查看: 2559|回复: 4
[解决] ams数模混合仿真
发表于 2024-3-2 11:08:27 | 显示全部楼层 |阅读模式
Netlist Error: Cannot find any info on instance "PORT2" in cell-view "mix_all" "mix_all_sim_test_6" "schematic"
Netlist Error: Some cell-views used inside this block could not be netlisted in analog context
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
*ERROR* (AMS-1247): AMS UNL netlisting has failed.
Check Simulation->Output Log->Netlister Log for errors.
Correct your design and netlist again.
在仿真时遇到这种问题是什么原因导致的
发表于 2024-3-2 12:21:54 | 显示全部楼层
看看
发表于 2024-3-2 15:34:06 | 显示全部楼层
看看
发表于 2024-11-25 14:43:00 | 显示全部楼层
我仿真也遇到这个问题了,请问您找到是什么原因导致的了嘛
发表于 2024-12-19 10:32:52 | 显示全部楼层
那是因为你的仿真的时候库没有选对,或者少选了
GMT+8, 2025-12-20 00:32 , Processed in 0.014652 second(s), 4 queries , Gzip On, Redis On.
