查看: 1319|回复: 5
[讨论] Post layout simulation output value difference from Pre schematic simulation.
发表于 2024-8-23 13:16:34 | 显示全部楼层 |阅读模式
Post Layout Simulation Output value is diffrent from pre simulation circuit. Could you please anyone guide to resolve this error?
Here I have given VDD DC supply voltage = 2 V
发表于 2024-8-23 14:40:20 | 显示全部楼层
LVS PASS了么 感觉简单的电路功能有问题 有可能是设置问题 PIN的顺序正确么
 楼主| 发表于 2024-8-23 14:47:50 | 显示全部楼层
Ya. It passed the LVS, and Calibre pex. ya pins are connected. could you please suggest the what is setting problem?
发表于 2024-8-26 10:59:42 | 显示全部楼层
感觉衬底打错了啊。如果黄色的是nwell,那么旁边的衬底也应该有nwell啊
 楼主| 发表于 2024-8-26 19:30:33 | 显示全部楼层
yellow one is P+ implant. after the pmos is detached n+ implant (blue one) is generated. pmos is designed under the nwell (purple). nmos is designed using pwell. then also the post and pre simulation values are same.
发表于 2024-12-2 09:38:33 | 显示全部楼层
感谢,我也是想知道的
GMT+8, 2025-12-25 18:35 , Processed in 0.580183 second(s), 5 queries , Gzip On, Redis On.
