查看: 13836|回复: 49
[原创] 【Kluwer 1999】Surviving the SOC Revolution - A Guide to Platform-Based Design
发表于 2008-2-15 21:09:19 | 显示全部楼层 |阅读模式
[size=120%]Surviving the SOC Revolution - A Guide to Platform-Based Design
By Henry Chang, L.R. Cooke, Merrill Hunt, Grant Martin, Andrew McNelly, Lee Todd
Publisher:   Springer
Number Of Pages:   256
Publication Date:   1999-11-01
ISBN-10 / ASIN:   0792386795
ISBN-13 / EAN:   9780792386797
Binding:   Hardcover
Book Description:
The aim of Surviving the SOC Revolution: A Guide to Platform-Based Design is to provide the engineering community with a thorough understanding of the challenges involved when moving to system-on-a-chip and deliver a step-by-step methodology to get them there.
Design reuse is most effective in reducing the cost and development time when the components to be shared are close to the final implementation. On the other hand, it is not always possible or desirable to share designs at this level, since minimal variations in specification can result in different, albeit similar, implementations. However, moving higher in abstraction can eliminate the differences among designs, so that the higher level of abstraction can be shared and only a minimal amount of work needs to be carried out to achieve final implementation.
The ultimate goal is to create a library of functions and of hardware and software implementations that can be used for all new designs. It is important to have a multilevel library, since it is often the case that the lower levels that are closer to the physical implementation change because of the advances in technology, while the higher levels tend to be stable across product versions.
It is most likely that the preferred approaches to the implementation of complex embedded systems will include the following aspects: Design costs and time are likely to dominate the decision-making process for systems designers. Therefore, design reuse in all its shapes and forms will be of paramount importance. Designs have to be captured at the highest level of abstraction to be able to exploit all the degrees of freedom that are available. Next-generation systems will use a few highly complex (Moore's Law Limited) part-types, but many more energy-power-cost-efficient, medium-complexity (10M-100M) gates in 50nm technology chips, working concurrently to implement solutions to complex sensing, computing, and signaling/actuating problems. Such chips will most likely be developed as an instance of a particular platform. That is, rather than being assembled from a collection of independently developed blocks of silicon functionality, they will be derived from a specific `family' of rnicro-architectures, possibly oriented toward a particular class of problems, that can be modified (extended or reduced) by the system developer. These platforms will be highly programmable. Both system and software reuse impose a design methodology that has to leverage existing implementations available at all levels of abstraction. £/LIST£
This book deals with the basic principles of a design methodology that addresses the concerns expressed above. The platform concept is carried throughout the book as a unifying theme to reuse. This is the first book that deals with the platform-based approach to the design of embedded systems and is a stepping stone for anyone who is interested in the real issues facing the design of complex systems-on-chip.
From the Preface by Alberto Sangiovanni-Vincentelli
Surviving the SOC Revolution A Guide to Platform-based Design.rar
4.76 MB, 下载次数: 414 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2008-2-15 21:33:48 | 显示全部楼层
书太旧了,跟不上形势了
发表于 2008-2-16 00:50:59 | 显示全部楼层
楼上的!不懂就不要乱灌水!
发表于 2008-2-16 05:22:29 | 显示全部楼层
thanks for sharing
发表于 2008-2-18 08:33:07 | 显示全部楼层
好东西
谢谢楼主
发表于 2008-2-24 17:57:18 | 显示全部楼层
Thanks!
发表于 2008-2-25 01:58:14 | 显示全部楼层
多谢分享!
发表于 2008-6-14 00:43:35 | 显示全部楼层
dingg ding
发表于 2008-6-14 11:15:21 | 显示全部楼层
发表于 2008-6-21 01:29:05 | 显示全部楼层
thanks
GMT+8, 2025-12-26 04:48 , Processed in 0.029710 second(s), 7 queries , Gzip On, Redis On.
