查看: 2942|回复: 3
[求助] 新人求助:ICC生成gds后导入Virtuoso做LVS检查出错
发表于 2023-12-28 12:16:32 | 显示全部楼层 |阅读模式
求助各位大佬!
用的是tsmcN65的工艺,ICC之后的LVS只报了floating net的错误,这个是PVDD02POC还有PVDD02DGZ的VDDPST没有连导致的,但是我导出后在Virtuoso中已经打了Pin了,LVS检查端口数目也是对的。但还是有60多个错误。然后我在LVS Option里设置区分大小写之后,错误降到了20几个,现在完全没有头绪该怎么解决了,求助各位大佬看一看!
这边是LVS的详细报告:
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         Traffic_TOP_Pad_final.lvs.report
LAYOUT NAME:              /net/dellr710b/export1/mxic2015/dyzhou/Virtuoso/LVS/Traffic_TOP_Pad_final.sp ('Traffic_TOP_Pad_final')
SOURCE NAME:              _source.net_ ('Traffic_TOP_Pad')
RULE FILE:                /net/dellr710b/export1/mxic2015/dyzhou/Virtuoso/LVS/_calibre.lvs_
CREATION TIME:            Thu Dec 28 11:52:40 2023
CURRENT DIRECTORY:        /net/dellr710b/export1/mxic2015/dyzhou/Virtuoso/LVS
USER NAME:                mxic2015
CALIBRE VERSION:          v2020.4_34.17    Tue Dec 1 16:11:11 PST 2020
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of nets.
  Error:    Different numbers of instances.
  Error:    Connectivity errors.
  Error:    Instances of different types or subtypes were matched.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
  Warning:  Ambiguity points were found and resolved arbitrarily.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      Traffic_TOP_Pad_final         Traffic_TOP_Pad
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD" "VDDPST" "OC"
   LVS GROUND NAME                        "VSS" "VSSPST"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   // LVS HCELL REPORT
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       YES
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       YES
   LVS EXPAND UNBALANCED CELLS            YES
   LVS FLATTEN INSIDE CELL                NO
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   // LVS SPICE EXCLUDE CELL SOURCE
   // LVS SPICE EXCLUDE CELL LAYOUT
   LVS SPICE IMPLIED MOS AREA             NO
   // LVS SPICE MULTIPLIER NAME
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE SCALE X PARAMETERS           NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            YES
   SOURCE CASE                            YES
   LVS COMPARE CASE                       NAMES TYPES SUBTYPES VALUES
   LVS COMPARE CASE STRICT                NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     50
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   // LVS FILTER UNUSED OPTION
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // LVS IGNORE DEVICE PIN
   // LVS PREFER NETS FILTER SOURCE
   // LVS PREFER NETS FILTER LAYOUT
   LVS PREFER PORT NETS                   NO
   LVS EXPAND ON ERROR                    NO
   // Device Type Map
   LVS DEVICE TYPE                        RESISTOR "rm1" "rm10" "rm2" "rm3" "rm4" "rm5" "rm6" "rm7" "rm8" "rm9" "rnodl" "rnodl_m"
                                                   "rnods" "rnods_m" "rnodwo" "rnodwo_m" "rnpolyl" "rnpolyl_m" "rnpolys"
                                                   "rnpolys_m" "rnpolywo" "rnpolywo_m" "rnwod" "rnwod_m" "rnwsti" "rnwsti_m"
                                                   "rpodl" "rpodl_m" "rpods" "rpods_m" "rpodwo" "rpodwo_m" "rppolyl" "rppolyl_m"
                                                   "rppolyl_rf" "rppolyl_rf_rdk" "rppolys" "rppolys_m" "rppolys_rf"
                                                   "rppolys_rf_rdk" "rppolywo" "rppolywo_m" "rppolywo_rf" "rppolywo_rf_rdk"
                                                   [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   // Reduction
   LVS REDUCE SERIES MOS                  NO
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 NO
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           YES
   LVS REDUCE PARALLEL CAPACITORS         YES
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
   LVS REDUCE  rnwsti_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnwsti_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnwod_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnwod_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rpodwo_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rpodwo_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnodwo_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnodwo_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rpodl_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rpodl_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnodl_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnodl_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rpods_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rpods_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnods_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnods_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppolys_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rppolys_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpolys_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpolys_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppolyl_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rppolyl_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpolyl_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpolyl_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppolywo_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rppolywo_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpolywo_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpolywo_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppolyl_rf  PARALLEL NO
   LVS REDUCE  rppolyl_rf  SERIES PLUS MINUS NO
   LVS REDUCE  rppolyl_rf_rdk  PARALLEL NO
   LVS REDUCE  rppolyl_rf_rdk  SERIES PLUS MINUS NO
   LVS REDUCE  rppolys_rf  PARALLEL NO
   LVS REDUCE  rppolys_rf  SERIES PLUS MINUS NO
   LVS REDUCE  rppolys_rf_rdk  PARALLEL NO
   LVS REDUCE  rppolys_rf_rdk  SERIES PLUS MINUS NO
   LVS REDUCE  rppolywo_rf  PARALLEL NO
   LVS REDUCE  rppolywo_rf  SERIES PLUS MINUS NO
   LVS REDUCE  rppolywo_rf_rdk  PARALLEL NO
   LVS REDUCE  rppolywo_rf_rdk  SERIES PLUS MINUS NO
   LVS REDUCTION PRIORITY                 PARALLEL
   LVS SHORT EQUIVALENT NODES             NO
   // Filter
   LVS FILTER  D(pnwdio)  OPEN LAYOUT
   // Trace Property
   TRACE PROPERTY  lddp(pch_hv25_spw)  l l 0
   TRACE PROPERTY  lddp(pch_hv25_spw)  w w 0
   TRACE PROPERTY  lddn(nch_hv25_snw)  l l 0
   TRACE PROPERTY  lddn(nch_hv25_snw)  w w 0
   TRACE PROPERTY  mn(nch)  l l 0
   TRACE PROPERTY  mn(nch)  w w 0
   TRACE PROPERTY  mn(nch_18)  l l 0
   TRACE PROPERTY  mn(nch_18)  w w 0
   TRACE PROPERTY  mn(nch_18_dnw)  l l 0
   TRACE PROPERTY  mn(nch_18_dnw)  w w 0
   TRACE PROPERTY  mn(nch_25)  l l 0
   TRACE PROPERTY  mn(nch_25)  w w 0
   TRACE PROPERTY  mn(nch_25_dnw)  l l 0
   TRACE PROPERTY  mn(nch_25_dnw)  w w 0
   TRACE PROPERTY  mn(nch_25_dnwod)  l l 0
   TRACE PROPERTY  mn(nch_25_dnwod)  w w 0
   TRACE PROPERTY  mn(nch_25_dnwud)  l l 0
   TRACE PROPERTY  mn(nch_25_dnwud)  w w 0
   TRACE PROPERTY  mn(nch_25od)  l l 0
   TRACE PROPERTY  mn(nch_25od)  w w 0
   TRACE PROPERTY  mn(nch_25od28)  l l 0
   TRACE PROPERTY  mn(nch_25od28)  w w 0
   TRACE PROPERTY  mn(nch_25od28_dnw)  l l 0
   TRACE PROPERTY  mn(nch_25od28_dnw)  w w 0
   TRACE PROPERTY  mn(nch_25ud)  l l 0
   TRACE PROPERTY  mn(nch_25ud)  w w 0
   TRACE PROPERTY  mn(nch_33)  l l 0
   TRACE PROPERTY  mn(nch_33)  w w 0
   TRACE PROPERTY  mn(nch_33_dnw)  l l 0
   TRACE PROPERTY  mn(nch_33_dnw)  w w 0
   TRACE PROPERTY  mn(nch_dnw)  l l 0
   TRACE PROPERTY  mn(nch_dnw)  w w 0
   TRACE PROPERTY  mn(nch_dnw_1tr)  l l 0
   TRACE PROPERTY  mn(nch_dnw_1tr)  w w 0
   TRACE PROPERTY  mn(nch_dnw_w)  l l 0
   TRACE PROPERTY  mn(nch_dnw_w)  w w 0
   TRACE PROPERTY  mn(nch_dnw_w_lvt)  l l 0
   TRACE PROPERTY  mn(nch_dnw_w_lvt)  w w 0
   TRACE PROPERTY  mn(nch_esd18)  l l 0
   TRACE PROPERTY  mn(nch_esd18)  w w 0
   TRACE PROPERTY  mn(nch_esd18_dnw)  l l 0
   TRACE PROPERTY  mn(nch_esd18_dnw)  w w 0
   TRACE PROPERTY  mn(nch_hvt)  l l 0
   TRACE PROPERTY  mn(nch_hvt)  w w 0
   TRACE PROPERTY  mn(nch_hvt_dnw)  l l 0
   TRACE PROPERTY  mn(nch_hvt_dnw)  w w 0
   TRACE PROPERTY  mn(nch_lpg)  l l 0
   TRACE PROPERTY  mn(nch_lpg)  w w 0
   TRACE PROPERTY  mn(nch_lpghvt)  l l 0
   TRACE PROPERTY  mn(nch_lpghvt)  w w 0
   TRACE PROPERTY  mn(nch_lpgna)  l l 0
   TRACE PROPERTY  mn(nch_lpgna)  w w 0
   TRACE PROPERTY  mn(nch_lvt)  l l 0
   TRACE PROPERTY  mn(nch_lvt)  w w 0
   TRACE PROPERTY  mn(nch_lvt_dnw)  l l 0
   TRACE PROPERTY  mn(nch_lvt_dnw)  w w 0
   TRACE PROPERTY  mn(nch_mlvt)  l l 0
   TRACE PROPERTY  mn(nch_mlvt)  w w 0
   TRACE PROPERTY  mn(nch_mlvt_dnw)  l l 0
   TRACE PROPERTY  mn(nch_mlvt_dnw)  w w 0
   TRACE PROPERTY  mn(nch_na)  l l 0
   TRACE PROPERTY  mn(nch_na)  w w 0
   TRACE PROPERTY  mn(nch_na18)  l l 0
   TRACE PROPERTY  mn(nch_na18)  w w 0
   TRACE PROPERTY  mn(nch_na25)  l l 0
   TRACE PROPERTY  mn(nch_na25)  w w 0
   TRACE PROPERTY  mn(nch_na25od)  l l 0
   TRACE PROPERTY  mn(nch_na25od)  w w 0
   TRACE PROPERTY  mn(nch_na25ud)  l l 0
   TRACE PROPERTY  mn(nch_na25ud)  w w 0
   TRACE PROPERTY  mn(nch_na33)  l l 0
   TRACE PROPERTY  mn(nch_na33)  w w 0
   TRACE PROPERTY  mn(nch_timer)  l l 0
   TRACE PROPERTY  mn(nch_timer)  w w 0
   TRACE PROPERTY  mn(nch_uhvt)  l l 0
   TRACE PROPERTY  mn(nch_uhvt)  w w 0
   TRACE PROPERTY  mn(nch_uhvt_dnw)  l l 0
