查看: 3109|回复: 9
Springer 2008——Active Sensor Planning for Multiview Vision Tasks
发表于 2008-2-12 11:49:56 | 显示全部楼层 |阅读模式
by S.Y. Shengyong Chen, Li Youfu, Jianwei Zhang, Wanliang Wang
[size=120%]Active Sensor Planning for Multiview Vision Tasks
By S.Y. Shengyong Chen, Li Youfu, Jianwei Zhang, Wanliang Wang
Publisher:   Springer
Number Of Pages:   266
Publication Date:   2008-03-01
ISBN-10 / ASIN:   3540770712
ISBN-13 / EAN:   9783540770718
Binding:   Hardcover
Book Description:
An active robot system can change its visual parameters in an intentional manner and perform its sensing actions purposefully. A general vision task thus can be performed in an efficient way by means of strategic control of the perception process. The controllable processes include 3D active sensing, sensor configuration and recalibration, automatic sensor placement, and 3D sensing. This book explores these important issues in studying for active visual perception.
Vision sensors have limited fields of views and can only "see" a portion of a scene from a single viewpoint. To make the entire object visible, the sensor has to be moved from one place to another around the object to observe all features of interest. The sensor planning presented in this book describes an effective strategy to generate a sequence of viewing poses and sensor settings for optimally completing a perception task. Several methods are proposed to solve the problems in both model-based and nonmodel-based vision tasks. For model-based applications, the method involves determination of the optimal sensor placements and a shortest path through these viewpoints for automatic generation of a perception plan. A topology of viewpoints is achieved by a genetic algorithm in which a min-max criterion is used for evaluation. A shortest path is also determined by graph algorithms. For nonmodel-based applications, the method involves determination of the best next view and sensor settings. The trend surface is proposed as the cue to predict the unknown portion of an object or environment.
The 11 chapters in Active Vision Planning draw on recent work in robot vision over ten years, particularly in the use of new concepts of active sensing, reconfiguration, recalibration, sensor model, sensing constraints, sensing evaluation, viewpoint decision, sensor placement graph, model based planning, path planning, planning for robot in unknown environment, dynamic 3D construction, surface prediction, etc. Implementation examples are also provided with theoretical methods for testing in a real robot system. With these optimal sensor planning strategies, this book will give the robot vision system the adaptability needed in many practical applications.
[ 本帖最后由 lotusky 于 2008-2-12 12:09 编辑 ]
Active Sensor Planning for Multiview Vision Tasks.part1.rar
3.72 MB, 下载次数: 80 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Active Sensor Planning for Multiview Vision Tasks.part2.rar
3.63 MB, 下载次数: 88 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-12 17:42:27 | 显示全部楼层
Thanks!
发表于 2008-2-12 17:43:42 | 显示全部楼层
Gooooooooooooooooood!
发表于 2008-5-18 14:28:22 | 显示全部楼层
关于传感器的,楼主是不是发错地方了。呵呵
发表于 2009-10-3 00:22:03 | 显示全部楼层
Thanks
发表于 2009-10-3 00:23:19 | 显示全部楼层
Thanks
发表于 2011-8-29 17:03:19 | 显示全部楼层
book about 3D camera
发表于 2011-11-29 20:06:04 | 显示全部楼层
Thanks for book
发表于 2011-12-2 17:29:59 | 显示全部楼层
Thanks!
发表于 2012-10-10 19:34:00 | 显示全部楼层
Thanks!Thanks!
GMT+8, 2025-10-8 20:59 , Processed in 0.021855 second(s), 6 queries , Gzip On, Redis On.
