查看: 1602|回复: 1
[求助] icc PSYN-1072 求解
发表于 2024-3-13 21:31:20 | 显示全部楼层 |阅读模式
  本人小白一个,目前在学习icc,在练习lab3,执行 place_opt -area_recovery -optimize_dft -power 后报错,下面是log,请问该怎么解决。
  lab是2010的,icc是2018的
Beginning Coarse Placement
Information: Running stand-alone coarse placer in a separate process using temp directory '/tmp'. (PSYN-605)
Information: Executable name is '/home/synopsys/icc/O-2018.06-SP1/linux64/syn/bin/rpsa_exec'.  (PSYN-877)
Severe Error: Fatal error: Placer did not complete. (PSYN-375)
Error: psynopt has abnormally terminated.  (OPT-100)
Error: place_opt results invalid due to placer failure.
Warning: ICC has suggestions for improving your design.  Use "report_suggestions" for details.  (PSYN-1067)
Error: Severe error encountered
        Use error_info for more info. (CMD-013)
icc_shell> report_suggestions
  Report : Suggestions
  Design : ORCA_TOP
  Version: O-2018.06-SP1
  Date   : Wed Mar 13 21:16:09 2024
   MSG ID  Incidents  Override code  Message
PSYN-1072          1      676087662  Scan chains not in scandef detected during initial placement.
                                     This can hurt clock speed and routability of your design because
                                     placement considers scan nets to be just like any other net.
                                     Suggestion:  make a scandef file and note all register pins
1
icc_shell> place_opt -area_recovery -optimize_dft -power -continue_on_missing_scandef
这是lab中的命令
这是lab中的命令
发表于 2024-3-14 06:22:59 | 显示全部楼层
New connections without risk of disappointment
Looking for a one-night partner
Authentic Damsels
回复 支持 0 反对 1
GMT+8, 2025-12-20 21:40 , Processed in 0.016472 second(s), 7 queries , Gzip On, Redis On.