   TRACE PROPERTY  mn(nch_uhvt_dnw)  w w 0
   TRACE PROPERTY  mn(nch_ulvt)  l l 0
   TRACE PROPERTY  mn(nch_ulvt)  w w 0
   TRACE PROPERTY  mn(nch_ulvt_dnw)  l l 0
   TRACE PROPERTY  mn(nch_ulvt_dnw)  w w 0
   TRACE PROPERTY  mn(nch_w)  l l 0
   TRACE PROPERTY  mn(nch_w)  w w 0
   TRACE PROPERTY  mn(nch_w_lvt)  l l 0
   TRACE PROPERTY  mn(nch_w_lvt)  w w 0
   TRACE PROPERTY  mn(nchpd_dphcsr)  l l 0
   TRACE PROPERTY  mn(nchpd_dphcsr)  w w 0
   TRACE PROPERTY  mn(nchpd_dpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_dpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_hvtdphcsr)  l l 0
   TRACE PROPERTY  mn(nchpd_hvtdphcsr)  w w 0
   TRACE PROPERTY  mn(nchpd_hvtdpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_hvtdpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_hvtsr)  l l 0
   TRACE PROPERTY  mn(nchpd_hvtsr)  w w 0
   TRACE PROPERTY  mn(nchpd_lpgdpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_lpgdpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_lpgsr)  l l 0
   TRACE PROPERTY  mn(nchpd_lpgsr)  w w 0
   TRACE PROPERTY  mn(nchpd_lpgtpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_lpgtpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_sr)  l l 0
   TRACE PROPERTY  mn(nchpd_sr)  w w 0
   TRACE PROPERTY  mn(nchpd_ulpdpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_ulpdpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_ulpsr)  l l 0
   TRACE PROPERTY  mn(nchpd_ulpsr)  w w 0
   TRACE PROPERTY  mn(nchpd_wisr)  l l 0
   TRACE PROPERTY  mn(nchpd_wisr)  w w 0
   TRACE PROPERTY  mn(nchpd_wosr)  l l 0
   TRACE PROPERTY  mn(nchpd_wosr)  w w 0
   TRACE PROPERTY  mn(nchpg_dphcsr)  l l 0
   TRACE PROPERTY  mn(nchpg_dphcsr)  w w 0
   TRACE PROPERTY  mn(nchpg_dpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_dpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_hvtdphcsr)  l l 0
   TRACE PROPERTY  mn(nchpg_hvtdphcsr)  w w 0
   TRACE PROPERTY  mn(nchpg_hvtdpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_hvtdpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_hvtsr)  l l 0
   TRACE PROPERTY  mn(nchpg_hvtsr)  w w 0
   TRACE PROPERTY  mn(nchpg_lpgdpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_lpgdpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_lpgsr)  l l 0
   TRACE PROPERTY  mn(nchpg_lpgsr)  w w 0
   TRACE PROPERTY  mn(nchpg_lpgtpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_lpgtpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_sr)  l l 0
   TRACE PROPERTY  mn(nchpg_sr)  w w 0
   TRACE PROPERTY  mn(nchpg_ulpdpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_ulpdpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_ulpsr)  l l 0
   TRACE PROPERTY  mn(nchpg_ulpsr)  w w 0
   TRACE PROPERTY  mn(nchpg_wisr)  l l 0
   TRACE PROPERTY  mn(nchpg_wisr)  w w 0
   TRACE PROPERTY  mn(nchpg_wosr)  l l 0
   TRACE PROPERTY  mn(nchpg_wosr)  w w 0
   TRACE PROPERTY  mp(pch)  l l 0
   TRACE PROPERTY  mp(pch)  w w 0
   TRACE PROPERTY  mp(pch_18)  l l 0
   TRACE PROPERTY  mp(pch_18)  w w 0
   TRACE PROPERTY  mp(pch_25)  l l 0
   TRACE PROPERTY  mp(pch_25)  w w 0
   TRACE PROPERTY  mp(pch_25od)  l l 0
   TRACE PROPERTY  mp(pch_25od)  w w 0
   TRACE PROPERTY  mp(pch_25od28)  l l 0
   TRACE PROPERTY  mp(pch_25od28)  w w 0
   TRACE PROPERTY  mp(pch_25ud)  l l 0
   TRACE PROPERTY  mp(pch_25ud)  w w 0
   TRACE PROPERTY  mp(pch_33)  l l 0
   TRACE PROPERTY  mp(pch_33)  w w 0
   TRACE PROPERTY  mp(pch_edc)  l l 0
   TRACE PROPERTY  mp(pch_edc)  w w 0
   TRACE PROPERTY  mp(pch_hvt)  l l 0
   TRACE PROPERTY  mp(pch_hvt)  w w 0
   TRACE PROPERTY  mp(pch_lpg)  l l 0
   TRACE PROPERTY  mp(pch_lpg)  w w 0
   TRACE PROPERTY  mp(pch_lpghvt)  l l 0
   TRACE PROPERTY  mp(pch_lpghvt)  w w 0
   TRACE PROPERTY  mp(pch_lvt)  l l 0
   TRACE PROPERTY  mp(pch_lvt)  w w 0
   TRACE PROPERTY  mp(pch_mlvt)  l l 0
   TRACE PROPERTY  mp(pch_mlvt)  w w 0
   TRACE PROPERTY  mp(pch_timer)  l l 0
   TRACE PROPERTY  mp(pch_timer)  w w 0
   TRACE PROPERTY  mp(pch_uhvt)  l l 0
   TRACE PROPERTY  mp(pch_uhvt)  w w 0
   TRACE PROPERTY  mp(pch_ulvt)  l l 0
   TRACE PROPERTY  mp(pch_ulvt)  w w 0
   TRACE PROPERTY  mp(pch_w)  l l 0
   TRACE PROPERTY  mp(pch_w)  w w 0
   TRACE PROPERTY  mp(pch_w_lvt)  l l 0
   TRACE PROPERTY  mp(pch_w_lvt)  w w 0
   TRACE PROPERTY  mp(pchpu_dphcsr)  l l 0
   TRACE PROPERTY  mp(pchpu_dphcsr)  w w 0
   TRACE PROPERTY  mp(pchpu_dpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_dpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_hvtdphcsr)  l l 0
   TRACE PROPERTY  mp(pchpu_hvtdphcsr)  w w 0
   TRACE PROPERTY  mp(pchpu_hvtdpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_hvtdpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_hvtsr)  l l 0
   TRACE PROPERTY  mp(pchpu_hvtsr)  w w 0
   TRACE PROPERTY  mp(pchpu_lpgdpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_lpgdpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_lpgsr)  l l 0
   TRACE PROPERTY  mp(pchpu_lpgsr)  w w 0
   TRACE PROPERTY  mp(pchpu_lpgtpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_lpgtpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_sr)  l l 0
   TRACE PROPERTY  mp(pchpu_sr)  w w 0
   TRACE PROPERTY  mp(pchpu_ulpdpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_ulpdpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_ulpsr)  l l 0
   TRACE PROPERTY  mp(pchpu_ulpsr)  w w 0
   TRACE PROPERTY  mp(pchpu_wisr)  l l 0
   TRACE PROPERTY  mp(pchpu_wisr)  w w 0
   TRACE PROPERTY  mp(pchpu_wosr)  l l 0
   TRACE PROPERTY  mp(pchpu_wosr)  w w 0
   TRACE PROPERTY  q(npn10)  a a 0
   TRACE PROPERTY  q(npn10_s)  a a 0
   TRACE PROPERTY  q(npn2)  a a 0
   TRACE PROPERTY  q(npn2_s)  a a 0
   TRACE PROPERTY  q(npn5)  a a 0
   TRACE PROPERTY  q(npn5_s)  a a 0
   TRACE PROPERTY  q(pnp10)  a a 0
   TRACE PROPERTY  q(pnp10_s)  a a 0
   TRACE PROPERTY  q(pnp2)  a a 0
   TRACE PROPERTY  q(pnp2_s)  a a 0
   TRACE PROPERTY  q(pnp5)  a a 0
   TRACE PROPERTY  q(pnp5_s)  a a 0
   TRACE PROPERTY  d(ndio)  a a 0
   TRACE PROPERTY  d(ndio_18)  a a 0
   TRACE PROPERTY  d(ndio_25)  a a 0
   TRACE PROPERTY  d(ndio_25od)  a a 0
   TRACE PROPERTY  d(ndio_25od28)  a a 0
   TRACE PROPERTY  d(ndio_25ud)  a a 0
   TRACE PROPERTY  d(ndio_33)  a a 0
   TRACE PROPERTY  d(ndio_esd)  a a 0
   TRACE PROPERTY  d(ndio_hvt)  a a 0
   TRACE PROPERTY  d(ndio_lpg)  a a 0
   TRACE PROPERTY  d(ndio_lpghvt)  a a 0
   TRACE PROPERTY  d(ndio_lpgna)  a a 0
   TRACE PROPERTY  d(ndio_lvt)  a a 0
   TRACE PROPERTY  d(ndio_mlvt)  a a 0
   TRACE PROPERTY  d(ndio_na)  a a 0
   TRACE PROPERTY  d(ndio_na18)  a a 0
   TRACE PROPERTY  d(ndio_na25)  a a 0
   TRACE PROPERTY  d(ndio_na25od)  a a 0
   TRACE PROPERTY  d(ndio_na25ud)  a a 0
   TRACE PROPERTY  d(ndio_na33)  a a 0
   TRACE PROPERTY  d(ndio_uhvt)  a a 0
   TRACE PROPERTY  d(ndio_w)  a a 0
   TRACE PROPERTY  d(nwdio)  a a 0
   TRACE PROPERTY  d(nwdio_18)  a a 0
   TRACE PROPERTY  d(nwdio_25)  a a 0
   TRACE PROPERTY  d(nwdio_33)  a a 0
   TRACE PROPERTY  d(pdio)  a a 0
   TRACE PROPERTY  d(pdio_18)  a a 0
   TRACE PROPERTY  d(pdio_25)  a a 0
   TRACE PROPERTY  d(pdio_25od)  a a 0
   TRACE PROPERTY  d(pdio_25od28)  a a 0
   TRACE PROPERTY  d(pdio_25ud)  a a 0
   TRACE PROPERTY  d(pdio_33)  a a 0
   TRACE PROPERTY  d(pdio_hvt)  a a 0
   TRACE PROPERTY  d(pdio_lpg)  a a 0
   TRACE PROPERTY  d(pdio_lpghvt)  a a 0
   TRACE PROPERTY  d(pdio_lvt)  a a 0
   TRACE PROPERTY  d(pdio_mlvt)  a a 0
   TRACE PROPERTY  d(pdio_uhvt)  a a 0
   TRACE PROPERTY  d(pdio_w)  a a 0
   TRACE PROPERTY  crtmom_rf  nv nv 0
   TRACE PROPERTY  crtmom_rf  nh nh 0
   TRACE PROPERTY  crtmom_rf  s s 0
   TRACE PROPERTY  crtmom_rf  w w 0
   TRACE PROPERTY  crtmom_rf  stm stm 0
   TRACE PROPERTY  crtmom_rf  spm spm 0
   TRACE PROPERTY  crtmom_rf_rdk  nv nv 0
   TRACE PROPERTY  crtmom_rf_rdk  nh nh 0
   TRACE PROPERTY  crtmom_rf_rdk  s s 0
   TRACE PROPERTY  crtmom_rf_rdk  w w 0
   TRACE PROPERTY  crtmom_rf_rdk  stm stm 0
   TRACE PROPERTY  crtmom_rf_rdk  spm spm 0
   TRACE PROPERTY  crtmom  nv nv 0
   TRACE PROPERTY  crtmom  nh nh 0
   TRACE PROPERTY  crtmom  s s 0
   TRACE PROPERTY  crtmom  w w 0
   TRACE PROPERTY  crtmom  stm stm 0
   TRACE PROPERTY  crtmom  spm spm 0
   TRACE PROPERTY  crtmom_2t  nv nv 0
   TRACE PROPERTY  crtmom_2t  nh nh 0
   TRACE PROPERTY  crtmom_2t  s s 0
   TRACE PROPERTY  crtmom_2t  w w 0
   TRACE PROPERTY  crtmom_2t  stm stm 0
   TRACE PROPERTY  crtmom_2t  spm spm 0
   TRACE PROPERTY  crtmom_mx  nv nv 0
   TRACE PROPERTY  crtmom_mx  nh nh 0
   TRACE PROPERTY  crtmom_mx  s s 0
   TRACE PROPERTY  crtmom_mx  w w 0
   TRACE PROPERTY  crtmom_mx  stm stm 0
   TRACE PROPERTY  crtmom_mx  spm spm 0
   TRACE PROPERTY  crtmom_mx  mf mf 0
   TRACE PROPERTY  fmom  nr nr 0
   TRACE PROPERTY  fmom  lr lr 0
   TRACE PROPERTY  fmom  s s 0
   TRACE PROPERTY  fmom  w w 0
   TRACE PROPERTY  fmom  stm stm 0
   TRACE PROPERTY  fmom  spm spm 0
   TRACE PROPERTY  fmom_mx  nr nr 0
   TRACE PROPERTY  fmom_mx  lr lr 0
   TRACE PROPERTY  fmom_mx  s s 0
   TRACE PROPERTY  fmom_mx  w w 0
   TRACE PROPERTY  fmom_mx  stm stm 0
   TRACE PROPERTY  fmom_mx  spm spm 0
   TRACE PROPERTY  fmom_mx  mf mf 0
   TRACE PROPERTY  d(pwdnw)  a a 0
   TRACE PROPERTY  d(dnwpsub)  a a 0
   TRACE PROPERTY  lincap  lr lr 0
   TRACE PROPERTY  lincap  wr wr 0
   TRACE PROPERTY  lincap  mr mr 0
