查看: 3031|回复: 2
[求助] Cadence创建functional文件报错
发表于 2024-7-9 18:41:57 | 显示全部楼层 |阅读模式
悬赏10资产未解决
Verilog写functional文件的时候报错:
*Error* _gets: argument #1 should be an I/O port (type template = "p") - nil
*WARNING* (TE-1308): Failed to perform syntax check for cellview 'sim_Y test_nand functional'.
*WARNING* (TE-1312): Compilation errors or warnings have been detected in the HDL file for cellview 'sim_Y test_nand functional'. To view the parse log for details, choose 'Parser Log File' from the 'View' menu.
*WARNING* (TE-4309): Extract failed for cellview 'sim_Y test_nand functional'
文件中没有使用_get函数,只是一个简单的信号发生器:
/Verilog HDL for "Amp_forweb", "nand_tb" "functional"
`timescale 1ns/1ns
module nand_tb (
output reg A, B
initial begin
    A = 0;
    B = 0;
end
always begin
    #2 A = ~A;
end
always begin
    #1 B = ~B;
end
endmodule
发表于 2024-8-5 13:45:54 | 显示全部楼层
解决了吗hxd
 楼主| 发表于 2024-8-23 12:28:07 | 显示全部楼层
Gaozheng 发表于 2024-8-5 13:45
解决了吗hxd
没解决,可能因为没有AMS的仿真器incisive或者Xcelium
Cadence官网上的AMS相关课程的软件要求。https://www.cadence.com/en_US/ho ... -courses/85059.html
我在电脑上找到了incisive的安装包,用Cadence自带的安装软件Iscape安装之后就没有这个错误了,但是在仿真最后关头卡在了license上,我也就没再继续了。
GMT+8, 2025-9-16 03:15 , Processed in 0.023851 second(s), 3 queries , Gzip On, Redis On.
