查看: 2896|回复: 4
[求助] Found 'module' inside module before 'endmodule'. 'module' inside 'module' is
发表于 2024-3-14 11:43:25 | 显示全部楼层 |阅读模式
悬赏10资产未解决
module sramc_top(
    //input signals
        hclk,
        sram_clk,
                hresetn,
                hsel,
                hwrite,
        hready,
                hsize,
                htrans,
                hburst,
                hwdata,
                haddr,
                dft_en,
                bist_en,
    //output signals
                hready_resp,
                hresp,
                hrdata,
                bist_done,
                bist_fail
  // list of AHB signals //
  //Signals used during normal operation
  input hclk;
  input sram_clk;
  input hresetn;
  //Signals from AMBA bus used during normal operation
  input        hsel;
  input        hwrite;
  input        hready;
  input [2:0]  hsize ;
  input [2:0]  hburst;
  input [1:0]  htrans;
  input [31:0] hwdata;
  input [31:0] haddr;
  //Signals to AMBA bus used during normal operation
  output        hready_resp;
  output [1:0]  hresp;
  output [31:0] hrdata;
  //Signals for BIST and DFT test mode
  //When signal"dft_en" or "bist_en" is high, sram
  //controller enters into test mode.
  input dft_en;
  input bist_en;
  //When "bist_done" is high, it shows BIST test is over.
  output bist_done;
  //"bist_fail" shows the results of each sram funtions.
  //There are 8 srams in this controller.
  output [7:0] bist_fail;
  //Select one of the two sram blocks according to the value of sram_csn
  wire [3:0] bank0_csn;
  wire [3:0] bank1_csn;
  //Sram read or write signals: When it is high, read sram; low, write
  //sram.
  wire  sram_w_en;
  //Each of 8 srams is 8kx8, the depth is 2^13, so the sram's address width
  //is 13 bits.
  wire [12:0] sram_addr;
  //AHB bus data write into srams
  wire [31:0] sram_wdata;
  //sram data output data which selected and read by AHB bus
  wire [7:0] sram_q0;
  wire [7:0] sram_q1;
  wire [7:0] sram_q2;
  wire [7:0] sram_q3;
  wire [7:0] sram_q4;
  wire [7:0] sram_q5;
  wire [7:0] sram_q6;
  wire [7:0] sram_q7;
  // Instance the two :           //
  // ahb_slave_if.v and sram_core.v      //
  ahb_slave_if U_ahb_slave_if(
                              // AHB input signals into sram controller
                              .hclk     (hclk),
                              .hresetn  (hresetn),
                              .hsel     (hsel),
                              .hwrite   (hwrite),
                              .hready   (hready),
                              .hsize    (hsize),
                              .htrans   (htrans),
                              .hburst   (hburst),
                              .hwdata   (hwdata),
                              .haddr    (haddr),
                              //8 sram blcoks data output into ahb slave
                              //interface
                              .sram_q0   (sram_q0),
                              .sram_q1   (sram_q1),
                              .sram_q2   (sram_q2),
                              .sram_q3   (sram_q3),
                              .sram_q4   (sram_q4),
                              .sram_q5   (sram_q5),
                              .sram_q6   (sram_q6),
                              .sram_q7   (sram_q7),
                              //AHB slave(sram controller) output signals
                              .hready_resp  (hready_resp),
                              .hresp        (hresp),
                              .hrdata       (hrdata),
                              //sram control signals and sram address
                                          .sram_w_en    (sram_w_en),
                                      .sram_addr_out(sram_addr),
                              //data write into sram
                                      .sram_wdata   (sram_wdata),
                              //choose the corresponding sram in a bank, active low
                              .bank0_csn    (bank0_csn),
                              .bank1_csn    (bank1_csn)
  sram_core U_sram_core(
                        //AHB bus signals
                        .hclk        (hclk    ),
                        .sram_clk    (sram_clk), // negetive of the hclk for system integration
                                          .hresetn     (hresetn ),
                        //sram control singals from ahb_slave_if.v
                                          .sram_addr    (sram_addr),
                                          .sram_wdata_in(sram_wdata),
                                          .sram_wen     (sram_w_en),
                                          .bank1_csn   (bank1_csn),
                        //test mode enable signals
                                          .bist_en     (bist_en),
                                          .dft_en      (dft_en),
                        //8 srams data output into AHB bus
                        .sram_q0    (sram_q0),
                        .sram_q1    (sram_q1),
                        .sram_q2    (sram_q2),
                        .sram_q3    (sram_q3),
                        .sram_q4    (sram_q4),
                        .sram_q5    (sram_q5),
                        .sram_q6    (sram_q6),
                        .sram_q7    (sram_q7),
                        //test results output when in test mode
                        .bist_done  (bist_done),
                        .bist_fail  (bist_fail)
endmodule
请问哪里有语法问题啊?
 楼主| 发表于 2024-3-14 14:37:12 | 显示全部楼层
跪求
发表于 2024-3-15 09:58:05 | 显示全部楼层
碰到这种问题就应该往前一个文件追
发表于 2024-3-17 04:29:21 | 显示全部楼层
还有一个办法就是对所有文件进行grep module关键字,发现module和endmodule不是一对的,肯定就是问题所在。
发表于 2024-5-25 09:46:20 来自手机 | 显示全部楼层
是不是前面的文件里面忘了写endmodule
GMT+8, 2025-12-27 06:31 , Processed in 0.016072 second(s), 4 queries , Gzip On, Redis On.
