仿真时报错
Fatal error found by spectre during Ahdl read-in.
FATAL (VACOMP-2096): File '/home/SMIC_018_MMRF/smic18mmrf/../models/spectre/res.def' does not appear to be a valid verilog-A file. In previous releases, '.def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this file is a SpectreHDL file, you need to replace it with an equivalent Verilog-A file.
将models/spectre/res.def和models/spectre/res_rf.def进行修改,并且修改相应的.ckt文件。
修改.def文件的内容并且改后缀为.va文件,两个都要改。附上修改前后对比图,和修改后的文件。
修改.ckt文件,.def要变成.va,有两个文件要修改。
补充说明:如果看了图片知道def文件修改的语法(改成Verilog-A语法),可按照示例进行修改,不用下载附件。
res.rar
1.35 KB, 下载次数: 78
, 下载积分:
资产 -2 信元, 下载支出 2 信元
res.def_to_res.va