   TRACE PROPERTY  lincap_25  lr lr 0
   TRACE PROPERTY  lincap_25  wr wr 0
   TRACE PROPERTY  lincap_25  mr mr 0
   TRACE PROPERTY  lincap_rf  lr lr 0
   TRACE PROPERTY  lincap_rf  wr wr 0
   TRACE PROPERTY  lincap_rf  br br 0
   TRACE PROPERTY  lincap_rf  gr gr 0
   TRACE PROPERTY  lincap_rf_25  lr lr 0
   TRACE PROPERTY  lincap_rf_25  wr wr 0
   TRACE PROPERTY  lincap_rf_25  br br 0
   TRACE PROPERTY  lincap_rf_25  gr gr 0
   TRACE PROPERTY  lowcpad_d15  lt lt 0
   TRACE PROPERTY  lowcpad_d15  wt wt 0
   TRACE PROPERTY  lowcpad_d15  lay lay 0
   TRACE PROPERTY  lowcpad_d23  lt lt 0
   TRACE PROPERTY  lowcpad_d23  wt wt 0
   TRACE PROPERTY  lowcpad_d23  lay lay 0
   TRACE PROPERTY  mimcap_sin  lt lt 0
   TRACE PROPERTY  mimcap_sin  wt wt 0
   TRACE PROPERTY  mimcap_sin  mimflag mimflag 0
   TRACE PROPERTY  mimcap_sin_3t  lt lt 0
   TRACE PROPERTY  mimcap_sin_3t  wt wt 0
   TRACE PROPERTY  mimcap_sin_3t  lay lay 0
   TRACE PROPERTY  mimcap_sin_3t  mimflag mimflag 0
   TRACE PROPERTY  mimcap_um_sin_rf  lt lt 0
   TRACE PROPERTY  mimcap_um_sin_rf  wt wt 0
   TRACE PROPERTY  mimcap_um_sin_rf  mimflag mimflag 0
   TRACE PROPERTY  mimcap_woum_sin_rf  lt lt 0
   TRACE PROPERTY  mimcap_woum_sin_rf  wt wt 0
   TRACE PROPERTY  mimcap_woum_sin_rf  lay lay 0
   TRACE PROPERTY  mimcap_woum_sin_rf  mimflag mimflag 0
   TRACE PROPERTY  moscap_rf  lr lr 0
   TRACE PROPERTY  moscap_rf  wr wr 0
   TRACE PROPERTY  moscap_rf  br br 0
   TRACE PROPERTY  moscap_rf  gr gr 0
   TRACE PROPERTY  moscap_rf18  lr lr 0
   TRACE PROPERTY  moscap_rf18  wr wr 0
   TRACE PROPERTY  moscap_rf18  br br 0
   TRACE PROPERTY  moscap_rf18  gr gr 0
   TRACE PROPERTY  moscap_rf18_nw  lr lr 0
   TRACE PROPERTY  moscap_rf18_nw  wr wr 0
   TRACE PROPERTY  moscap_rf18_nw  br br 0
   TRACE PROPERTY  moscap_rf18_nw  gr gr 0
   TRACE PROPERTY  moscap_rf25  lr lr 0
   TRACE PROPERTY  moscap_rf25  wr wr 0
   TRACE PROPERTY  moscap_rf25  br br 0
   TRACE PROPERTY  moscap_rf25  gr gr 0
   TRACE PROPERTY  moscap_rf25_nw  lr lr 0
   TRACE PROPERTY  moscap_rf25_nw  wr wr 0
   TRACE PROPERTY  moscap_rf25_nw  br br 0
   TRACE PROPERTY  moscap_rf25_nw  gr gr 0
   TRACE PROPERTY  moscap_rf33  lr lr 0
   TRACE PROPERTY  moscap_rf33  wr wr 0
   TRACE PROPERTY  moscap_rf33  br br 0
   TRACE PROPERTY  moscap_rf33  gr gr 0
   TRACE PROPERTY  moscap_rf33_nw  lr lr 0
   TRACE PROPERTY  moscap_rf33_nw  wr wr 0
   TRACE PROPERTY  moscap_rf33_nw  br br 0
   TRACE PROPERTY  moscap_rf33_nw  gr gr 0
   TRACE PROPERTY  moscap_rf_hvt  lr lr 0
   TRACE PROPERTY  moscap_rf_hvt  wr wr 0
   TRACE PROPERTY  moscap_rf_hvt  br br 0
   TRACE PROPERTY  moscap_rf_hvt  gr gr 0
   TRACE PROPERTY  moscap_rf_hvt_nw  lr lr 0
   TRACE PROPERTY  moscap_rf_hvt_nw  wr wr 0
   TRACE PROPERTY  moscap_rf_hvt_nw  br br 0
   TRACE PROPERTY  moscap_rf_hvt_nw  gr gr 0
   TRACE PROPERTY  moscap_rf_nw  lr lr 0
   TRACE PROPERTY  moscap_rf_nw  wr wr 0
   TRACE PROPERTY  moscap_rf_nw  br br 0
   TRACE PROPERTY  moscap_rf_nw  gr gr 0
   TRACE PROPERTY  moscap_rf_rdk  lr lr 0
   TRACE PROPERTY  moscap_rf_rdk  wr wr 0
   TRACE PROPERTY  moscap_rf_rdk  br br 0
   TRACE PROPERTY  moscap_rf_rdk  gr gr 0
   TRACE PROPERTY  ndio_hia_rf  al al 0
   TRACE PROPERTY  ndio_hia_rf  aw aw 0
   TRACE PROPERTY  nmos_rf  wr wr 0
   TRACE PROPERTY  nmos_rf  lr lr 0
   TRACE PROPERTY  nmos_rf  nr nr 0
   TRACE PROPERTY  nmos_rf_18  wr wr 0
   TRACE PROPERTY  nmos_rf_18  lr lr 0
   TRACE PROPERTY  nmos_rf_18  nr nr 0
   TRACE PROPERTY  nmos_rf_18_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_18_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_18_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_18_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_18_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_18_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_25  wr wr 0
   TRACE PROPERTY  nmos_rf_25  lr lr 0
   TRACE PROPERTY  nmos_rf_25  nr nr 0
   TRACE PROPERTY  nmos_rf_25_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_25_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_25_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_25_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_25_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_25_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_25_nodnwod  wr wr 0
   TRACE PROPERTY  nmos_rf_25_nodnwod  lr lr 0
   TRACE PROPERTY  nmos_rf_25_nodnwod  nr nr 0
   TRACE PROPERTY  nmos_rf_25_nodnwud  wr wr 0
   TRACE PROPERTY  nmos_rf_25_nodnwud  lr lr 0
   TRACE PROPERTY  nmos_rf_25_nodnwud  nr nr 0
   TRACE PROPERTY  nmos_rf_25od  wr wr 0
   TRACE PROPERTY  nmos_rf_25od  lr lr 0
   TRACE PROPERTY  nmos_rf_25od  nr nr 0
   TRACE PROPERTY  nmos_rf_25od33_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_25od33_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_25od33_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_25ud  wr wr 0
   TRACE PROPERTY  nmos_rf_25ud  lr lr 0
   TRACE PROPERTY  nmos_rf_25ud  nr nr 0
   TRACE PROPERTY  nmos_rf_25ud18_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_25ud18_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_25ud18_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_33  wr wr 0
   TRACE PROPERTY  nmos_rf_33  lr lr 0
   TRACE PROPERTY  nmos_rf_33  nr nr 0
   TRACE PROPERTY  nmos_rf_33_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_33_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_33_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_33_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_33_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_33_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_cas_nw  wr wr 0
   TRACE PROPERTY  nmos_rf_cas_nw  lr lr 0
   TRACE PROPERTY  nmos_rf_cas_nw  nr nr 0
   TRACE PROPERTY  nmos_rf_cas_nw  wrr wrr 0
   TRACE PROPERTY  nmos_rf_cas_nw  lrr lrr 0
   TRACE PROPERTY  nmos_rf_cas_nw  nrr nrr 0
   TRACE PROPERTY  nmos_rf_cross_nw  wr wr 0
   TRACE PROPERTY  nmos_rf_cross_nw  lr lr 0
   TRACE PROPERTY  nmos_rf_cross_nw  nr nr 0
   TRACE PROPERTY  nmos_rf_diff_nw  wr wr 0
   TRACE PROPERTY  nmos_rf_diff_nw  lr lr 0
   TRACE PROPERTY  nmos_rf_diff_nw  nr nr 0
   TRACE PROPERTY  nmos_rf_hvt  wr wr 0
   TRACE PROPERTY  nmos_rf_hvt  lr lr 0
   TRACE PROPERTY  nmos_rf_hvt  nr nr 0
   TRACE PROPERTY  nmos_rf_hvt_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_hvt_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_hvt_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_hvt_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_hvt_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_hvt_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_lvt  wr wr 0
   TRACE PROPERTY  nmos_rf_lvt  lr lr 0
   TRACE PROPERTY  nmos_rf_lvt  nr nr 0
   TRACE PROPERTY  nmos_rf_lvt_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_lvt_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_lvt_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_lvt_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_lvt_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_lvt_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_mlvt  wr wr 0
   TRACE PROPERTY  nmos_rf_mlvt  lr lr 0
   TRACE PROPERTY  nmos_rf_mlvt  nr nr 0
   TRACE PROPERTY  nmos_rf_mlvt_6t  wr wr 0
   TRACE PROPERTY  nmos_rf_mlvt_6t  lr lr 0
   TRACE PROPERTY  nmos_rf_mlvt_6t  nr nr 0
   TRACE PROPERTY  nmos_rf_mlvt_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_mlvt_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_mlvt_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_na18  wr wr 0
   TRACE PROPERTY  nmos_rf_na18  lr lr 0
   TRACE PROPERTY  nmos_rf_na18  nr nr 0
   TRACE PROPERTY  nmos_rf_nodnw  wr wr 0
   TRACE PROPERTY  nmos_rf_nodnw  lr lr 0
   TRACE PROPERTY  nmos_rf_nodnw  nr nr 0
   TRACE PROPERTY  nmos_rf_rdk  wr wr 0
   TRACE PROPERTY  nmos_rf_rdk  lr lr 0
   TRACE PROPERTY  nmos_rf_rdk  nr nr 0
   TRACE PROPERTY  nmoscap  wr wr 0
   TRACE PROPERTY  nmoscap  lr lr 0
   TRACE PROPERTY  nmoscap_18  wr wr 0
   TRACE PROPERTY  nmoscap_18  lr lr 0
   TRACE PROPERTY  nmoscap_25  wr wr 0
   TRACE PROPERTY  nmoscap_25  lr lr 0
   TRACE PROPERTY  nmoscap_33  wr wr 0
   TRACE PROPERTY  nmoscap_33  lr lr 0
   TRACE PROPERTY  nmoscap_lpg  wr wr 0
   TRACE PROPERTY  nmoscap_lpg  lr lr 0
   TRACE PROPERTY  pdio_hia_rf  al al 0
   TRACE PROPERTY  pdio_hia_rf  aw aw 0
   TRACE PROPERTY  pmos_rf  wr wr 0
   TRACE PROPERTY  pmos_rf  lr lr 0
   TRACE PROPERTY  pmos_rf  nr nr 0
   TRACE PROPERTY  pmos_rf_18  wr wr 0
   TRACE PROPERTY  pmos_rf_18  lr lr 0
   TRACE PROPERTY  pmos_rf_18  nr nr 0
   TRACE PROPERTY  pmos_rf_18_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_18_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_18_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_18_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_18_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_18_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_18_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_18_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_18_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25  wr wr 0
   TRACE PROPERTY  pmos_rf_25  lr lr 0
   TRACE PROPERTY  pmos_rf_25  nr nr 0
