查看: 1754|回复: 2
[求助] 求助drc错误
发表于 2024-4-19 17:05:38 | 显示全部楼层 |阅读模式
Minimum dimension of an NW region not connected to the most
positive power supply is 2.10um.
Need to be changed depending on your power supply name
In this case the most positive voltage
请问这是什么drc错误呀
发表于 2024-4-19 17:42:02 | 显示全部楼层
你这个rule,应该有设置power name的option,可以把常用的power name写进去,然后连接到power name的nw区域需要达到2.1um?,并且是正电压。只有这么一句,没法判断更多
发表于 2025-4-22 15:55:40 | 显示全部楼层
加个NW就行
GMT+8, 2025-12-23 02:47 , Processed in 0.014027 second(s), 3 queries , Gzip On, Redis On.
