查看: 2644|回复: 10
[求助] DC综合问题
发表于 2023-12-10 15:23:31 | 显示全部楼层 |阅读模式
悬赏20资产未解决
inout端口如何进行时序约束,这样对吗
set_input_delay -max 5 -clock clk [remove_from_collection [all_inputs] [get_ports clk]]
set_input_delay -min 2 -clock clk [remove_from_collection [all_inputs] [get_ports clk]]
set_output_delay -max 5 -clock clk [all_outputs]
set_output_delay -min 2 -clock clk [all_outputs]
这样的话,我在形式验证时,有双向端口错误。
如果不对,应该如何设置这个约束
发表于 2023-12-11 09:23:18 | 显示全部楼层
formal过不了和约束无关
发表于 2023-12-11 17:51:02 | 显示全部楼层
形式验证和约束没有关系。
形式验证的双向端口错误是什么?是不等吗?
发表于 2023-12-14 09:58:21 | 显示全部楼层
数字有双向端口吗
 楼主| 发表于 2023-12-17 15:32:52 | 显示全部楼层
flyskyseu 发表于 2023-12-11 17:51
形式验证和约束没有关系。
Status:  Verifying...
Compare point sd_BO failed (is not equivalent)
Compare point sd_DI failed (is not equivalent)
********************************* Verification Results *********************************
Verification FAILED
   ATTENTION: 2 failing compare points have unmatched undriven signals in their
                reference fan-in.  To report such failing points, use
                "report_failing_points -inputs unmatched -inputs undriven".
              To read about undriven signal handling, use
                "man verification_set_undriven_signals".
Reference design: r:/WORK/top
Implementation design: i:/WORK/top
623 Passing compare points
2 Failing compare points
0 Aborted compare points
0 Unverified compare points
Matched Compare Points     BBPin    Loop   BBNet     Cut    Port     DFF     LAT   TOTAL
Passing (equivalent)           0       0       2       0       9     612       0     623
Failing (not equivalent)       0       0       0       0       2       0       0       2
Info:  Try the analyze_points command to see if Formality can determine potential
causes, or suggest next steps for a FAILED or INCONCLUSIVE verification.
See the man page for analyze_points usage and options.
0
显示是这个错误
 楼主| 发表于 2023-12-17 15:34:27 | 显示全部楼层
nirvana_pear 发表于 2023-12-11 09:23
formal过不了和约束无关
Verification FAILED
0
显示是这个错误
 楼主| 发表于 2023-12-17 15:35:51 | 显示全部楼层
Verification FAILED
0
显示是这个错误
 楼主| 发表于 2023-12-17 16:05:01 | 显示全部楼层
形式验证和约束没有关系。
我用这条命令就可以了
发表于 2023-12-18 11:41:09 | 显示全部楼层
你用的是BINARY:X还是0?
 楼主| 发表于 2023-12-19 16:19:16 | 显示全部楼层
flyskyseu 发表于 2023-12-18 11:41
你用的是BINARY:X还是0?
我用的是0
GMT+8, 2025-12-21 21:12 , Processed in 0.025067 second(s), 4 queries , Gzip On, Redis On.