   TRACE PROPERTY  pmos_rf_25_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_25_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_25_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_25_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25_nwod  wr wr 0
   TRACE PROPERTY  pmos_rf_25_nwod  lr lr 0
   TRACE PROPERTY  pmos_rf_25_nwod  nr nr 0
   TRACE PROPERTY  pmos_rf_25_nwud  wr wr 0
   TRACE PROPERTY  pmos_rf_25_nwud  lr lr 0
   TRACE PROPERTY  pmos_rf_25_nwud  nr nr 0
   TRACE PROPERTY  pmos_rf_25od  wr wr 0
   TRACE PROPERTY  pmos_rf_25od  lr lr 0
   TRACE PROPERTY  pmos_rf_25od  nr nr 0
   TRACE PROPERTY  pmos_rf_25od33_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25od33_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25od33_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25od33_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25od33_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25od33_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25ud  wr wr 0
   TRACE PROPERTY  pmos_rf_25ud  lr lr 0
   TRACE PROPERTY  pmos_rf_25ud  nr nr 0
   TRACE PROPERTY  pmos_rf_25ud18_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25ud18_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25ud18_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_25ud18_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_25ud18_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_25ud18_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_33  wr wr 0
   TRACE PROPERTY  pmos_rf_33  lr lr 0
   TRACE PROPERTY  pmos_rf_33  nr nr 0
   TRACE PROPERTY  pmos_rf_33_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_33_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_33_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_33_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_33_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_33_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_33_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_33_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_33_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_hvt  wr wr 0
   TRACE PROPERTY  pmos_rf_hvt  lr lr 0
   TRACE PROPERTY  pmos_rf_hvt  nr nr 0
   TRACE PROPERTY  pmos_rf_hvt_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_hvt_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_hvt_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_hvt_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_hvt_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_hvt_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_hvt_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_hvt_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_hvt_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_lvt  wr wr 0
   TRACE PROPERTY  pmos_rf_lvt  lr lr 0
   TRACE PROPERTY  pmos_rf_lvt  nr nr 0
   TRACE PROPERTY  pmos_rf_lvt_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_lvt_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_lvt_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_lvt_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_lvt_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_lvt_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_lvt_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_lvt_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_lvt_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_mlvt  wr wr 0
   TRACE PROPERTY  pmos_rf_mlvt  lr lr 0
   TRACE PROPERTY  pmos_rf_mlvt  nr nr 0
   TRACE PROPERTY  pmos_rf_mlvt_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_mlvt_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_mlvt_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_mlvt_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_nw  wr wr 0
   TRACE PROPERTY  pmos_rf_nw  lr lr 0
   TRACE PROPERTY  pmos_rf_nw  nr nr 0
   TRACE PROPERTY  pmos_rf_nw_5t  wr wr 0
   TRACE PROPERTY  pmos_rf_nw_5t  lr lr 0
   TRACE PROPERTY  pmos_rf_nw_5t  nr nr 0
   TRACE PROPERTY  pmos_rf_rdk  wr wr 0
   TRACE PROPERTY  pmos_rf_rdk  lr lr 0
   TRACE PROPERTY  pmos_rf_rdk  nr nr 0
   TRACE PROPERTY  pmoscap_rf  lr lr 0
   TRACE PROPERTY  pmoscap_rf  wr wr 0
   TRACE PROPERTY  pmoscap_rf  br br 0
   TRACE PROPERTY  pmoscap_rf  gr gr 0
   TRACE PROPERTY  pmoscap_rf18  lr lr 0
   TRACE PROPERTY  pmoscap_rf18  wr wr 0
   TRACE PROPERTY  pmoscap_rf18  br br 0
   TRACE PROPERTY  pmoscap_rf18  gr gr 0
   TRACE PROPERTY  pmoscap_rf25  lr lr 0
   TRACE PROPERTY  pmoscap_rf25  wr wr 0
   TRACE PROPERTY  pmoscap_rf25  br br 0
   TRACE PROPERTY  pmoscap_rf25  gr gr 0
   TRACE PROPERTY  probe1  a a 0
   TRACE PROPERTY  probe1  pj pj 0
   TRACE PROPERTY  probe2  a a 0
   TRACE PROPERTY  probe2  pj pj 0
   TRACE PROPERTY  probe3  a a 0
   TRACE PROPERTY  probe3  pj pj 0
   TRACE PROPERTY  probe4  a a 0
   TRACE PROPERTY  probe4  pj pj 0
   TRACE PROPERTY  probe5  a a 0
   TRACE PROPERTY  probe5  pj pj 0
   TRACE PROPERTY  probe6  a a 0
   TRACE PROPERTY  probe6  pj pj 0
   TRACE PROPERTY  probe7  a a 0
   TRACE PROPERTY  probe7  pj pj 0
   TRACE PROPERTY  rfesd_rf1  lay lay 0
   TRACE PROPERTY  rfesd_rf2  lay lay 0
   TRACE PROPERTY  rfesd_rf3  lay lay 0
   TRACE PROPERTY  rfesd_rf4  lay lay 0
   TRACE PROPERTY  rfesd_rf5  lay lay 0
   TRACE PROPERTY  rfesd_rf6  lay lay 0
   TRACE PROPERTY  rfesd_rf7  lay lay 0
   TRACE PROPERTY  rfesd_rf8  lay lay 0
   TRACE PROPERTY  rm1  w w 0
   TRACE PROPERTY  rm1  l l 0
   TRACE PROPERTY  rm10  w w 0
   TRACE PROPERTY  rm10  l l 0
   TRACE PROPERTY  rm2  w w 0
   TRACE PROPERTY  rm2  l l 0
   TRACE PROPERTY  rm3  w w 0
   TRACE PROPERTY  rm3  l l 0
   TRACE PROPERTY  rm4  w w 0
   TRACE PROPERTY  rm4  l l 0
   TRACE PROPERTY  rm5  w w 0
   TRACE PROPERTY  rm5  l l 0
   TRACE PROPERTY  rm6  w w 0
   TRACE PROPERTY  rm6  l l 0
   TRACE PROPERTY  rm7  w w 0
   TRACE PROPERTY  rm7  l l 0
   TRACE PROPERTY  rm8  w w 0
   TRACE PROPERTY  rm8  l l 0
   TRACE PROPERTY  rm9  w w 0
   TRACE PROPERTY  rm9  l l 0
   TRACE PROPERTY  rnodl  l l 0
   TRACE PROPERTY  rnodl  w w 0
   TRACE PROPERTY  rnodl_m  lr lr 0
   TRACE PROPERTY  rnodl_m  wr wr 0
   TRACE PROPERTY  rnods  l l 0
   TRACE PROPERTY  rnods  w w 0
   TRACE PROPERTY  rnods_m  lr lr 0
   TRACE PROPERTY  rnods_m  wr wr 0
   TRACE PROPERTY  rnodwo  l l 0
   TRACE PROPERTY  rnodwo  w w 0
   TRACE PROPERTY  rnodwo_m  lr lr 0
   TRACE PROPERTY  rnodwo_m  wr wr 0
   TRACE PROPERTY  rnpolyl  l l 0
   TRACE PROPERTY  rnpolyl  w w 0
   TRACE PROPERTY  rnpolyl_m  lr lr 0
   TRACE PROPERTY  rnpolyl_m  wr wr 0
   TRACE PROPERTY  rnpolys  l l 0
   TRACE PROPERTY  rnpolys  w w 0
   TRACE PROPERTY  rnpolys_m  lr lr 0
   TRACE PROPERTY  rnpolys_m  wr wr 0
   TRACE PROPERTY  rnpolywo  l l 0
   TRACE PROPERTY  rnpolywo  w w 0
   TRACE PROPERTY  rnpolywo_m  lr lr 0
   TRACE PROPERTY  rnpolywo_m  wr wr 0
   TRACE PROPERTY  rnwod  l l 0
   TRACE PROPERTY  rnwod  w w 0
   TRACE PROPERTY  rnwod_m  lr lr 0
   TRACE PROPERTY  rnwod_m  wr wr 0
   TRACE PROPERTY  rnwsti  l l 0
   TRACE PROPERTY  rnwsti  w w 0
   TRACE PROPERTY  rnwsti_m  lr lr 0
   TRACE PROPERTY  rnwsti_m  wr wr 0
   TRACE PROPERTY  rpodl  l l 0
   TRACE PROPERTY  rpodl  w w 0
   TRACE PROPERTY  rpodl_m  lr lr 0
   TRACE PROPERTY  rpodl_m  wr wr 0
   TRACE PROPERTY  rpods  l l 0
   TRACE PROPERTY  rpods  w w 0
   TRACE PROPERTY  rpods_m  lr lr 0
   TRACE PROPERTY  rpods_m  wr wr 0
   TRACE PROPERTY  rpodwo  l l 0
   TRACE PROPERTY  rpodwo  w w 0
   TRACE PROPERTY  rpodwo_m  lr lr 0
   TRACE PROPERTY  rpodwo_m  wr wr 0
   TRACE PROPERTY  rppolyl  l l 0
   TRACE PROPERTY  rppolyl  w w 0
   TRACE PROPERTY  rppolyl_m  lr lr 0
   TRACE PROPERTY  rppolyl_m  wr wr 0
   TRACE PROPERTY  rppolyl_rf  w w 0
   TRACE PROPERTY  rppolyl_rf  l l 0
   TRACE PROPERTY  rppolyl_rf_rdk  w w 0
   TRACE PROPERTY  rppolyl_rf_rdk  l l 0
   TRACE PROPERTY  rppolys  l l 0
   TRACE PROPERTY  rppolys  w w 0
   TRACE PROPERTY  rppolys_m  lr lr 0
   TRACE PROPERTY  rppolys_m  wr wr 0
   TRACE PROPERTY  rppolys_rf  w w 0
   TRACE PROPERTY  rppolys_rf  l l 0
   TRACE PROPERTY  rppolys_rf_rdk  w w 0
   TRACE PROPERTY  rppolys_rf_rdk  l l 0
   TRACE PROPERTY  rppolywo  l l 0
   TRACE PROPERTY  rppolywo  w w 0
   TRACE PROPERTY  rppolywo_m  lr lr 0
   TRACE PROPERTY  rppolywo_m  wr wr 0
   TRACE PROPERTY  rppolywo_rf  w w 0
   TRACE PROPERTY  rppolywo_rf  l l 0
   TRACE PROPERTY  rppolywo_rf_rdk  w w 0
   TRACE PROPERTY  rppolywo_rf_rdk  l l 0
   TRACE PROPERTY  sbd_rf  nf nf 0
   TRACE PROPERTY  sbd_rf  w w 0
   TRACE PROPERTY  sbd_rf  l l 0
   TRACE PROPERTY  sbd_rf_nw  nf nf 0
   TRACE PROPERTY  sbd_rf_nw  w w 0
   TRACE PROPERTY  sbd_rf_nw  l l 0
   TRACE PROPERTY  sline_gscpw_mu  l l 0
   TRACE PROPERTY  sline_gscpw_mu  s s 0
   TRACE PROPERTY  sline_gscpw_mu  w w 0
   TRACE PROPERTY  sline_gscpw_mu  lay lay 0
   TRACE PROPERTY  sline_ms_mu  l l 0
   TRACE PROPERTY  sline_ms_mu  w w 0
   TRACE PROPERTY  sline_ms_mu  lay lay 0
   TRACE PROPERTY  spiral_std_mu_z  lay lay 0
   TRACE PROPERTY  spiral_std_mu_z  w w 0.05
   TRACE PROPERTY  spiral_std_mu_z  nr nr 0
   TRACE PROPERTY  spiral_std_mu_z  rad rad 0
   TRACE PROPERTY  spiral_std_mu_z  gdis gdis 0
   TRACE PROPERTY  spiral_std_mu_z  spacing spacing 0
   TRACE PROPERTY  spiral_std_mu_z_rdk  lay lay 0
   TRACE PROPERTY  spiral_std_mu_z_rdk  w w 0.05
   TRACE PROPERTY  spiral_std_mu_z_rdk  nr nr 0
