查看: 4033|回复: 16
[求助] 求助!!版图LVSmissing port严重
发表于 2024-2-26 15:37:53 | 显示全部楼层 |阅读模式
不知道为啥,这边感觉有很多数据丢失,各种instance,nets和ports都显示missing。但里面的小器件的LVS都没啥问题的,也不知道是哪出了问题。能试的方法都试了,pin脚和lable都没问题,这边求助一下各位大佬,有知道原因的吗?
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of ports (see below).
  Error:    Different numbers of nets (see below).
  Error:    Different numbers of instances (see below).
  Error:    Connectivity errors.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              6        12    *
Nets:             119       125    *
Instances:         34        34         MN (4 pins)
                   241       241         MP (4 pins)
                    22         2    *    R (2 pins)
                    41         0    *    D (2 pins)
Total Inst:       338       277
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              6        12    *
Nets:              51        17    *
Instances:         43         3    *    MP (4 pins)
                     2         2         R (2 pins)
                     6         8    *    _sdw2v (4 pins)
                     1         5    *    _smp2v (4 pins)
Total Inst:        52        18
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net VDD                                                   VDD
       --- 130 Connections On This Net ---                       --- 9 Connections On This Net ---
       (_sdw2b)ut1                                             ** missing connection **
         X15/M0(78.080,-233.495):s
         X12/M0(223.989,-209.990):s
       (_smp2v):in2                                              ** missing connection **
         X68/X60/M0(272.932,-51.895):g
       (_smp2v):in1                                              ** missing connection **
         X68/X61/M0(271.932,-34.620):g
       X23/X9/M0(204.740,-107.470):b                             ** missing connection **
       X23/X9/M0(204.740,-107.470):d                             ** missing connection **
  略一部分
38    Net X23/13                                                ** no similar net **
39    Net X23/14                                                ** no similar net **
40    Net X23/15                                                ** no similar net **
41    Net X23/16                                                ** no similar net **
42    ** no similar net **                                      OUT1
43    ** no similar net **                                      OUT2
44    ** no similar net **                                      OUTN1
45    ** no similar net **                                      OUTN2
46    ** no similar net **                                      PVB1
47    ** no similar net **                                      PVB2
                                   INCORRECT PORTS
48    ** missing port **                                        OUT1 on net: OUT1
49    ** missing port **                                        OUT2 on net: OUT2
50    ** missing port **                                        OUTN1 on net: OUTN1
51    ** missing port **                                        OUTN2 on net: OUTN2
52    ** missing port **                                        PVB1 on net: PVB1
53    ** missing port **                                        PVB2 on net: PVB2
                                 INCORRECT INSTANCES
54    X20/X0/M0(28.185,-151.660)  MP(p50)                       ** missing instance **
发表于 2024-2-26 16:51:20 | 显示全部楼层
把图形界面的错误,贴出来看一下,目测是器件个数问题对不上。
 楼主| 发表于 2024-2-26 17:01:43 | 显示全部楼层
请问是这个吗?
发表于 2024-2-26 17:04:33 | 显示全部楼层
看一下ports问题,电路有OUT1 OUT2 ,是不是电路有修改啊,或者版图和电路没对应上啊
 楼主| 发表于 2024-2-26 17:06:26 | 显示全部楼层
Discrepancy #48 in AMP10_PITCH_5_2
都是这样的
 楼主| 发表于 2024-2-26 17:09:18 | 显示全部楼层
你要是全部报错或是全部不报错,我还有点头绪,关键是这有些报错,有些没报错就很难受,不知道哪出了问题
 楼主| 发表于 2024-2-26 17:11:01 | 显示全部楼层
电路也没问题啊,没有什么修改的,和版图也对的上,我核对过好几遍了
发表于 2024-2-26 17:16:15 | 显示全部楼层
查一下LVS规则选项,有可能是LVS规则选错了
 楼主| 发表于 2024-2-26 17:19:16 | 显示全部楼层
请问什么叫LVS规则选错了?rule文件需要修改吗?
发表于 2024-2-26 17:31:22 | 显示全部楼层
大量VDD VSS的问题,先看看电源线以及short 问题
missing port 的问题, 确认一下port有没有,位置合不合理或者实际连线有没有
GMT+8, 2025-12-29 04:29 , Processed in 0.024681 second(s), 4 queries , Gzip On, Redis On.
