查看: 2127|回复: 4
[求助] cadence 仿真spectre问题(无法预处理)
发表于 2024-5-21 11:29:53 | 显示全部楼层 |阅读模式
求助,在仿真时出现error
Loading /opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
Loading /opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Error found by spectre.
    ERROR (SPECTRE-15): Unable to run circuit preprocessor (/lib/cpp).
        No such file or directory.
spectre terminated prematurely due to fatal error.
这列提示找不到/lib/cpp 但是不知道这个文件该在哪里找
 楼主| 发表于 2024-5-21 12:54:26 | 显示全部楼层
已解决
方法:
According to http://support.cadence.com Article 1841055, this error means that Spectre couldn't find the c pre-processor file cpp at /lib/cpp. This can be resolved by reinstalling the operating system component which will install all the c language utilities, including the c pre-processor cpp that the Spectre simulator requires.
yum -y install gcc
yum -y install gcc-c++
发表于 2025-2-20 17:00:34 | 显示全部楼层
阿波次德 发表于 2024-5-21 12:54
已解决
方法:
According to http://support.cadence.com Article 1841055, this error means that Spectre ...
感谢
发表于 2025-5-20 22:53:51 | 显示全部楼层
已解决
方法:
感谢
发表于 5 天前 | 显示全部楼层
感谢
GMT+8, 2025-11-5 08:39 , Processed in 0.014627 second(s), 3 queries , Gzip On, Redis On.