   TRACE PROPERTY  spiral_std_mu_z_rdk  rad rad 0
   TRACE PROPERTY  spiral_std_mu_z_rdk  gdis gdis 0
   TRACE PROPERTY  spiral_std_mu_z_rdk  spacing spacing 0
   TRACE PROPERTY  spiral_sym_ct_mu_z  lay lay 0
   TRACE PROPERTY  spiral_sym_ct_mu_z  w w 0.05
   TRACE PROPERTY  spiral_sym_ct_mu_z  nr nr 0
   TRACE PROPERTY  spiral_sym_ct_mu_z  rad rad 0
   TRACE PROPERTY  spiral_sym_ct_mu_z  gdis gdis 0
   TRACE PROPERTY  spiral_sym_ct_mu_z  spacing spacing 0
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  lay lay 0
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  w w 0.05
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  nr nr 0
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  rad rad 0
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  gdis gdis 0
   TRACE PROPERTY  spiral_sym_ct_mu_z_rdk  spacing spacing 0
   TRACE PROPERTY  spiral_sym_mu_z  lay lay 0
   TRACE PROPERTY  spiral_sym_mu_z  w w 0.05
   TRACE PROPERTY  spiral_sym_mu_z  nr nr 0
   TRACE PROPERTY  spiral_sym_mu_z  rad rad 0
   TRACE PROPERTY  spiral_sym_mu_z  gdis gdis 0
   TRACE PROPERTY  spiral_sym_mu_z  spacing spacing 0
   TRACE PROPERTY  spiral_sym_mu_z_rdk  lay lay 0
   TRACE PROPERTY  spiral_sym_mu_z_rdk  w w 0.05
   TRACE PROPERTY  spiral_sym_mu_z_rdk  nr nr 0
   TRACE PROPERTY  spiral_sym_mu_z_rdk  rad rad 0
   TRACE PROPERTY  spiral_sym_mu_z_rdk  gdis gdis 0
   TRACE PROPERTY  spiral_sym_mu_z_rdk  spacing spacing 0
   TRACE PROPERTY  xjvar  w w 0
   TRACE PROPERTY  xjvar  l l 0
   TRACE PROPERTY  xjvar  nr nr 0
   TRACE PROPERTY  xjvar_nw  w w 0
   TRACE PROPERTY  xjvar_nw  l l 0
   TRACE PROPERTY  xjvar_nw  nr nr 0
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         Traffic_TOP_Pad_final
SOURCE CELL NAME:         Traffic_TOP_Pad
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             25        26    *
Nets:            2601      2557    *
Instances:       3255      2872    *    MN (4 pins)
                  2967      2702    *    MP (4 pins)
                   262       262         rnpolywo (2 pins)
                   387       386    *    rppolywo (2 pins)
                   519        84    *    D (2 pins)
Total Inst:      7390      6306
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             25        25
Nets:            1420      1418    *
Instances:        498       500    *    MN (4 pins)
                   393       393         MP (4 pins)
                    53        53         rnpolywo (2 pins)
                    94        93    *    rppolywo (2 pins)
                    77        73    *    D (2 pins)
                    15        15         SPDW_2_1 (4 pins)
                     1         1         SPDW_2_1_1 (5 pins)
                     4         4         SPDW_2_2 (5 pins)
                     1         1         SPDW_2_2_1 (6 pins)
                     3         3         SPDW_2_2_2 (7 pins)
                     1         1         SPDW_3_2 (6 pins)
                    65        65         SPUP_2_1 (4 pins)
                     2         2         SPUP_2_1_1 (5 pins)
                     3         3         SPUP_2_2 (5 pins)
                     2         2         SPUP_3_1 (5 pins)
                     3         3         SPUP_3_2 (6 pins)
                    22        22         SMN2 (4 pins)
                    22        22         SMP2 (4 pins)
                     1         1         SPMN((((2+2)*1)+2)*1) (10 pins)
                    22        22         SPMN((2+2)*1) (7 pins)
                     1         1         SPMN((2+2)*2) (8 pins)
                     1         1         SPMP((((2+2)*1)+2)*1) (10 pins)
                    22        22         SPMP((2+2)*1) (7 pins)
                    46        46         _invb (6 pins)
                   473       472    *    _invv (4 pins)
                    58        58         _invx2v (4 pins)
                     1         1         _invx3v (4 pins)
                    84        84         _nand2v (5 pins)
                     3         3         _nand3v (6 pins)
                     4         4         _nand4v (7 pins)
                    46        46         _nor2v (5 pins)
                     2         2         _nor3v (6 pins)
                     8         7    *    _nor4v (7 pins)
                    64        64         _pdw2v (4 pins)
                    11        11         _pup2b (5 pins)
                     6         6         _pup2v (4 pins)
                    20        20         _smn2b (5 pins)
                   362       362         _smn2v (4 pins)
                    50        50         _smn3v (5 pins)
                   103       103         _smp2v (4 pins)
                     2         4    *    _smp4v (6 pins)
                     1         1         _sup3v (5 pins)
                     1         1         _xnor2v (5 pins)
Total Inst:      2651      2648
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net VDD                                                   VDD
       --- 838 Connections On This Net ---                       --- 835 Connections On This Net ---
       (_nor4v):sup1                                             ** missing connection **
         X40/X202/M5(235.510,258.795):b
         X40/X202/M6(235.250,258.795):b
         X40/X202/M7(234.990,258.795):b
         X40/X202/M4(235.770,258.795):b
         X40/X202/M4(235.770,258.795):s
       (_invv):sup1                                              ** missing connection **
         X29/X0/X31/M0(113.815,305.395):b
         X29/X0/X31/M0(113.815,305.395):d
       X29/X1/M0(139.330,307.565):d                              ** missing connection **
       X29/X0/X10(88.970,308.650)LUS                           ** missing connection **
       X29/X0/D9(1.565,285.050):neg                              ** missing connection **
       ** missing connection **                                  (_smp4v)ut2
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI30:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI31:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI32:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI29:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI29:s
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI26:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI7:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI27:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI28:b
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI28:s
  2    Net VSSPST                                                VSSPST
       --- 291 Connections On This Net ---                       --- 287 Connections On This Net ---
       X65/D9(548.445,302.790):pos                               ** missing connection **
       X65/D4(584.495,302.790):neg                               ** missing connection **
       X29/X0/D9(1.565,285.050):pos                              ** missing connection **
       X29/X0/X26/X0/X0/X0/X0/M0(48.795,307.565):b               ** missing connection **
  3    Net VSS                                                   VSS
       --- 1764 Connections On This Net ---                      --- 1763 Connections On This Net ---
       (_nor4v):sup2                                             ** missing connection **
         X40/X202/M1(235.510,258.080):b
         X40/X202/M1(235.510,258.080):d
         X40/X202/M2(235.250,258.080):b
         X40/X202/M2(235.250,258.080):s
         X40/X202/M3(234.990,258.080):b
         X40/X202/M3(234.990,258.080):d
         X40/X202/M0(235.770,258.080):b
         X40/X202/M0(235.770,258.080):s
       (_invv):sup2                                              ** missing connection **
         X29/X1/M48(136.420,307.565):b
         X29/X1/M48(136.420,307.565):d
       X65/X10/D9(480.325,302.790):pos                           ** missing connection **
       X65/D9(548.445,302.790):neg                               ** missing connection **
       X65/D4(584.495,302.790):pos                               ** missing connection **
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI5:b
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI38:b
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI39:b
       X29/X0/X26/X0/X0/X0/X0/M0(48.795,307.565):d               ** unmatched connection **
       X29/X0/X26/X0/X0/X0/X0/M0(48.795,307.565):s               ** unmatched connection **
       ** unmatched connection **                                Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI5:s
       ** unmatched connection **                                Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI38:s
       ** unmatched connection **                                Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI39:s
  4    Net 17                                                    Xu_Traffic_TOP/Xcounter_UNIT/n9
       --- 2 Connections On This Net ---                         --- 7 Connections On This Net ---
       (_nor4v)ut                                              ** missing connection **
         X40/X202/M1(235.510,258.080):s
         X40/X202/M2(235.250,258.080):d
         X40/X202/M3(234.990,258.080):s
         X40/X202/M0(235.770,258.080):d
         X40/X202/M5(235.510,258.795):s
       ** missing connection **                                  (_smp4v):out1
