查看: 1741|回复: 5
[求助] 斩波运放PSS仿真保存
发表于 2024-5-28 11:54:15 | 显示全部楼层 |阅读模式
悬赏500资产未解决
求教大家!!
斩波运放跑PAC,PNOISE,PSTB之前都需要先跑一遍PSS,找到收敛点之后才能进行下一步仿真,感觉有些费时,之前老师有说可以把PSS仿真收敛先保存下来,之后直接进行读取,就可以省略PSS这一步了,请问各位前辈有懂具体操作的吗,感激不尽!
发表于 2024-5-28 13:26:22 | 显示全部楼层
蹲蹲  我只了解过pss瞬态可以断点续仿  PSS收敛过程不是很清楚
发表于 2024-5-28 13:40:22 | 显示全部楼层
发表于 2024-5-28 16:51:18 | 显示全部楼层
或许应该试试"Reuse"菜单中的
41      writepss          File to which the converged steady-state solution is written. The file of shooting and HB cannot be mutually reused.
42      readpss           File from which a previously converged steady-state solution is read. For shooting method, PSS loads the solution and checks the residue of the circuit equations
                          only. The solution is re-used if the residue is satisfactory. Otherwise, the solution is re-converged using the finite difference method. The results from shooting
                          QPSS cannot be used in HB QPSS analysis and vice-versa.
 楼主| 发表于 2024-6-6 15:54:23 | 显示全部楼层
已解决
发表于 2025-1-13 15:16:15 | 显示全部楼层
怎么解决的楼主
GMT+8, 2025-12-13 16:05 , Processed in 0.085569 second(s), 3 queries , Gzip On, Redis On.
