查看: 1075|回复: 0
[求助] 在使用DFT做ATPG时scan chain问题
发表于 2024-7-24 17:19:41 | 显示全部楼层 |阅读模式
在使用Modus工具做atpg时,在verify_test_structure步骤中,报了TSV-400和TSV-571的warning
即observable scan chain ending at pin A[1] is not a controllable scan chain, the last observation flop that was found in the scan chain is unidentified.
a scan in pin B[1] does not feed to a scan out, a multiple-input signature register ( MISR ) input, pattern generator, or a controllable latch
同时会报告TSV-311的severe warning,运行停止
即 more than one clock input to memory element blobk ABC is not off ( at logic zero ) during the scan operation
有没有大佬指点一下
这是不是跟assign file中指定的SE有关,因为我用gui去查看的时候发现,一些module的DFT_se信号的source为0,像是只有一条悬空的线
GMT+8, 2025-12-16 18:24 , Processed in 0.062396 second(s), 4 queries , Gzip On, Redis On.
