查看: 1895|回复: 3
[求助] virtuoso导入GDS的警告,WARNING (XSTRM-107): WARNING (XSTRM-31): ,并且无版图显示
发表于 2024-5-30 21:36:16 | 显示全部楼层 |阅读模式
将innovus导出的GDS导入virtuoso。导入后没有版图显示,报如下警告,为什么?怎么改?求大佬指点
Product   : Virtuoso(R) XStream In
Program   : @(#)$CDS: strmin version 6.1.8-64b 05/03/2023 09:40 (sjfhw317) $
          : sub-version  IC6.1.8-64b.500.32
Started at: 30-May-2024  21:24:22
User Name : wang.zhaobin
Host Name : centos8
Directory : /team/advisor/wang.zhaobin/chenjie/UART24.4.28/vitrsuo
CADENCE Design Systems, Inc.
Info: Cellview Rev Num:99,  Tech Rev Num:59
WARNING (XSTRM-107): Existing cells in the target library will be overwritten if the cell names in the Stream file and the target library are the same. To prevent this, set the '-writeMode' option to 'noOverwrite'.
INFO (XSTRM-217): Reading the layer map file, /team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '41:0' at line '555'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '46:0' at line '556'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '48:0' at line '557'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '50:0' at line '558'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '52:0' at line '559'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '54:0' at line '560'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '56:0' at line '561'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '58:0' at line '562'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '60:0' at line '563'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '67:0' at line '564'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '41:0' at line '565'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '46:0' at line '566'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '48:0' at line '567'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '50:0' at line '568'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '52:0' at line '569'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '54:0' at line '570'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '56:0' at line '571'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '58:0' at line '572'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '60:0' at line '573'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '67:0' at line '574'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '41:0' at line '575'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '46:0' at line '576'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '48:0' at line '577'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '50:0' at line '578'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '52:0' at line '579'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '54:0' at line '580'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '56:0' at line '581'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '58:0' at line '582'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '60:0' at line '583'. Therefore, this entry will be ignored during translation.
WARNING (XSTRM-31): Layer map file '/team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap' contains a duplicate entry for Stream layer-datatype '67:0' at line '584'. Therefore, this entry will be ignored during translation.
INFO (XSTRM-163): You have not used the '-viaMap' option. If a viaMap file, corresponding technology file or technology library exist, then use the '-viaMap' option for creating oaVia instances in the Streamed-In library. Using the '-viaMap' option improves performance and VM usage of applications using the Streamed-In design.
Summary of Options:
        library                         umc110ae
        strmFile                        /team/advisor/wang.zhaobin/chenjie/test/innovus/output/top_control.gds
        logFile                         strmIn.log
        topCell                         top_control
        view                            layout
        case                            Preserve
        layerMap                        /team/advisor/wang.zhaobin/Tech/UMC/umc110ae/umc110ae.layermap
        propSeparator                   ,
INFO (XSTRM-80075): Via detection cannot use a stdViaDef for "top_control_genm5m6_12" due to rounding errors. A customViaDef has been used instead. Use the -dbuPerUU option to increase the DBUperUU to enable detection of stdViaDef.
WARNING (XSTRM-81142): Custom via definition 'top_control_genm5m6_12' in the technology library has been updated with the new custom via definition found in the GDS file.
INFO (XSTRM-220): 1. Translating STRUCTURE BUFM12HM as cellView umc110ae/BUFM12HM/layout.
INFO (XSTRM-220): 2. Translating STRUCTURE BUFM2HM as cellView umc110ae/BUFM2HM/layout.
INFO (XSTRM-220): 3. Translating STRUCTURE DEL3M1HM as cellView umc110ae/DEL3M1HM/layout.
INFO (XSTRM-220): 4. Translating STRUCTURE BUFM4HM as cellView umc110ae/BUFM4HM/layout.
INFO (XSTRM-220): 5. Translating STRUCTURE DEL4M1HM as cellView umc110ae/DEL4M1HM/layout.
INFO (XSTRM-220): 6. Translating STRUCTURE DEL2M1HM as cellView umc110ae/DEL2M1HM/layout.
INFO (XSTRM-220): 7. Translating STRUCTURE DEL4M4HM as cellView umc110ae/DEL4M4HM/layout.
INFO (XSTRM-220): 8. Translating STRUCTURE DEL1M1HM as cellView umc110ae/DEL1M1HM/layout.
INFO (XSTRM-220): 9. Translating STRUCTURE BUFM8HM as cellView umc110ae/BUFM8HM/layout.
INFO (XSTRM-220): 10. Translating STRUCTURE DEL1M4HM as cellView umc110ae/DEL1M4HM/layout.
INFO (XSTRM-220): 11. Translating STRUCTURE DEL2M4HM as cellView umc110ae/DEL2M4HM/layout.
INFO (XSTRM-220): 12. Translating STRUCTURE DEL3M4HM as cellView umc110ae/DEL3M4HM/layout.
INFO (XSTRM-220): 13. Translating STRUCTURE CKBUFM16HM as cellView umc110ae/CKBUFM16HM/layout.
INFO (XSTRM-220): 14. Translating STRUCTURE CKBUFM8HM as cellView umc110ae/CKBUFM8HM/layout.
INFO (XSTRM-220): 15. Translating STRUCTURE CKBUFM20HM as cellView umc110ae/CKBUFM20HM/layout.
 楼主| 发表于 2024-5-31 10:51:09 | 显示全部楼层
自己顶一下
发表于 2024-11-25 11:37:18 | 显示全部楼层
大佬你好,可以问一下你解决了吗
发表于 2024-12-20 17:37:20 | 显示全部楼层
东木 发表于 2024-5-31 10:51
自己顶一下
除了warning的提示外,没有error的提示吗?
GMT+8, 2025-12-18 15:00 , Processed in 0.014520 second(s), 4 queries , Gzip On, Redis On.
