/ The rst_flag is the synced version of rst_n
// * rst_n is asserted
// The rst_flag will be clear when
// * rst_n is de-asserted
wire reset_flag_r;
sirv_gnrl_dffrs #(1) reset_flag_dffrs (1'b0, reset_flag_r, clk, rst_n);
// The reset_req valid is set when
// * Currently reset_flag is asserting
// The reset_req valid is clear when
// * Currently reset_req is asserting
// * Currently the flush can be accepted by IFU
wire reset_req_r;
wire reset_req_set = (~reset_req_r) & reset_flag_r;
wire reset_req_clr = reset_req_r & ifu_req_hsked;
wire reset_req_ena = reset_req_set | reset_req_clr;
wire reset_req_nxt = reset_req_set | (~reset_req_clr);
sirv_gnrl_dfflr #(1) reset_req_dfflr (reset_req_ena, reset_req_nxt, reset_req_r, clk, rst_n);
wire ifu_reset_req = reset_req_r;
这是取指模块e203_ifu_ifetch.v中的一段代码,没见过这种写法,不理解复位信号为什么这样处理?
