查看: 1593|回复: 2
[求助] cadence瞬态仿真报错
发表于 2024-5-21 10:19:00 | 显示全部楼层 |阅读模式
    tran: time = 15.57 ms    (15.6 %), step = 5.056 ps    (5.06 n%)
    tran: time = 15.57 ms    (15.6 %), step = 8.414 ps    (8.41 n%)
    tran: time = 15.57 ms    (15.6 %), step = 9.502 ps     (9.5 n%)
    tran: time = 15.57 ms    (15.6 %), step = 3.375 ps    (3.37 n%)
    tran: time = 15.57 ms    (15.6 %), step = 5.329 ps    (5.33 n%)
Internal error found in spectre at time = 15.5721 ms during transient analysis `tran'.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
    FATAL (SPECTRE-18): Segmentation fault.
振荡器仿真过程中每次都会在这个时间节点报错 然后跳出仿真(内存够用),请问是什么原因?求大佬指点
发表于 2024-5-21 15:37:08 | 显示全部楼层
看看有没有短路的地方,或者对地电容容值过大什么的,瞬态跑一会儿就报错一般都是电路问题,软件一般不会有啥问题的
 楼主| 发表于 2024-5-31 17:01:13 | 显示全部楼层
问题已解决:
方式1:查看内存是否充足,释放内存,删除simulation的数据
方式2:更换启动文件61.cshrc的版本,从618换为617
GMT+8, 2025-12-29 06:30 , Processed in 0.024768 second(s), 5 queries , Gzip On, Redis On.
