查看: 1873|回复: 5
[求助] ccopt_design会报license错误,在使用Nanoroute的时候也会报同样的错误,求大佬们指点
发表于 2023-12-28 16:44:14 | 显示全部楼层 |阅读模式
最近在学innovus,在做这个lab,进行到ccopt_design的时候就报了以下两个错误
**ERROR: (IMPLIC-90):        This command "ccopt_design" does not have the necessary license to run and there are no optional licenses installed that can enable this command using the current base-license of 'fexl'.
Use 'setLicenseCheck -status' to see the current licenses in use and for more information.
**ERROR: (IMPCCOPT-2196):        Cannot run ccopt_design because the command prerequisites were not met. Review the previous error messages for more details about the failure.
发表于 2023-12-28 16:51:59 | 显示全部楼层
在公司找IT,在外面找破解
 楼主| 发表于 2023-12-28 21:38:52 来自手机 | 显示全部楼层
菜鸟一号 发表于 2023-12-28 16:51
在公司找IT,在外面找破解
请问一般都会load哪些license呀。
发表于 2023-12-29 09:56:33 | 显示全部楼层
Innovus_10nm_Opt
Innovus_20nm_Opt
Innovus_3D_IC_Opt
Innovus_3nm_Opt
Innovus_5nm_Opt
Innovus_7nm_Opt
Innovus_CPU_Opt
Innovus_DFM
Innovus_EHFS_Opt
Innovus_GigaPlace_GXL_Opt
Innovus_GigaPlace_XL_Opt
Innovus_hfr_Opt
Innovus_Hier_Opt
Innovus_I10nm_Opt
Innovus_I20nm_Opt
Innovus_Impl_System
Innovus_Impl_System_Basic
Innovus_ML_Impl_Opt
Innovus_MS_Opt
Innovus_PI_Opt
发表于 2024-11-10 12:01:06 | 显示全部楼层
大哥请问解决了吗?怎么解决的?
 楼主| 发表于 2024-12-3 17:53:39 | 显示全部楼层
firm09 发表于 2024-11-10 12:01
大哥请问解决了吗?怎么解决的?
让你们公司it重新安装innovus  licences没按好
GMT+8, 2025-12-31 01:50 , Processed in 0.014942 second(s), 3 queries , Gzip On, Redis On.
