查看: 1310|回复: 2
[求助] ERROR
发表于 2024-7-24 17:07:27 | 显示全部楼层 |阅读模式
Netlisting failed because the function 'hnlNetNameOnTerm' was called with a non-existent terminal 'vd11' on the current instance 'I27' in the design '003.SAR_ADC/0_TB_TOP2_tb/schematic'. Provide a valid terminal name with this function and regenerate the netlist.\n\n"
发表于 2024-7-25 09:34:12 | 显示全部楼层
都把答案告诉你了,你找个翻译软件翻译下把
发表于 2024-7-25 09:46:03 | 显示全部楼层
你的'I27' 这个电路的pin:vd11电路上和symbol不匹配,重新打开该电路,检查一下,然后check and save
GMT+8, 2025-10-6 11:52 , Processed in 0.012447 second(s), 3 queries , Gzip On, Redis On.
