xdpyinfo:X.Org version: 1.20.4
xdpyinfo:maximum request size:  16777212 bytes
xdpyinfo:motion buffer size:  256
xdpyinfo:bitmap unit, bit order, padding:    32, LSBFirst, 32
xdpyinfo:image byte order:    LSBFirst
xdpyinfo:number of supported pixmap formats:    7
xdpyinfo:supported pixmap formats:
xdpyinfo:    depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo:    depth 4, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo:    depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range:    minimum 8, maximum 255
xdpyinfo:focus:  window 0x2400007, revert to Parent
xdpyinfo:number of extensions:    28
xdpyinfo:    BIG-REQUESTS
xdpyinfo:    Composite
xdpyinfo:    DAMAGE
xdpyinfo:    DOUBLE-BUFFER
xdpyinfo:    DPMS
xdpyinfo:    DRI2
xdpyinfo:    GLX
xdpyinfo:    Generic Event Extension
xdpyinfo:    MIT-SCREEN-SAVER
xdpyinfo:    MIT-SHM
xdpyinfo:    Present
xdpyinfo:    RANDR
xdpyinfo:    RECORD
xdpyinfo:    RENDER
xdpyinfo:    SECURITY
xdpyinfo:    SHAPE
xdpyinfo:    SYNC
xdpyinfo:    VMWARE_CTRL
xdpyinfo:    X-Resource
xdpyinfo:    XC-MISC
xdpyinfo:    XFIXES
xdpyinfo:    XFree86-DGA
xdpyinfo:    XFree86-VidModeExtension
xdpyinfo:    XINERAMA
xdpyinfo:    XInputExtension
xdpyinfo:    XKEYBOARD
xdpyinfo:    XTEST
xdpyinfo:    XVideo
xdpyinfo:default screen number:    0
xdpyinfo:number of screens:    1
xdpyinfo:screen #0:
xdpyinfo:  dimensions:    3478x1938 pixels (920x512 millimeters)
xdpyinfo:  resolution:    96x96 dots per inch
xdpyinfo:  depths (7):    24, 1, 4, 8, 15, 16, 32
xdpyinfo:  root window id:    0x17d
xdpyinfo:  depth of root window:    24 planes
xdpyinfo:  number of colormaps:    minimum 1, maximum 1
xdpyinfo:  default colormap:    0x20
xdpyinfo:  default number of colormap cells:    256
xdpyinfo:  preallocated pixels:    black 0, white 16777215
xdpyinfo:  options:    backing-store WHEN MAPPED, save-unders NO
xdpyinfo:  largest cursor:    64x64
xdpyinfo:  current input event mask:    0xda0003
xdpyinfo:    KeyPressMask             KeyReleaseMask           StructureNotifyMask
xdpyinfo:    SubstructureNotifyMask   SubstructureRedirectMask PropertyChangeMask
xdpyinfo:    ColormapChangeMask
xdpyinfo:  number of visuals:    108
xdpyinfo:  default visual id:  0x21
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x21
xdpyinfo:    class:    TrueColor
xdpyinfo:    depth:    24 planes
xdpyinfo:    available colormap entries:    256 per subfield
xdpyinfo:    red, green, blue masks:    0xff0000, 0xff00, 0xff
xdpyinfo:    significant bits in color specification:    8 bits
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x22
xdpyinfo:    class:    DirectColor
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x113
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x114
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x115
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x116
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x117
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x118
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x119
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x11f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x120
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x121
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x122
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x123
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x124
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x125
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x126
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x127
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x128
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x129
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x12f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x130
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x131
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x132
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x133
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x134
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x135
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x136
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x137
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x138
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x139
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x13f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x140
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x141
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x142
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x143
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x144
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x145
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x146
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x147
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x148
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x149
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x14f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x150
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x151
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x152
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x153
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x154
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x155
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x156
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x157
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x158
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x159
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x15f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x160
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x161
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x162
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x163
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x164
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x165
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x166
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x167
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x168
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x169
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16b
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16c
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16d
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16e
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x16f
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x170
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x76
xdpyinfo:    depth:    32 planes
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x171
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x172
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x173
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x174
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x175
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x176
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x177
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x178
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x179
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x17a
xdpyinfo:  visual:
xdpyinfo:    visual id:    0x17b
sysconf:=======================================================================
sysconf:[Copyright 2002-2022] Cadence Design Systems, Inc. All rights reserved.
sysconf:This  program and online  documentation  may not be copied, modified,
sysconf:re-published, uploaded,  executed, or  distributed in any way, in any
sysconf:medium, whether in whole or in part, without prior written permission
sysconf:from Cadence Design Systems, Inc.
sysconf:============== checkSysConf:  Version 3.51 ====================
sysconf:Configuration checks failed on this workstation (chiara), status is: FAIL
sysconf:This operating system version '8.0WS' is not supported
sysconf:If you believe you are running a supported OS then check that
sysconf:the OS version directory exists in the data directory:
sysconf:/opt/cadence/IC618/share/patchData/Linux/x86_64
sysconf:Exiting checkSysConf ... Good-bye
sysconf:Output is saved as /tmp/checkSysConf.chiara-2024.09.20.16:18.7790.log
 楼主| 发表于 2024-9-21 01:09:06 来自手机 | 显示全部楼层
换了个IC231的虚拟机试了试,这次都不弹崩溃界面了。看shell里面似乎是PDK带的PyCell插件的问题。python在导入sys初始化的时候error了。还有一个非法的unicode.
发表于 2024-9-29 20:28:20 | 显示全部楼层
遇到同样的问题了,顶下
 楼主| 发表于 2024-10-25 19:42:55 | 显示全部楼层
gzll 发表于 2024-9-29 20:28
遇到同样的问题了,顶下
我已经放弃618了,感觉就是工艺库的问题,在617下就没啥问题。
发表于 2024-10-28 11:24:30 | 显示全部楼层
换个231不香么。反正你都全部23了
GMT+8, 2025-12-17 06:46 , Processed in 0.031018 second(s), 3 queries , Gzip On, Redis On.
