查看: 1556|回复: 1
[求助] innovus Master/Clone partition flow下如何build Htree Trunk
发表于 2024-3-22 10:40:40 | 显示全部楼层 |阅读模式
悬赏5000资产未解决
有没有朋友做过多Master/Clone partition (abut/feedthrough design flow)下的Htree Trunk Planning的?
以下命令感觉需要LimtedAcessFeature, 谁知道如何设置,让工具支持多master clone?
synthesize_ccopt_flexible_htrees
Running flexible H-tree synthesis in master/clone mode. Note that H-trees are not routed during H-tree synthesis in this case and a non-default H-tree routing flow is required. Also, the ccopt spec is removed at the end of H-tree synthesis.
**ERROR: (IMPSE-25):        You are using a Limited Access feature that requires special setup before you can use it. Please contact Cadence support for more information on how to access this feature.
谢谢
发表于 2024-3-23 17:42:33 | 显示全部楼层
我以前碰到过Genus的ispatial的feature也是limited access。后来升级版本后,这个就开放出来,在原来的版本上应该是没有成熟所以是limited。所以我觉得你升级innovus应该就可以了。如果你当前的版本是DDI23,那就等后续的更新吧。否则你试一下DDI23.
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 06:36 , Processed in 0.011289 second(s), 3 queries , Gzip On, Redis On.
