查看: 1063|回复: 0
[求助] GENUS加载工艺库后报Warning
发表于 2024-6-28 11:29:56 | 显示全部楼层 |阅读模式
GENUS191加载工艺库后报多个类似Warning:
Warning : Detected both combinational and sequential timing arcs in a library cell. This might prevent the tool from using this cell for technology mapping. The tool will treat it as unusable. [LBR-76]
        : The arc 'CK_E_Ha0' between pins 'CK' and 'E' in libcell 'TLATNCAX12' is a sequential timing arc.
        : The library cell will be treated as a timing-model. Make sure that the timing arcs and output function are defined correctly. Even if the cell intends to have dual-functionality, it cannot be unmapped or automatically inferred.
TLATNCAX12是时钟门控单元,是否GENUS191不支持这种结构?Warning说不能自动推断出该单元,那么是否可以直接实例化?
GMT+8, 2025-12-26 22:14 , Processed in 0.013062 second(s), 3 queries , Gzip On, Redis On.
