查看: 4961|回复: 36
[资料] c家modus ATPG工具
发表于 2024-5-21 01:57:55 | 显示全部楼层 |阅读模式
HardwareModus requires one of the following hardware platforms.Unix and Linux based workstations:
X86 and X86_64 architectures running Linux
              RHEL 7.4 (RedHat) - 64 bit
                RHEL 7.6 (RedHat) - 64 bit
                RHEL 7.7 (RedHat) - 64 bit
                RHEL 7.8 (RedHat) - 64 bit
                RHEL 7.9 (RedHat) - 64 bit
                RHEL 8.1 (RedHat) - 64 bit
                RHEL 8.2 (RedHat) - 64 bit
                RHEL 8.4 (RedHat) - 64 bit
                RHEL 8.5 (RedHat) - 64 bit
                RHEL 8.6 (RedHat) - 64 bit
                RHEL 9.0 (RedHat) - 64 bit
                      SLES 12.0 SP3     - 64 bit
                SLES 12.0 SP4     - 64 bit
                SLES 12.0 SP5     - 64 bit
                SLES 15.0 SP2     - 64 bit
                SLES 15.0 SP4     - 64 bit
                LoP (Linux on Power) RedHat 7.2
                LoP (Linux on Power) RedHat 8.4
                CentOS 7.4
                CentOS 7.7
The following table illustrates the Modus and Diagnostics product names,product numbers, their associated license keys, and an overview of providedfunction with each product.
Table 1-1  License Key Map to Modus Products
Product Name      Product   License Keys                 Function Overview
                           Number
Modus ATPG        MOD200    Modus_Test                   Automatic Test Pattern Generation
                                         Affirma_sim_analysis_env     SimVision Waveform Viewer
                                        Modus_common_ui              Common User Interface
Modus Diagnostics MOD300    Modus_Diagnostics            Diagnostics & Trend Analysis
Virtuoso Digital  VDT100    Virtuoso_digital_test              ATPG & Test  Diagnostics
        Note: While the full
        spectrum of ATPG
        and Diagnostics
        capabilities are
        provided through the
        Virtuoso Digital Test
        product, there are
        design size restrictions which
        apply. A single VDT100
        supports designs of up to
        50,000 technology cell instances
        and two VDT 100's support 100,000
        instances. Larger designs require
        either the VDL-XL Block Capacity
        option (3004) in combination with
        one VDT100 for designs of up to
        300,000 instances or ATPG or
        Diagnostics for designs larger
        than 300,000.
        Refer to 'Capacity-limited
        Licensing' for more information.
Modus D-ATPG     MOD204     modus_atpg                  Automatic Test Pattern Generation (ATPG) with distributed upgrade
Modus D-ATPG     MOD20      modus_atpg_mcpu            Extended CPU option for Modus D-ATPG
CPU Option        (up to 64 CPU’s)
Modus Memory     MOD40      Modus_PMBIST_Opt           Programmable Memory
BIST Option        Built-in Self-Test Option
Modus Logic      MOD50      Modus_LBIST_Opt            Logic Built-in
BIST Option                                                             Self-Test Option
Modus            MOD60      Modus_Hierarchical_Opt     Hierarchical Test and
Hierarchical                                                           Diagnostics Option
Option
VDI-XL Block Capacity Option   3004     Vdixl_Capacity_Opt          Extended capacity option for Virtuoso
        Digital Test (VDT100). This product
        may be used in conjunction with VDT100
        to process designs of up to 300,000
        technology cell instances. Larger
        designs will require ATPG or Diagnostics.
        Refer to "Capacity-limited Licensing" for more information.
The What's New manual lists out specific functions and license requirements associated withthe various Modus Options. The functionality available under a specificcommand may vary depending on the available product or license.
Tool Compatibility
Modus 23.10 is compatible with:
* Genus 22.10
* IC 6.1.8 (Virtuoso)
modus231.txt (84 Bytes , 下载次数: 153 )
发表于 2024-5-21 14:16:45 | 显示全部楼层
kankan
发表于 2024-5-21 14:56:20 | 显示全部楼层
好东西,感谢分享
发表于 2024-5-21 21:01:31 | 显示全部楼层
感谢分享
发表于 2024-5-21 21:38:12 | 显示全部楼层
kankan
发表于 2024-5-21 21:49:48 | 显示全部楼层
多谢分享
发表于 2024-5-21 22:10:14 | 显示全部楼层
Hope to read the content. Thank you very much.
发表于 2024-5-21 22:12:58 | 显示全部楼层
Thank you again and again.
发表于 2024-5-22 00:06:02 | 显示全部楼层
多谢分享
发表于 2024-5-22 07:21:36 | 显示全部楼层
kan xie
GMT+8, 2025-10-26 06:00 , Processed in 0.021079 second(s), 3 queries , Gzip On, Redis On.