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI30:s
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI26:s
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI5:d
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI37:d
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI38:d
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI39:d
  5    Net 52                                                    Xu_Traffic_TOP/Xcounter_UNIT/cnt[24]
       --- 7 Connections On This Net ---                         --- 9 Connections On This Net ---
       (_nor4v):in2                                              ** missing connection **
         X40/X202/M3(234.990,258.080):g
         X40/X202/M7(234.990,258.795):g
       ** missing connection **                                  (_smp4v):in1
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI29:g
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI28:g
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI5:g
  6    Net X40/32                                                Xu_Traffic_TOP/Xcounter_UNIT/cnt[26]
       (_nor4v):in4                                              ** missing connection **
         X40/X202/M1(235.510,258.080):g
         X40/X202/M5(235.510,258.795):g
       ** missing connection **                                  (_smp4v):in3
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI31:g
       ** missing connection **                                  (_smp4v):in4
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI26:g
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI38:g
  7    Net X40/26                                                Xu_Traffic_TOP/Xcounter_UNIT/cnt[27]
       --- 5 Connections On This Net ---                         --- 7 Connections On This Net ---
       (_nor4v):in1                                              ** missing connection **
         X40/X202/M0(235.770,258.080):g
         X40/X202/M4(235.770,258.795):g
       ** missing connection **                                  (_smp4v):in2
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI32:g
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI7:g
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI39:g
  8    Net X40/33                                                Xu_Traffic_TOP/Xcounter_UNIT/cnt[25]
       (_nor4v):in3                                              ** missing connection **
         X40/X202/M2(235.250,258.080):g
         X40/X202/M6(235.250,258.795):g
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI30:g
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI27:g
       ** missing connection **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI37:g
  9    Net X29/8                                                 ** missing net **
10    Net X29/9                                                 ** missing net **
                                 INCORRECT INSTANCES
11    X29/X1/M0(139.330,307.565)  MN(nch_hvt)                   Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI37  MN(nch)
         bad component subtype
12    X29/X0/D9(1.565,285.050)  D(ndio_25od)                    ** missing instance **
13    X29/X0/X10(88.970,308.650)  rppolywo                      ** missing instance **
14    X65/D4(584.495,302.790)  D(pdio)                          ** missing instance **
15    X65/D9(548.445,302.790)  D(ndio)                          ** missing instance **
16    X65/X10/D9(480.325,302.790)  D(pdio_25od)                 ** missing instance **
17    (_invv)                                                   ** missing injected instance **
       Devices:
         X29/X0/X31/M0(113.815,305.395)  MP(pch_25od)
         X29/X1/M48(136.420,307.565)  MN(nch_25od)
18    (_nor4v)                                                  ** missing injected instance **
       Devices:
         X40/X202/M4(235.770,258.795)  MP(pch)
         X40/X202/M7(234.990,258.795)  MP(pch)
         X40/X202/M6(235.250,258.795)  MP(pch)
         X40/X202/M5(235.510,258.795)  MP(pch)
         X40/X202/M0(235.770,258.080)  MN(nch)
         X40/X202/M3(234.990,258.080)  MN(nch)
         X40/X202/M2(235.250,258.080)  MN(nch)
         X40/X202/M1(235.510,258.080)  MN(nch)
19    ** missing injected instance **                           (_smp4v)
        Devices:
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI28  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI27  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI7  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI26  MP(pch)
20    ** missing injected instance **                           (_smp4v)
        Devices:
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI29  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI32  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI31  MP(pch)
        Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI30  MP(pch)
                                      PROPERTY ERRORS
DISC#  LAYOUT                                                    SOURCE                      ERROR
21    X69/X0/X2/X0/D4(417.380,332.790)  D(pdio)                 Xio_ground1/D_0  D(pdio)
       a: 289.062 sq u                                           a: 192.708 sq u               50%
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:              25         25            0            0
   Nets:             1418       1418            2            0
   Instances:         197        197            0            3    MN(nch)
                      218        218            1            0    MN(nch_25od)
                       82         82            0            0    MN(nch_na25)
                      126        126            0            0    MP(pch)
                      267        267            0            0    MP(pch_25od)
                       53         53            0            0    rnpolywo
                       93         93            1            0    rppolywo
                       51         51            1            0    D(ndio)
                        0          0            1            0    D(ndio_25od)
                       20         20            0            0    D(ndio_esd)
                        1          1            1            0    D(pdio)
                        1          1            1            0    D(pdio_25od)
                       15         15            0            0    SPDW_2_1
                        1          1            0            0    SPDW_2_1_1
                        4          4            0            0    SPDW_2_2
                        1          1            0            0    SPDW_2_2_1
                        3          3            0            0    SPDW_2_2_2
                        1          1            0            0    SPDW_3_2
                       65         65            0            0    SPUP_2_1
                        2          2            0            0    SPUP_2_1_1
                        3          3            0            0    SPUP_2_2
                        2          2            0            0    SPUP_3_1
                        3          3            0            0    SPUP_3_2
                       22         22            0            0    SMN2
                       22         22            0            0    SMP2
                        1          1            0            0    SPMN((((2+2)*1)+2)*1)
                       22         22            0            0    SPMN((2+2)*1)
                        1          1            0            0    SPMN((2+2)*2)
                        1          1            0            0    SPMP((((2+2)*1)+2)*1)
                       22         22            0            0    SPMP((2+2)*1)
                       46         46            0            0    _invb
                      472        472            1            0    _invv
                       58         58            0            0    _invx2v
                        1          1            0            0    _invx3v
                       84         84            0            0    _nand2v
                        3          3            0            0    _nand3v
                        4          4            0            0    _nand4v
                       46         46            0            0    _nor2v
                        2          2            0            0    _nor3v
                        7          7            1            0    _nor4v
                       64         64            0            0    _pdw2v
                       11         11            0            0    _pup2b
                        6          6            0            0    _pup2v
                       20         20            0            0    _smn2b
                      362        362            0            0    _smn2v
                       50         50            0            0    _smn3v
                      103        103            0            0    _smp2v
                        2          2            0            2    _smp4v
                        1          1            0            0    _sup3v
                        1          1            0            0    _xnor2v
   Total Inst:       2643       2643            8            5
o Statistics:
   46 isolated layout nets were deleted.
