查看: 1188|回复: 1
[求助] SiliconSmart软件tutorial中LAB2报错
发表于 2024-4-24 14:07:26 | 显示全部楼层 |阅读模式
Error:   error {child process exited abnormally} verbose {child process exited abnormally     while executing "exec egrep -e WARNING -e Error -e Info $taluslog"     (procedure "cell_import::recognizeFunction" line 546)     invoked from within "cell_import::recognizeFunction  $liberty_file  options  $options(args)  cells  $netlistType $importSkeletonOnly "} (DFFX1)
Error:   Task 4 (import of DFFX1) failed on W2 (cu02) with return value 0 (CDPL-11)
Error:   error {child process exited abnormally} verbose {child process exited abnormally     while executing "exec egrep -e WARNING -e Error -e Info $taluslog"     (procedure "cell_import::recognizeFunction" line 546)     invoked from within "cell_import::recognizeFunction  $liberty_file  options  $options(args)  cells  $netlistType $importSkeletonOnly "} (INVX1)
Error:   Task 5 (import of INVX1) failed on W4 (cu02) with return value 0 (CDPL-11)
Error:   error {child process exited abnormally} verbose {child process exited abnormally     while executing "exec egrep -e WARNING -e Error -e Info $taluslog"     (procedure "cell_import::recognizeFunction" line 546)     invoked from within "cell_import::recognizeFunction  $liberty_file  options  $options(args)  cells  $netlistType $importSkeletonOnly "} (MUX2X1)
Error:   Task 6 (import of MUX2X1) failed on W3 (cu02) with return value 0 (CDPL-11)
Error:   error {child process exited abnormally} verbose {child process exited abnormally     while executing "exec egrep -e WARNING -e Error -e Info $taluslog"     (procedure "cell_import::recognizeFunction" line 546)     invoked from within "cell_import::recognizeFunction  $liberty_file  options  $options(args)  cells  $netlistType $importSkeletonOnly "} (NANDX1)
请问这个error怎么解决。只是把configure.tcl中默认仿真器finesim改为了hspice
发表于 2025-7-4 10:34:13 | 显示全部楼层
楼主解决了吗,同问
GMT+8, 2025-10-30 00:54 , Processed in 0.010875 second(s), 4 queries , Gzip On, Redis On.
