查看: 14514|回复: 54
allen指导关于深亚微米低功耗ADC设计的博士论文
发表于 2008-2-2 17:22:01 | 显示全部楼层 |阅读模式
title:
A power optimized pipelined analog-to-digital converter design in deep sub-micron CMOS technology
author:
Cho, Chang-Hyuk
apply for
PHD of Engineering, Electronics and Electrical ,Georgia Institute of Technology
director:
Allen, Phillip E.
abstract:
      High-speed, medium-resolution, analog-to-digital converters (ADCs) are important building blocks in a wide range of applications. High-speed, medium-resolution ADCs have been implemented by various ADC architectures such as a folding ADC, a subranging ADC, and a pipeline ADC. Among them, pipeline ADCs have proven to be efficient architectures for applications such as digital communication systems, data acquisition systems and video systems. Especially, power dissipation is a primary concern in applications requiring portability. Thus, the objective of this work is to design and build a low-voltage low-power medium-resolution (8-10bits) high-speed pipeline ADC in deep sub-micron CMOS technology.;The non-idealities of the circuit realization are carefully investigated in order to identify the circuit requirements for a low power circuit design of a pipeline ADC. The resolution per stage plays an important role in determining overall power dissipation of a pipeline ADC. The pros and cons of both large and small number of bits per-stage are examined. A power optimization algorithm is developed to decide more accurately which approach is better for lower power dissipation. Both identical and non-identical number of bit per-stage approaches are considered and their differences are analyzed.;A low-power, low-voltage 10-bit 100Msamples/s pipeline ADC was designed and implemented in a 0.18mum CMOS process. The power consumption was minimized with the right selection of the per-stage resolution based on the result of the power optimization algorithm and by the scaling down the sampling capacitor size in subsequent stages.
abbr_0ad22746c8a2073645169b15b98bbab7.pdf
1.5 MB, 下载次数: 334 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-2 19:54:00 | 显示全部楼层
类似多发!谢!
发表于 2008-2-3 00:10:47 | 显示全部楼层
看看看看看
发表于 2008-2-3 05:20:10 | 显示全部楼层
发表于 2008-2-14 16:10:38 | 显示全部楼层
不错不错
发表于 2008-2-14 17:43:47 | 显示全部楼层
xiexie.
发表于 2008-2-16 10:23:42 | 显示全部楼层
bucuo thank you
发表于 2008-2-26 19:36:51 | 显示全部楼层
必看宝典!!
发表于 2008-2-26 22:53:38 | 显示全部楼层
Thanks for sharing!!
发表于 2008-3-3 09:21:00 | 显示全部楼层
谢谢!
楼主辛苦了。
GMT+8, 2025-12-15 12:07 , Processed in 0.023528 second(s), 6 queries , Gzip On, Redis On.