   1 passthrough source net was deleted.
   274 layout instances were filtered and their pins removed from adjoining nets.
   1908 layout mos transistors were reduced to 465.
     1443 mos transistors were deleted by parallel reduction.
   882 source mos transistors were reduced to 87.
     795 mos transistors were deleted by parallel reduction.
   566 series/parallel layout resistors were reduced to 64.  4 connecting nets were deleted.
   566 series/parallel source resistors were reduced to 64.  4 connecting nets were deleted.
   203 parallel layout diodes were reduced to 35.
   22 parallel source diodes were reduced to 11.
   2 nets and 58 instances were matched arbitrarily.
o Initial Correspondence Points:
   Ports:        VDDPST VDD POC VSSPST VSS s_o light[0] light[1] light[2] light[7] clk rst_n
                 light[8] flow[0] light[9] flow[1] flow[2] s_e flow[3] s_i flow[4] light[3]
                 light[4] light[5] light[6]
o Ambiguity Resolution Points:
      (Each one of the following objects belongs to a group of indistinguishable objects.
       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
       Layout                                                    Source
                                     Nets
       X30/X0/X0/8                                               Xio_power2/net_6649
       X28/X1/X0/15                                              Xio_power2/net_6637
                                   Instances
       (_invx2v)                                                 (_invx2v)
       Devices:
         X28/X1/X0/X1/M10(136.040,262.210)  MP(pch_25od)           Xio_power1/M_15  MP(pch_25od)
         X28/X1/X0/X3/X8/M0(147.800,262.250)  MN(nch_25od)         Xio_power1/M_48  MN(nch_25od)
         X28/X1/X0/X1/M11(136.040,260.415)  MP(pch_25od)           Xio_power1/M_10  MP(pch_25od)
         X28/X1/X0/X3/X9/M0(147.800,260.500)  MN(nch_25od)         Xio_power1/M_43  MN(nch_25od)
       (_invx2v)                                                 (_invx2v)
       Devices:
         X30/X1/X0/X1/M10(136.040,322.210)  MP(pch_25od)           Xio_power2/M_15  MP(pch_25od)
         X30/X1/X0/X3/X8/M0(147.800,322.250)  MN(nch_25od)         Xio_power2/M_48  MN(nch_25od)
         X30/X1/X0/X1/M11(136.040,320.415)  MP(pch_25od)           Xio_power2/M_10  MP(pch_25od)
         X30/X1/X0/X3/X9/M0(147.800,320.500)  MN(nch_25od)         Xio_power2/M_43  MN(nch_25od)
       (_smp4v)                                                  (_smp4v)
       Devices:
         X50/M42(307.630,305.595)  MP(pch)                         Xu_Traffic_TOP/Xcounter_UNIT/XU66/MI29  MP(pch)
         X50/M49(308.720,305.595)  MP(pch)                         Xu_Traffic_TOP/Xcounter_UNIT/XU66/MI32  MP(pch)
         X50/M50(308.910,305.595)  MP(pch)                         Xu_Traffic_TOP/Xcounter_UNIT/XU66/MI31  MP(pch)
         X50/M41(307.440,305.595)  MP(pch)                         Xu_Traffic_TOP/Xcounter_UNIT/XU66/MI30  MP(pch)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X41/M44(273.685,324.685)  MP(pch)                         Xu_Traffic_TOP/XFSM_UNIT/XU32/MI5_0  MP(pch)
         X41/M45(273.945,324.685)  MP(pch)                         Xu_Traffic_TOP/XFSM_UNIT/XU32/MI12_0  MP(pch)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X42/X66/M16(226.150,361.755)  MN(nch)                     Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[2]/MI158_0-M_u3  MN(nch)
         X42/X66/M15(226.380,361.755)  MN(nch)                     Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[2]/MI158_0-M_u4  MN(nch)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X40/X203/M16(239.950,228.555)  MN(nch)                    Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[0]/MI158_0-M_u3  MN(nch)
         X40/X203/M15(240.180,228.555)  MN(nch)                    Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[0]/MI158_0-M_u4  MN(nch)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X51/X28/M16(363.650,361.755)  MN(nch)                     Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[6]/MI158_0-M_u3  MN(nch)
         X51/X28/M15(363.420,361.755)  MN(nch)                     Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[6]/MI158_0-M_u4  MN(nch)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X49/X112/M16(364.050,242.955)  MN(nch)                    Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[4]/MI158_0-M_u3  MN(nch)
         X49/X112/M15(363.820,242.955)  MN(nch)                    Xu_Traffic_TOP/XFSM_UNIT/Xlight_reg[4]/MI158_0-M_u4  MN(nch)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X8/M1(517.745,201.385)  MN(nch_25od)      Xopad_light3/M_39  MN(nch_25od)
         X63/X0/X1/X0/X3/X8/M2(517.745,202.135)  MN(nch_25od)      Xopad_light3/M_50  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X7/M4(517.745,199.295)  MN(nch_25od)      Xopad_light3/M_38  MN(nch_25od)
         X63/X0/X1/X0/X3/X7/M3(517.745,198.545)  MN(nch_25od)      Xopad_light3/M_49  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X6/M4(587.385,210.705)  MN(nch_25od)      Xopad_light3/M_37  MN(nch_25od)
         X63/X0/X1/X0/X3/X6/M3(587.385,211.455)  MN(nch_25od)      Xopad_light3/M_48  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X6/M1(587.385,217.435)  MN(nch_25od)      Xopad_light3/M_36  MN(nch_25od)
         X63/X0/X1/X0/X3/X6/M2(587.385,216.685)  MN(nch_25od)      Xopad_light3/M_47  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X5/M4(587.385,201.885)  MN(nch_25od)      Xopad_light3/M_35  MN(nch_25od)
         X63/X0/X1/X0/X3/X5/M3(587.385,202.635)  MN(nch_25od)      Xopad_light3/M_46  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X5/M1(587.385,208.615)  MN(nch_25od)      Xopad_light3/M_34  MN(nch_25od)
         X63/X0/X1/X0/X3/X5/M2(587.385,207.865)  MN(nch_25od)      Xopad_light3/M_45  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X4/M4(587.385,193.065)  MN(nch_25od)      Xopad_light3/M_33  MN(nch_25od)
         X63/X0/X1/X0/X3/X4/M3(587.385,193.815)  MN(nch_25od)      Xopad_light3/M_44  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X4/M1(587.385,199.795)  MN(nch_25od)      Xopad_light3/M_32  MN(nch_25od)
         X63/X0/X1/X0/X3/X4/M2(587.385,199.045)  MN(nch_25od)      Xopad_light3/M_43  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X8/M4(517.745,208.115)  MN(nch_25od)      Xopad_light3/M_31  MN(nch_25od)
         X63/X0/X1/X0/X3/X8/M3(517.745,207.365)  MN(nch_25od)      Xopad_light3/M_42  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X63/X0/X1/X0/X3/X9/M1(517.745,210.205)  MN(nch_25od)      Xopad_light3/M_30  MN(nch_25od)
         X63/X0/X1/X0/X3/X9/M2(517.745,210.955)  MN(nch_25od)      Xopad_light3/M_41  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X8/M1(517.745,231.385)  MN(nch_25od)      Xopad_light4/M_39  MN(nch_25od)
         X64/X0/X1/X0/X3/X8/M2(517.745,232.135)  MN(nch_25od)      Xopad_light4/M_50  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X7/M4(517.745,229.295)  MN(nch_25od)      Xopad_light4/M_38  MN(nch_25od)
         X64/X0/X1/X0/X3/X7/M3(517.745,228.545)  MN(nch_25od)      Xopad_light4/M_49  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X6/M4(587.385,240.705)  MN(nch_25od)      Xopad_light4/M_37  MN(nch_25od)
         X64/X0/X1/X0/X3/X6/M3(587.385,241.455)  MN(nch_25od)      Xopad_light4/M_48  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X6/M1(587.385,247.435)  MN(nch_25od)      Xopad_light4/M_36  MN(nch_25od)
         X64/X0/X1/X0/X3/X6/M2(587.385,246.685)  MN(nch_25od)      Xopad_light4/M_47  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X5/M4(587.385,231.885)  MN(nch_25od)      Xopad_light4/M_35  MN(nch_25od)
         X64/X0/X1/X0/X3/X5/M3(587.385,232.635)  MN(nch_25od)      Xopad_light4/M_46  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X5/M1(587.385,238.615)  MN(nch_25od)      Xopad_light4/M_34  MN(nch_25od)
         X64/X0/X1/X0/X3/X5/M2(587.385,237.865)  MN(nch_25od)      Xopad_light4/M_45  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X4/M4(587.385,223.065)  MN(nch_25od)      Xopad_light4/M_33  MN(nch_25od)
         X64/X0/X1/X0/X3/X4/M3(587.385,223.815)  MN(nch_25od)      Xopad_light4/M_44  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X4/M1(587.385,229.795)  MN(nch_25od)      Xopad_light4/M_32  MN(nch_25od)
         X64/X0/X1/X0/X3/X4/M2(587.385,229.045)  MN(nch_25od)      Xopad_light4/M_43  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X8/M4(517.745,238.115)  MN(nch_25od)      Xopad_light4/M_31  MN(nch_25od)
         X64/X0/X1/X0/X3/X8/M3(517.745,237.365)  MN(nch_25od)      Xopad_light4/M_42  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X64/X0/X1/X0/X3/X9/M1(517.745,240.205)  MN(nch_25od)      Xopad_light4/M_30  MN(nch_25od)
         X64/X0/X1/X0/X3/X9/M2(517.745,240.955)  MN(nch_25od)      Xopad_light4/M_41  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X8/M1(291.385,72.255)  MN(nch_25od)       Xopad_light9/M_39  MN(nch_25od)
         X46/X0/X1/X0/X3/X8/M2(292.135,72.255)  MN(nch_25od)       Xopad_light9/M_50  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X7/M4(289.295,72.255)  MN(nch_25od)       Xopad_light9/M_38  MN(nch_25od)
         X46/X0/X1/X0/X3/X7/M3(288.545,72.255)  MN(nch_25od)       Xopad_light9/M_49  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X6/M4(300.705,2.615)  MN(nch_25od)        Xopad_light9/M_37  MN(nch_25od)
         X46/X0/X1/X0/X3/X6/M3(301.455,2.615)  MN(nch_25od)        Xopad_light9/M_48  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X6/M1(307.435,2.615)  MN(nch_25od)        Xopad_light9/M_36  MN(nch_25od)
         X46/X0/X1/X0/X3/X6/M2(306.685,2.615)  MN(nch_25od)        Xopad_light9/M_47  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X5/M4(291.885,2.615)  MN(nch_25od)        Xopad_light9/M_35  MN(nch_25od)
         X46/X0/X1/X0/X3/X5/M3(292.635,2.615)  MN(nch_25od)        Xopad_light9/M_46  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X5/M1(298.615,2.615)  MN(nch_25od)        Xopad_light9/M_34  MN(nch_25od)
         X46/X0/X1/X0/X3/X5/M2(297.865,2.615)  MN(nch_25od)        Xopad_light9/M_45  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X4/M4(283.065,2.615)  MN(nch_25od)        Xopad_light9/M_33  MN(nch_25od)
         X46/X0/X1/X0/X3/X4/M3(283.815,2.615)  MN(nch_25od)        Xopad_light9/M_44  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X4/M1(289.795,2.615)  MN(nch_25od)        Xopad_light9/M_32  MN(nch_25od)
         X46/X0/X1/X0/X3/X4/M2(289.045,2.615)  MN(nch_25od)        Xopad_light9/M_43  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X8/M4(298.115,72.255)  MN(nch_25od)       Xopad_light9/M_31  MN(nch_25od)
         X46/X0/X1/X0/X3/X8/M3(297.365,72.255)  MN(nch_25od)       Xopad_light9/M_42  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X46/X0/X1/X0/X3/X9/M1(300.205,72.255)  MN(nch_25od)       Xopad_light9/M_30  MN(nch_25od)
         X46/X0/X1/X0/X3/X9/M2(300.955,72.255)  MN(nch_25od)       Xopad_light9/M_41  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X8/M1(72.255,358.615)  MN(nch_25od)       Xopad_light1/M_39  MN(nch_25od)
         X31/X0/X1/X0/X3/X8/M2(72.255,357.865)  MN(nch_25od)       Xopad_light1/M_50  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X7/M4(72.255,360.705)  MN(nch_25od)       Xopad_light1/M_38  MN(nch_25od)
         X31/X0/X1/X0/X3/X7/M3(72.255,361.455)  MN(nch_25od)       Xopad_light1/M_49  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X6/M4(2.615,349.295)  MN(nch_25od)        Xopad_light1/M_37  MN(nch_25od)
         X31/X0/X1/X0/X3/X6/M3(2.615,348.545)  MN(nch_25od)        Xopad_light1/M_48  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X6/M1(2.615,342.565)  MN(nch_25od)        Xopad_light1/M_36  MN(nch_25od)
         X31/X0/X1/X0/X3/X6/M2(2.615,343.315)  MN(nch_25od)        Xopad_light1/M_47  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X5/M4(2.615,358.115)  MN(nch_25od)        Xopad_light1/M_35  MN(nch_25od)
         X31/X0/X1/X0/X3/X5/M3(2.615,357.365)  MN(nch_25od)        Xopad_light1/M_46  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X5/M1(2.615,351.385)  MN(nch_25od)        Xopad_light1/M_34  MN(nch_25od)
         X31/X0/X1/X0/X3/X5/M2(2.615,352.135)  MN(nch_25od)        Xopad_light1/M_45  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X4/M4(2.615,366.935)  MN(nch_25od)        Xopad_light1/M_33  MN(nch_25od)
         X31/X0/X1/X0/X3/X4/M3(2.615,366.185)  MN(nch_25od)        Xopad_light1/M_44  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X4/M1(2.615,360.205)  MN(nch_25od)        Xopad_light1/M_32  MN(nch_25od)
         X31/X0/X1/X0/X3/X4/M2(2.615,360.955)  MN(nch_25od)        Xopad_light1/M_43  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X8/M4(72.255,351.885)  MN(nch_25od)       Xopad_light1/M_31  MN(nch_25od)
         X31/X0/X1/X0/X3/X8/M3(72.255,352.635)  MN(nch_25od)       Xopad_light1/M_42  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X31/X0/X1/X0/X3/X9/M1(72.255,349.795)  MN(nch_25od)       Xopad_light1/M_30  MN(nch_25od)
         X31/X0/X1/X0/X3/X9/M2(72.255,349.045)  MN(nch_25od)       Xopad_light1/M_41  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X26/X0/X1/X0/X3/X8/M1(72.255,208.615)  MN(nch_25od)       Xopad_s_o/M_39  MN(nch_25od)
         X26/X0/X1/X0/X3/X8/M2(72.255,207.865)  MN(nch_25od)       Xopad_s_o/M_50  MN(nch_25od)
       (_smn2v)                                                  (_smn2v)
       Devices:
         X26/X0/X1/X0/X3/X7/M4(72.255,210.705)  MN(nch_25od)       Xopad_s_o/M_38  MN(nch_25od)
         X26/X0/X1/X0/X3/X7/M3(72.255,211.455)  MN(nch_25od)       Xopad_s_o/M_49  MN(nch_25od)
o Matched Mosfets Which Have Been Unequally Reduced:
       X30/X0/X0/X1/X5/M0(66.095,338.205)                        Xio_power2/M_71
       X30/X0/X0/X1/X9/M0(66.095,316.765)                        Xio_power2/M_80
       X30/X0/X0/X1/X8/M0(66.095,322.125)                        Xio_power2/M_79
       X30/X0/X0/X1/X7/M0(66.095,327.485)                        Xio_power2/M_78
       X30/X0/X0/X1/X6/M0(66.095,332.845)                        Xio_power2/M_77
       ** missing smashed mosfet **                              Xio_power2/M_76
       ** missing smashed mosfet **                              Xio_power2/M_75
       ** missing smashed mosfet **                              Xio_power2/M_74
       ** missing smashed mosfet **                              Xio_power2/M_73
       ** missing smashed mosfet **                              Xio_power2/M_72
       X28/X0/X0/X1/X5/M0(66.095,278.205)                        Xio_power1/M_71
       X28/X0/X0/X1/X9/M0(66.095,256.765)                        Xio_power1/M_80
       X28/X0/X0/X1/X8/M0(66.095,262.125)                        Xio_power1/M_79
       X28/X0/X0/X1/X7/M0(66.095,267.485)                        Xio_power1/M_78
       X28/X0/X0/X1/X6/M0(66.095,272.845)                        Xio_power1/M_77
       ** missing smashed mosfet **                              Xio_power1/M_76
       ** missing smashed mosfet **                              Xio_power1/M_75
       ** missing smashed mosfet **                              Xio_power1/M_74
       ** missing smashed mosfet **                              Xio_power1/M_73
       ** missing smashed mosfet **                              Xio_power1/M_72
                             DETAILED INSTANCE CONNECTIONS
          (This section contains detailed information about connections of
           matched instances that are involved in net discrepancies).
         s: VSS                                                    s: VSS
         b: VSS                                                    b: VSS
         g: X29/9                                                  ** missing net **
         d: VDD                                                    ** VDD **
         ** X40/33 **                                              g: Xu_Traffic_TOP/Xcounter_UNIT/cnt[25]
         ** 17 **                                                  d: Xu_Traffic_TOP/Xcounter_UNIT/n9
                                  UNMATCHED OBJECTS
       LAYOUT                                                    SOURCE
       X29/X0/X26/X0/X0/X0/X0/M0(48.795,307.565)  MN(nch_25od)   ** unmatched instance **
       ** unmatched instance **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI39  MN(nch)
       ** unmatched instance **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI38  MN(nch)
       ** unmatched instance **                                  Xu_Traffic_TOP/Xcounter_UNIT/XU63/MI5  MN(nch)
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  1 sec
LVS错误报告
LVS错误报告
Virtuoso layout
Virtuoso layout
 楼主| 发表于 2023-12-28 12:20:39 | 显示全部楼层
希望有大佬指点以下
发表于 2023-12-28 15:14:35 | 显示全部楼层
器件类型不一样(红),连接问题查下(蓝)
 楼主| 发表于 2023-12-28 20:28:02 | 显示全部楼层
谢谢大佬,后面发现nch_hvt和nch_25od出自PVDD01DGZ,原来是ICC出网表的时候没有导出Power Pad导致的
现在LVS通过了
GMT+8, 2025-12-21 23:57 , Processed in 0.019210 second(s), 4 queries , Gzip On, Redis On.
